UMW
R
MMBT4401
UMW MMBT4401
SOT-23 Plastic-Encapsulate Transistors
TRANSISTOR (NPN)
FEATURES
z Switching Transistor
SOT-23
MARKING:2X
1. BASE
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
2. EMITTER
Value
Unit
VCBO
Collector-Base Voltage
60
V
VCEO
Collector-Emitter Voltage
40
V
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current
600
mA
PC
Collector Power Dissipation
300
mW
Thermal Resistance From Junction To Ambient
417
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
3. COLLECTOR
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=100µA, IE=0
60
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=1mA, IB=0
40
V
Emitter-base breakdown voltage
V(BR)EBO
IE=100µA, IC=0
6
V
Collector cut-off current
ICEO
VCE=30V, IB=0
100
nA
ICBO
VCB= 50V, IE=0
100
nA
Emitter cut-off current
IEBO
VEB=5V, IC=0
100
nA
DC current gain
hFE
VCE=1V, IC=150mA
100
300
Collector-emitter saturation voltage
VCE(sat)
IC=150mA, IB=15mA
0.4
V
VBE(sat)
IC=150mA, IB=15mA
0.95
V
Transition frequency
fT
VCE=10V,IC=20mA, f=100MHz
Delay time
td
VCC=30V, VBE(off)=-2V IC=150mA,
15
ns
Rise time
tr
IB1=15mA
ns
Storage time
ts
225
ns
Fall time
tf
30
ns
www.umw-ic.com
VCC=30V, IC=150mA, IB1= IB2=15mA
1
250
MHz
友台半导体有限公司
UMW
R
UMW MMBT4401
Static Characteristic
DC CURRENT GAIN
IC
0.8mA
0.7mA
0.6mA
0.5mA
100
0.4mA
0.3mA
50
IC
Ta=100℃
0.9mA
150
COMMON EMITTER
VCE= 1V
1mA
hFE
(mA)
COMMON
EMITTER
Ta=25℃
200
COLLECTOR CURRENT
hFE
1000
250
Ta=25℃
100
0.2mA
IB=0.1mA
2
3
COLLECTOR-EMITTER VOLTAGE
VBEsat ——
1000
4
1
IC
VCEsat
1000
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
800
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
IC
600
100
(mA)
IC
β=10
β=10
Ta=25℃
600
Ta=100 ℃
400
200
1
10
100
COLLECTOR CURREMT
IC
IC
Ta=100 ℃
100
Ta=25℃
10
0.5
0.1
600
1
10
COLLECTOR CURREMT
(mA)
VBE
fT
500
600
(mA)
IC
Ta=25℃
TRANSITION FREQUENCY
10
T =2
5℃
a
T =1
00℃
a
COLLECTOR CURRENT
IC
fT
100
600
100
IC
COMMON EMITTER
VCE=10V
(MHz)
COMMON EMITTER
VCE=1V
(mA)
10
COLLECTOR CURRENT
VCE (V)
1
0.1
400
600
800
1000
100
10
1200
10
Cob/Cib
100
VCB/VEB
COLLECTOR POWER DISSIPATION
PC (mW)
Ta=25 ℃
Cib
C
(pF)
PC
400
f=1MHz
IE=0/IC=0
CAPACITANCE
COLLECTOR CURRENT
BASE-EMMITER VOLTAGE VBE (mV)
10
Cob
IC
40
(mA)
Ta
300
200
100
0.1
1
REVERSE VOLTAGE
www.umw-ic.com
10
V
25
50
75
AMBIENT TEMPERATURE
(V)
2
100
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW MMBT4401
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“UMW MMBT4401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09020
- 150+0.07720
- 1000+0.06420
- 5000+0.05900
