HYG065P03LQ1 D/U/V
P-Channel Enhancement Mode MOSFET
Feature
Pin Description
-30V/-70A
RDS(ON)= 5.9mΩ(typ.) @VGS = -10V
RDS(ON)= 9.1mΩ(typ.) @VGS = -4.5V
G D
100% avalanche tested
Reliable and Rugged
Halogen Free and Green Devices Available
S
G D
G D
S
(RoHS Compliant)
TO-252-2L
TO-251-3L
TO-251-3S
Applications
Power Management in DC/DC converter.
Load switching.
Motor control.
P-Channel MOSFET
Ordering and Marking Information
Package Code
D
G065P03
U
G065P03
XYMXXXXXX
XYMXXXXXX
V
G065P03
D: TO-252-2L
XYMXXXXXX
U: TO-251-3L
V:TO-251-3S
Date Code
XYMXXXXXX
Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hymexa.com
1
V1.2
S
HYG065P03LQ1 D/U/V
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (Tc=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
-30
V
VGSS
Gate-Source Voltage
±20
V
TJ
Junction Temperature Range
-55 to 175
°C
TSTG
Storage Temperature Range
-55 to 175
°C
Tc=25°C
-70
A
Tc=25°C
-280
A
Tc=25°C
-70
A
Tc=100°C
-49.5
A
Tc=25°C
57.7
W
Tc=100°C
28.8
W
IS
Drain Current-Continuous
Mounted on Large Heat Sink
Note:
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance, Junction-to-Case
2.6
°C/W
RJA
Thermal Resistance, Junction-to-Ambient **
110
°C/W
EAS
SinglePulsed-Avalanche Energy ***
164***
mJ
L=0.1mH
Repetitive rating; pulse width limited by max junction temperature.
Surface mounted on FR-4 board.
Limited by TJmax , starting TJ=25°C , L= 0. 1mH, RG= 25Ω, VGS = -10V.
Electrical Characteristics(Tc =25°C
Symbol
Parameter
Test Conditions
HYG065P03LQ1
Unit
Min
Typ
Max
VGS=0V,IDS=-250uA
-30
V
VDS=-30V, VGS=0V
-1
uA
-50
uA
-1.0
-1.5
-3.0
V
±100
nA
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Drain-to-Source Leakage Current
VGS(th)
IGSS
RDS(ON)*
TJ=125°C
Gate Threshold Voltage
VDS=VGS, IDS=-250uA
Gate-Source Leakage Current
VGS=±20V,VDS=0V
VGS=-10V,ID= -20A
5.9
7.5
mΩ
9.1
14.0
mΩ
-0.85
-1.3
V
17
ns
9
nC
Drain-Source On-state Resistance
VGS=-4.5V,ID= -20A
Diode Characteristics
VSD*
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
www.hymexa.com
ISD= -20A,VGS=0V
ISD= -20A,dI/dt=100A/us
2
V1.2
HYG065P03LQ1 D/U/V
Electrical Characteristics (Cont.) (Tc =25°C
Symbol
Parameter
Test Conditions
HYG065P03LQ1
Min
Typ
Max
Unit
Dynamic Characteristics
Gate Resistance
VGS=0V,VDS=0V,
Frequency=1.0MHz
9
Ciss
Input Capacitance
VGS=0V,
3595
Coss
Output Capacitance
VDS=-15V,
531
Crss
Reverse Transfer Capacitance
Frequency=1.0MHz
446
td(ON)
Turn-on Delay Time
12
Tr
Turn-on Rise Time
VDD= -15V,RG=4Ω,
65
td(OFF)
Turn-off Delay Time
IDS= -20A,VGS=-10V
100
96
76
41
11
22
RG
Tf
Turn-off Fall Time
Gate Charge
Ω
pF
ns
Characteristics
Qg
Total Gate Charge
(Vgs=-10V)
Qg
Total Gate Charge
(Vgs=-4.5V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS = -24V, ID= -20A,
Note: *Pulse test; pulse width ≤ 300us,duty cycle ≤ 2%
www.hymexa.com
3
V1.2
nC
HYG065P03LQ1 D/U/V
Typical Operating Characteristics
-ID-Drain Current(A)
Voltage
Figure 2: Drain Current
Power Dissipation (w)
Figure 1: Power Dissipation
Tc-Case Temperature(℃)
Impedance
Thermal
Normalized Transient
Figure 4: Thermal Transient Impedance
Zθjc
Voltage
Figure 3: Safe Operation Area
-VDS-Drain-Source Voltage(V)
-VDS-Drain-Source Voltage (V)
www.hymexa.com
Voltage
RDS(ON)-ON-Resistance(mΩ)
Figure 6: Drain-Source On Resistance
Voltage
Figure 5: Output Characteristics
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
- ID-Drain Current(A)
4
V1.2
HYG065P03LQ1 D/U/V
Typical Operating Characteristics(Cont.)
Voltage
-IS-Source Current (A)
Figure 8: Source-Drain Diode Forward
Voltage
Normalized On-Resistance
Figure 7: On-Resistance vs. Temperature
Tj-Junction Temperature (℃)
www.hymexa.com
Voltage
-VGS-Gate-Source Voltage (V)
Figure 10: Gate Charge Characteristics
Voltage
C-Capacitance(pF)
Figure 9: Capacitance Characteristics
-VSD-Source-Drain Voltage(V)
Q G-Gate Charge (nC)
5
V1.2
HYG065P03LQ1 D/U/V
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
6
V1.2
HYG065P03LQ1 D/U/V
Device Per Unit
Package Type
Unit
Quantity
TO-252-2L
TO-252-2L
TO-251-3L
TO-251-3S
Tube
75
Reel
Tube
Tube
2500
75
75
Package Information
TO-252-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A1
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
7
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
2.90REF
L2
0.51BSC
L3
0.88
1.28
L4
1.00
L5
1.65
1.80
1.95
θ
0°
8°
V1.2
HYG065P03LQ1 D/U/V
TO-251-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b2
0.00
0.04
0.10
b2'
0.00
0.04
0.10
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
2.286BSC
H
16.22
16.52
16.82
L1
9.15
9.40
9.65
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
8
V1.2
HYG065P03LQ1 D/U/V
TO-251-3S
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
2.286BSC
H
10.00
11.22
11.44
L1
3.90
4.10
4.30
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
9
V1.2
HYG065P03LQ1 D/U/V
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmax to TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
See Classification Temp in table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (T p) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
10
V1.2
HYG065P03LQ1 D/U/V
Table 1.SnPb Eutectic Process – Classification Temperatures (Tc)
Package
Volume mm³
Volume mm³
Thickness
很抱歉,暂时无法提供与“HYG065P03LQ1D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.62832
- 10+1.26544
- 30+1.10992
