ATM3404NSA
N-Channel Enhancement Mode Field Effect Transistor
Drain-Source Voltage: 30V
Drain Current: 5A
Features
Trench FET Power MOSFET
Excellent RDS(on) and Low Gate Charge
RDS(ON) < 28mΩ (VGS = 10V)
RDS(ON) < 40mΩ (VGS = 4.5V)
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
IDM
PD@TA=25℃
PD@TA=70℃
10s
Steady State
Units
30
V
±20
V
1
5.8
5
A
1
4.6
4
A
Continuous Drain Current, VGS @ 10V
2
Pulsed Drain Current
25
A
Total Power Dissipation
3
1.32
1
3
0.84
0.64
W
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
1
RθJA
Thermal Resistance Junction-ambient
RθJA
Thermal Resistance Junction-Ambient (t ≤10s)
RθJC
1
Thermal Resistance Junction-Case
1
AGERTECH MICROELECTRONICS
Subsidiary of Sino-Talent International Holdings Ltd.
1/6
Max.
Unit
125
℃/W
95
℃/W
80
℃/W
Dated:09/2018
Rev: 1.0
ATM3404NSA
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
Conditions
BVDSS
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
2
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.025
V/℃
VGS=10V , ID=5A
24
28
VGS=4.5V , ID=4A
34
40
1.2
1.5
2.5
V
-4.8
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=5A
7
S
VDS=0V , VGS=0V , f=1MHz
2.5
5
6
8.4
2.5
3.5
Rg
Gate Resistance
Qg
Total Gate Charge (4.5V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
2.1
2.9
Td(on)
Turn-On Delay Time
2.4
4.8
Tr
Td(off)
Tf
Ciss
VDS=15V , VGS=4.5V , ID=5A
uA
nC
Rise Time
VDD=15V , VGS=10V , RG=3.3
7.8
14
Turn-Off Delay Time
ID=5A
22
44
4
8
572
800
81
112
65
91
Min.
Typ.
Max.
Unit
5
A
25
A
1.2
V
19
nS
1.04
nC
Fall Time
Input Capacitance
VDS=15V , VGS=0V , f=1MHz
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current
2,4
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=5A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
2/6
Dated:09/2018
Rev: 1.0
ATM3404NSA
Typical Characteristics Curves
39
ID=5A
33
30
RDSON (mΩ)
36
27
24
21
2
4
6
8
10
VGS (V)
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source
IS - Source Current(A)
6
4
TJ=150℃
TJ=25℃
2
0.6
0.9
VSD , Source-to-Drain Voltage (V)
Forward Characteristics Of Reverse
Fig.4 Gate-Charge CharacteristicsFig.3
1.8
Normalized on resistance
Normalized VGS(th) (V)
1.8
1.4
1
0.6
1.4
1.0
0.6
0.2
0.2
-50
100
-50
150
TJ ,Junction Temperature (℃ )
100
150
TJ , Junction Temperature (℃)
Fig.5 Normalized VGS(th) vs. TJ
Fig.6 Normalized RDSON vs. T J
3/6
Dated:09/2018
Rev: 1.0
ATM3404NSA
1000
F=1.0MHz
Capacitance (pF)
Ciss
100
Coss
Crss
10
1
5
9
13
17
21
25
VDS Drain to Source Voltage (V)
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA )
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJ peak = TC + PDM x RθJ C
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
Fig.11 Gate Charge Waveform
4/6
Dated:09/2018
Rev: 1.0
ATM3404NSA
Package Outline
SOT-23
Symbol
Dimensions In Millimeters
Min.
Max.
A
0.90
1.15
A1
0.00
0.10
A2
0.90
1.05
b
0.30
0.50
c
0.08
0.15
D
2.80
3.00
E
1.20
1.40
E1
2.25
2.55
e
e1
0.95 REF.
1.80
2.00
L
L1
0.55 REF.
0.30
0.50
5/6
Dated:09/2018
Rev: 1.0
ATM3404NSA
Package Specifications
6/6
Dated:09/2018
Rev: 1.0
很抱歉,暂时无法提供与“ATM3404NSA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17669
- 200+0.14315
- 600+0.12451
- 3000+0.10310
- 9000+0.09341
- 21000+0.08820
