PPT89T30V5AE2M
Transistor
Feature
2 - Collector
1 - Base
¾
This device is Pb-Free and RoHS compliant.
¾
PNP epitaxial planar silicon transistor
3 - Emitter
Mechanical Characteristics
¾
Lead finish:100% matte Sn(Tin)
¾
Mounting position: Any
¾
Qualified max reflow temperature:260℃
¾
Device meets MSL 1 requirements
¾
Pure tin plating: 7 ~ 17 um
¾
Pin flatness:≤3mil
Absolute maximum rating@25℃
Parameter
Symbol
Value
Units
Collector-Emitter Breakdown Voltage
V (BR)CEO
-20
V
Collector-Base Breakdown Voltage
V (BR)CBO
-30
V
Emitter -Base Breakdown Voltage
V (BR)EBO
-6
V
IC
-5
A
IC(Pulse)
-10
A
VCE(sat)
-1
V
PC
3
W
Collector Current
Collector-Emitter Saturation Voltage
Collector power dissipation
Rev.06
1
www.prisemi.com
Transistor
PPT89T30V5AE2M
Electrical characteristics per line@25℃( unless otherwise specified)
Parameter
Symbol
Conditions
Min.
V (BR)CEO
IC=-1.0mA,IB=0
-20
V
V (BR)CBO
IC=-50uA,IE=0
-30
V
V (BR)EBO
IE=-50uA,IC=0
-6.0
V
Emitter Cutoff Current
IEBO
VEB=-5V
-500
nA
Collector Cutoff Current
ICBO
VCB=-20V
-500
nA
VCE(sat)
IC=-4A,IB=-100mA
-1
V
Transition frequency
fT
VCE=-6V,IE=50mA,f=100MHz
120
MHz
Output capacitance
Co
VCB=-20V,IE=0A,f=1MHz
60
pF
DC Current gain
hFE
VCE=-2V,IC=-0.5A
Typ.
-0.3
100
Max.
Units
400
Typical Characteristics
hFE
% Of Rated Power
100
VCE=1V
100
80
60
40
0.01
0.1
1
IC(A)
Fig1.DC Current Gain
25
50
75
100
125
(°C)
Fig2. Power Derating Curve
VCE(SAT)
VBE(SAT)
(V)
(V)
0.8
0.1
0.7
0.6
0.01
0.01
0.5
0.1
1
10
0.01
0.1
1
10
IC(A)
IC(A)
Fig 3.Collector-Emitter Saturation Voltage
Rev.06
Fig4. Base-Emitter Saturation Voltage
2
www.prisemi.com
Transistor
PPT89T30V5AE2M
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
30
90
120
150
180
240
210
270
300
330
360
390
420
450
480
Time (sec)
Product dimension (SOT89-3L)( unit :mm)
4.5
1.6
1.5
0.5
2.5
4.0
1.0
(1)
(2)
(3)
0.4
0.4
0.5
0.4
1.5
1.5
3.0
Rev.06
(1)
Base
(2)
Collector
(3)
Emitter
3
www.prisemi.com
Transistor
PPT89T30V5AE2M
1.73
0.41
4.6
0.95
1.47
1.3
0.6
1.5
Ordering information
Device
Package
Shipping
PPT89T30V5AE2M
SOT89-3L (Pb-Free)
1000 / Tape & Reel
Rev.06
4
www.prisemi.com
Transistor
PPT89T30V5AE2M
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06
5
www.prisemi.com
很抱歉,暂时无法提供与“PPT89T30V5AE2M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.31951
- 100+0.29821
- 300+0.27691
- 500+0.25561
- 2000+0.24496
- 5000+0.23857
