A1015
PNP GENERAL PURPOSE SWITCHING TRANSISTOR
VOLTAGE 50Volts POWER 200mWatts
FEATURES
PNP epitaxial silicon, planar design.
Collector-emitter voltage VCE=-50V.
Collector current IC=-0.15A.
Transition frequency f T >80MHz @ IC=1mAdc, VCE=-10Vdc, f=30MHz.
In compliance with ER RoHS 2002/95/EC
directives.
MECHANICAL DATA
Case: SOT-23, Plastic
Terminals: Solderable per MIL-STD-750,
method 2026
Approx. Weight: 0.008gram
Marking: BA
3
C
BA
1
2
B
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
VCBO
VCEO
VEBO
IC
PD
RθJA
TJ
TSTG
Parameter
Vaule
Collector-Base Voltage
-50
Collector-Emitter Voltage
-50
Emitter-Base Voltage
-5
Collector Current
-0.15
Total Device Dissipation(FR-5 BOARD)
0.2
Thermal Resistance Form Junction to Ambient
625
Junction Temperature
150
Storage Temperature
-55~+150
Unit
V
V
V
A
W
O
C/W
O
C
O
C
E
A1015
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Collector-Base breakdown voltage
Symbol
Test Condition
Min. Typ. Max. Units
V(BR)CBO
IC=-100uA,IE=0
-50
V
Collector-Emitter breakdown voltage V(BR)CEO
IC=-0.1mA,IB=0
-50
V
Emitter-Base breakdown voltage
V(BR)EBO
IE=-100uA,IC=0
-5
V
Collector cut-off current
ICBO
VCB=-50V,IC=0
ICEX
Base cut-off current
IBEX
Emitter cut-off current
IEBO
VEB=-5V,IC=0
DC current gain*
HFE
IC=-2mA,VCE=-6V
Collector-Emitter saturation voltage VCE(SAT)
VCE=-25V,IB=0
130
-0.1
uA
-0.1
uA
-0.1
uA
-0.1
uA
400
IC=-10mA,IB=-1mA
-0.2
V
IC=-100mA,IB=-10mA
-0.3
V
IC=-10mA,IB=-1mA
-0.85
V
IC=-100mA,IB=-10mA
-0.95
V
Base-Emitter Saturation voltage*
VBE(SAT)
Input capacitance
CIB
VCB=-5V,IE=0,f=1MHZ
4.0
pF
Output capacitance
COB
8.0
pF
Transition ferquency
fT
Delay time
td
Rise time
tr
VEB=-0.5V,IC=0,f=1MHZ
IC=-1mA,VCE=-10V,
f=30MHZ
VCC=-3V,VBE=0.5V,
IC=-10mA,IB=-1mA
Storage time
ts
Fall time
tf
VCC=-3V,VBE=0.5V,
IB1=IB2=-1mA
150
MHZ
35
nS
35
nS
200
nS
50
nS
*Pulse Test: Pulse Width
很抱歉,暂时无法提供与“A1015”相匹配的价格&库存,您可以联系我们找货
