Jun 2015
SE30P50B
P-Channel Enhancement-Mode MOSFET
Revision: A
Features
General Description
Thigh Density Cell Design For Ultra Low
On-Resistance Fully Characterized Avalanche
Voltage and Current Improved Shoot-Through
For a single MOSFET
VDS = -30V
RDS(ON) = 5.8mΩ @ VGS=-10
FOM
Simple Drive Requirement
Small Package Outline
Surface Mount Device
Pin configurations
See Diagram below
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
Drain Current
Total Power Dissipation
Continuous
Pulsed
@TA=25℃
Operating Junction Temperature Range
ShangHai Sino-IC Microelectronic Co., Ltd.
ID
-50
-120
A
PD
90
W
TJ
-55 to 150
1.
SE30P50B
Electrical Characteristics
Symbol
(TJ=25℃ unless otherwise noted)
Parameter
Test Conditions
Min
Typ
Max
Units
OFF CHARACTERISTICS (Note 2)
BVDSS
Drain-Source Breakdown Voltage
ID=-250μA, VGS=0 V
IDSS
Drain to Source Leakage Current
VDS= -30V, VGS=0V
IGSS
Gate-Body Leakage Current
VGS=20 V
VGS(th)
RDS(ON)
Gate Threshold Voltage
VDS= VGS, ID=250μA
Static Drain-Source On-Resistance
2
VGS=-10V, ID=-20A
-30
V
1
μA
100
nA
-0.4
-1.5
-2.2
V
5.8
7
mΩ
DYNAMIC PARAMETERS
Ciss
Input Capacitance
VGS=0V,
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS=15V,
f=1MHz
7032
pF
898
pF
743
pF
80
nC
19
nC
38
nC
SWITCHING PARAMETERS
Qg
Total Gate Charge 2
VGS=10V,
VDS=15V,
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
Turn-On Delay Time
VGS=10V, VDS=15V,
ns
td(off)
Turn-Off Delay Time
RGEN=1Ω
80
ns
td(r)
Turn-On Rise Time
ID=1A
36
ns
td(f)
Turn-Off Fall Time
33
ns
ID=30A
Thermal Resistance
Symbol
Parameter
Typ
Max
Units
RθJC
Junction to Case
2
℃/W
RθJA
Junction to Ambient (t≦10s)
50
℃/W
2.
SE30P50B
Test Circuits and Waveform
3.
SE30P50B
Typical Characteristics
4.
SE30P50B
Package Outline Dimension
TO-252
5.
SE30P50B
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics
Co., Ltd.
© 2005 SINO-IC - Printed in China - All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road,
ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China
Phone:
+86-21-33932402
33932403
33932405 33933508 33933608
Fax: +86-21-33932401
Email: szrxw002@126.com
Website: http://www.sino-ic.net
6.
很抱歉,暂时无法提供与“SE30P50B”相匹配的价格&库存,您可以联系我们找货
