ShenZhen HanKingYuan Electronic Co.,Ltd
KY2304
30V N-Channel Mosfet
SOT-23
FEATURES
● RDS(ON) ≤ 39mΩ (31mΩ Typ.)
@VGS=10V
● RDS(ON) ≤ 52mΩ (41mΩ Typ.)
@VGS=4.5V
1. GATE
2. SOURCE
3. DRAIN
APPLICATIONS
● Load/Power Switching
● Interfacing Switching
N-CHANNEL MOSFET
MARKING
2304
2304 :Device Code
MAXIMUM RATINGS (Ta=25°C unless otherwise noted)
Symbol
Parameter
Max.
Units
VDSS
Drain-Source Voltage
30
V
VGSS
Gate-Source Voltage
±20
V
Ta = 25℃
4.0
A
Ta= 100℃
2.6
A
16
A
1.0
W
125
℃/W
-55 to +150
ID
Continuous Drain Current
IDM
Pulsed Drain Current
PD
Power Dissipation
RθJA
TJ, TSTG
note1
Thermal Resistance, Junction to Ambient
Operating and Storage Temperature Range
www.scr-ky.com
Ta = 25℃
1/5
KY2304
MOSFET ELECTRICAL CHARACTERISTICS Ta=25 °C unless otherwise specified
Parameter
Symbol
bol
Test Condition
Min.
Typ.
Max.
Units
30
V
1
μA
±100
nA
1.0
1.4
2.2
V
VGS =10V, ID =4A
31
39
On-Resistance note2
VGS =4.5V, ID =3A
41
52
Forwar d
r T ansconductance
VDS =4.5V, ID =2.5A
52
S
231
pF
42
pF
17
pF
nC
4.1
0.74
nC
0.66
nC
11
ns
48
ns
12
ns
19
ns
Maximum Continuous Drain to Source Diode
Forward Current
4
A
Maximum Pulsed Drain to Source
Diode Forward Current
16
A
1.2
V
Off Characteristic
V(BR)DSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
IGSS
Gate to Body Leakage Current
VGS = 0V,ID = 250μA
VDS = 30V,
VGS = 0V, TJ = 25℃
VGS = ±20V,VDS = 0V
On Characteristics
VGS(th)
Gate Threshold Voltage
RDS(on)
gFS
Static Drain-Source
VDS =VGS,ID = 250μA
mΩ
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain(“Miller”) Charge
VDS =15V, VGS = 0V,
f = 1.0MHz
VDS=15V, ID=3A,
VGS=4.5V,
Switching Characteristics
td(on)
Turn-On Delay Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
VGS = 4.5V, VDS=15V,
RG =3Ω, ID=3A
Turn-Off Fall Time
Drain-Source Diode Characteristics and Maximum Ratings
IS
ISM
VSD
Drain to Source Diode Forward
Voltage
VGS = 0V, ISD=2.7A,
TJ = 25℃
Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature
2 . Pulse Test: Pulse width ≤ 300μs, Duty Cycle ≤ 2%
www.scr-ky.com
2/5
Typical Performance Characteristics
Figure1. Output Characteristics
KY2304
Figure2. Transfer Characteristics
Figure3. Rdson-Drain Current
Figure4. Typical Source-Drain Diode Forward
Voltage
Figure5. Capacitance Characteristics
Figure6. Gate Charge
www.scr-ky.com
3/5
Typical Performance Characteristics (cont.)
Figure8. Normalized on Resistance vs.
Temperature
Figure7. Normalized Breakdown Voltage vs.
Temperature
Figure9. Safe Operation Area
KY2304
Figure10. Drain Current vs. Ambient Temperature
Figure11. Transient Thermal Response Curve
www.scr-ky.com
4/5
KY2304
SOT-23 PACKAGE OUTLINE DRAWING
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min
Max
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
e1
0.950 TYP
1.800
L
0.037 TYP
2.000
0.071
0.550 REF
L1
0.300
0.500
0.012
θ
0°
8°
0°
www.scr-ky.com
0.079
0.022 REF
0.020
8°
5/5
很抱歉,暂时无法提供与“KY2304”相匹配的价格&库存,您可以联系我们找货
