HSS2306A
N-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The HSS2306A is the high cell density trenched Nch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSS2306A meet the RoHS and Green Product
requirement with full function reliability approved.
VDS
30
V
RDS(ON),typ
27
mΩ
ID
4.6
A
SOT23 Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @ 10V1
4.6
A
ID@TA=70℃
3.7
A
IDM
Pulsed Drain Current2
18.4
A
PD@TA=25℃
Total Power Dissipation3
1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
RθJC
www.hs-semi.cn
Typ.
Max.
Unit
Thermal Resistance Junction-ambient 1
125
℃/W
Thermal Resistance Junction-Case1
80
℃/W
Ver 2.0
1
HSS2306A
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.023
V/℃
VGS=10V , ID=4A
27
33
VGS=4.5V , ID=3A
36
50
1.0
1.5
2.5
V
-4.2
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=4A
7
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.3
4.6
Qg
Total Gate Charge (4.5V)
5.0
6.9
1.1
2.2
VDS=15V , VGS=4.5V , ID=4A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
2.6
2.8
Turn-On Delay Time
2
4
Td(on)
nC
Rise Time
VDD=15V , VGS=10V , RG=3.3
34.4
62
Turn-Off Delay Time
ID=4A
13.2
26
Fall Time
4.8
9.6
Ciss
Input Capacitance
420
582
Coss
Output Capacitance
60
87
Crss
Reverse Transfer Capacitance
53
71
Min.
Typ.
Max.
Unit
4.6
A
18.4
A
1.2
V
8.7
nS
2.3
nC
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
IS
Continuous Source Current1,4
ISM
Pulsed Source Current2,4
VSD
Diode Forward Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF =4A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSS2306A
Typical Characteristics
40
ID=4A
RDSON (mΩ)
35
30
25
2
4
6
8
10
VGS (V)
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source
Voltage
IS Source Current(A)
6
4
TJ=150℃
2
0.25
0.50
TJ=25℃
0.75
1.00
VSD , Source-to-Drain Voltage (V)
Fig.3 Forward Characteristics Of Reverse
Fig.4 Gate-Charge Characteristics
diode
1.8
Normalized On Resistance
1.8
1.4
Normalized VGS(th)
1.4
1.0
1
0.6
0.6
0.2
0.2
-50
100
150
TJ ,Junction Temperature (℃ )
100
150
TJ , Junction Temperature (℃)
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
-50
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSS2306A
1000
F=1.0MHz
Capacitance (pF)
Ciss
100
Coss
Crss
10
1
5
9
13
17
21
25
VDS Drain to Source Voltage (V)
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TA + PDM x RθJA
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
HSS2306A
Ordering Information
Part Number
HSS2306A
www.hs-semi.cn
Package code
SOT-23
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS2306A”相匹配的价格&库存,您可以联系我们找货
