UMW
R
MMBT2222A
UMW MMBT2222A
SOT-23 Plastic-Encapsulate Transistors
SOT-23
TRANSISTOR (NPN)
FEATURES
z Epitaxial planar die construction
z Complementary PNP Type available(MMBT2907A)
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Parameter
Value
Symbol
Collector-Base Voltage
75
VCBO
40
VCEO
Collector-Emitter Voltage
6
VEBO
Emitter-Base Voltage
Collector
Current
-Continuous
600
IC
Collector Dissipation
300
PC
Thermal Resistance, Junction to Ambient
417
RΘJA
Junction Temperature
150
TJ
Storage Temperature
-55~+150
Tstg
1. BASE
2. EMITTER
3. COLLECTOR
Unit
V
V
V
mA
mW
℃/W
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Pa
rameter
Symbol
Collector-base breakdown voltage
V(BR)CBO
T est conditions
Min
Typ
Max
Unit
IC= 10μA, IE=0
75
V
IC= 10mA, IB=0
40
V
6
V
Collector-emitter breakdown voltage
V(BR)CEO
Emitter-base breakdown voltage
V(BR)EBO
IE=10μA, IC=0
Collector cut-off current
ICBO
VCB=60V, IE=0
0.01
μA
ICEX
VCE=30V,VBE(off)=3V
0.01
μA
Emitter cut-off current
IEBO
VEB= 3V, IC=0
0.1
μA
hFE(1)
DC current gain
hFE(2)
hFE(3)
Collector-emitter saturation voltage
VCE(sat)
Base-emitter saturation voltage
VBE(sat)
Transition frequency
fT
Delay time
td
Rise time
tr
Storage time
tS
Fall time
tf
VCE=10V, IC= 150mA
100
VCE=10V, IC= 0.1mA
40
VCE=10V, IC= 500mA
42
IC=500 mA, IB= 50mA
IC=150 mA, IB=15mA
IC=500 mA, IB= 50mA
IC=150 mA, IB=15mA
VCE=20V, IC= 20mA,
f=100MHz
300
1
0.3
2.0
1.2
300
V
V
MHz
VCC=30V, VBE(off)=-0.5V
IC=150mA , IB1= 15mA
10
ns
25
ns
VCC=30V, IC=150mA
IB1=-IB2=15mA
225
ns
60
ns
*pulse test: Pulse Width ≤300μs, Duty Cycle≤ 2.0%.
CLASSIFICATION OF hFE(1)
RANK
L
H
RANGE
100–200
200–300
MARKING 13
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW MMBT2222A
Static Characteristic
0.25
0.9mA
0.20
400
0.8mA
hFE
0.7mA
IC
0.6mA
0.15
DC CURRENT GAIN
(A)
COMMON EMITTER
VCE=10V
1mA
COMMON EMITTER
Ta=25℃
COLLECTOR CURRENT
—— IC
hFE
500
0.5mA
0.10
0.4mA
0.3mA
0.05
Ta=100℃
300
200
Ta=25℃
100
0.2mA
IB=0.1mA
0.00
4
6
8
COLLECTOR-EMITTER VOLTAGE
VCEsat
0.5
10
VCE
12
1
(V)
10
100
COLLECTOR CURRENT
IC
VBEsat
1.2
IC
600
(mA)
—— IC
0.4
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
β=10
0.3
0.2
Ta=100℃
0.1
Ta=25℃
Ta=25℃
0.8
Ta=100℃
0.4
β=10
0.0
0.0
1
10
100
COLLECTOR CURRENT
IC
IC
1
600
10
(mA)
100
COLLECTOR CURRENT
—— VBE
Cob/ Cib
100
600
IC
—— VCB/ VEB
f=1MHz
IE=0/ IC=0
Ta=25℃
Cib
(pF)
100
IC
(mA)
COMMON EMITTER
VCE=10V
C
Ta=100℃
10
CAPACITANCE
COLLECTOR CURRENT
600
(mA)
Ta=25℃
1
0.1
0.0
0.2
0.4
0.6
0.8
Cob
10
1
0.1
1.0
1
BASE-EMMITER VOLTAGE VBE (V)
fT
500
10
REVERSE VOLTAGE
—— IC
Pc
400
V
(V)
Ta
COMMON EMITTER
VCE=20V f=200MHz
TRANSTION FREQUENCY
fT
COLLECTOR POWER DISSIPATION
Pc (mW)
(MHz)
Ta=25℃
100
10
300
200
100
COLLECTOR CURRENT
www.umw-ic.com
IC
(mA)
25
50
75
AMBIENT TEMPERATURE
2
100
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW MMBT2222A
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“UMW MMBT2222A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07592
- 500+0.06812
- 5000+0.06292
- 10000+0.06032
- 30000+0.05772
- 50000+0.05616
