ShenZhen HanKingYuan Electronic Co.,Ltd
KY2312
20V N-Channel Mosfet
SOT-23
FEATURES
● RDS(ON) ≤ 21mΩ (16 mΩ Typ.)
@VGS=4.5V
● RDS(ON) ≤ 30mΩ (20 mΩ Typ.)
@VGS=2.5V
1. GATE
2. SOURCE
3. DRAIN
APPLICATIONS
● Battery Protection
● Load Switch
● Power Management
N-CHANNEL MOSFET
MARKING
2312
2312: Device Code
Other marks: "S12"
MAXIMUM RATINGS (Ta=25°C unless otherwise noted)
Symbol
Parameter
Max.
Units
VDSS
Drain-Source Voltage
V
VGSS
Gate-Source Voltage
±10
V
ID
Continuous Drain Current
IDM
Pulsed Drain Current note1
PD
Power Dissipation
RθJA
TJ, TSTG
Ta= 25℃
Ta = 100℃
Ta= 25℃
Thermal Resistance, Junction to Ambient
Operating and Storage Temperature Range
www.scr-ky.com
5
3.2
A
A
1.25
W
100
℃/W
-55 to +150
1/5
KY2312
MOSFET ELECTRICAL CHARACTERISTICS Ta=25 °C unless otherwise specified
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Units
V
Off Characteristic
V(BR)DSS
Drain-Source Breakdown Voltage
VGS=0V,ID=250μA
IDSS
Zero Gate Voltage Drain Current
VDS =20V, VGS = 0V,
1
μA
IGSS
Gate to Body Leakage Current
VDS =0V, VGS = ±10V
±100
nA
0.5
0.65
0.9
V
On Characteristics
VGS(th)
Gate Threshold Voltage
VDS= VGS, ID= 250μA
RDS(on)
Static Drain-Source on-Resistance
VGS =4.5V, ID =5A
16
21
note2
VGS =2.5V, ID =4.7A
Forward Transconductance
VDS =10V, ID = 5A
6
S
865
pF
105
pF
55
pF
gFS
mΩ
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS=10V, VGS =0V,
f = 1.0MHz
Switching Characteristics
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-off Delay Time
tf
VDD =10V, ID =4A,
RG = 1Ω, VGEN=5V,
Turn-off Fall Time
10
ns
ns
32
ns
12
ns
Drain-Source Diode Characteristics and Maximum Ratings
IS
Maximum Continuous Drain to Source Diode Forward
Current
5
A
ISM
Maximum Pulsed Drain to Source Diode Forward Current
A
VSD
Voltage
0.75
1.2
V
VGS = 0V, IS = 4A
Notes:1. Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature
2. Pulse Test: Pulse Width≤300μs, Duty Cycle≤2%
www.scr-ky.com
2/5
KY2312
TYPICAL PERFORMANCE CHARACTERISTICS
Figure 1. Gate Charge Test Circuit & Waveform
Figure 2. Resistive Switching Test Circuit & Waveforms
Figure 3. Unclamped Inductive Switching Test Circuit & Waveforms
www.scr-ky.com
3/5
KY2312
Figure 4. Peak Diode Recovery dv/dt Test Circuit & Waveforms (For N-channel)
www.scr-ky.com
4/5
KY2312
SOT-23 PACKAGE OUTLINE DRAWING
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min
Max
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
2.000
0.071
e
e1
0.950 TYP
1.800
L
0.037 TYP
0.550 REF
0.022 REF
L1
0.300
0.500
0.012
θ
0°
8°
0°
www.scr-ky.com
0.079
0.020
8°
5/5
很抱歉,暂时无法提供与“KY2312”相匹配的价格&库存,您可以联系我们找货
