ZD1117ILTR18
ZD1117ILTR18
    ZETTA(澜智)
    SOT223-3
    输出类型:-;输出极性:正;最大输入电压:18V;输出电压:1.8V;输出电流:1A;电源纹波抑制比(PSRR):-;
ZD1117ILTR18 数据手册
ZD1117 1A Bipolar Linear Regulator     DESCRIPTION  FEATURES      ZD1117 is a series of low dropout three‐terminal  regulators with a dropout of 1.3V at 1A load current.  ZD1117 features a low standby current 2mA.  Other than a fixed version (Vout = 1.2V, 1.5V, 1.8V,  2.5V, 3.3V, 5V, and 12V), ZD1117 has an adjustable  version, which can provide an output voltage from  1.25 to 12V with only two external resistors.      ZD1117 is available in SOT‐223, TO‐252  power packages.  Other than a fixed version and an adjustable  version, output value can be customized on  demand.  Maximum output current is 1A  Range of operation input voltage: Max 18V  Standby current: 2mA (typ.)  Line regulation: 0.1%/V (typ.)  Load regulation: 10mV (typ.)  Environment Temperature: ‐40C~85C  Compatible with tantalum capacitor,  electrolytic capacitor and MLCC.           ZD1117 offers thermal shut down and current limit  functions, to assure stability of chip and power  system. Trimming technique is used to guarantee  output voltage accuracy within 2%. Other output  voltage accuracy such as 1% can be customized on  demand.         APPLICATIONS     Power Management for Computer Mother  Board, Graphic Card  LCD Monitor and LCD TV  DVD Decode Board  ADSL  Modem  Post Regulators for Switching Supplies            TYPICAL APPLICATION  TYPICAL ELECTRICAL CHARACTERISTIC      ZD1117  Vin  10uF  Vout  Gnd  ZD1117‐ADJ Vout Vs. Temp  Vout    1.5  10uF    Vout (V)  Vin      1.0    0.5        0.0      Application circuit ZD1117 fixed version  ‐50  50  150  Temperature (C)    www.zettadevice.com 1 250    ZD1117   PIN CONFIGURATION  ORDERING INFORMATION    ZD1117 □ 1 □ 2 □ 3 □ 4 □ 5  Code        □1    □2  □3        □4    □5  Product Classification  Marking  1117:    Product Code    ZD: Zetta Device  1117 ZD   XX:  XX    YYZZ    Output Voltage  YY: Lot No.  ZZ: Date Code  Product Classification  1117:    Product Code    ZD:Zetta Device    XX:  1117 ZD   Output Voltage  XX    YYZZ  YY:Lot No.  Description  Temperature&Rohs:  I:‐40~85C ,Pb Free Rohs Std.  Package type:  L:SOT‐223  O:TO‐252  Packing type:  TR:Tape&Reel (Standard)  Output voltage:  e.g.  12=1.2V   15=1.5V  18=1.8V  25=2.5V  33=3.3V  50=5.0V  120=12V  AD=Output adjustable  Voltage accuracy:  1=±1%(Customized)  Blank(default)=±2%  ZZ:Date Code  Vss/Adj Vin Vout   4 □   ZD1117ILTR□                   4 □   LC1117IOTR□ TO-252       1 Vss/ADJ 2 Vout  3 Vin  1117 B XX YYZZ             1 2 3 Ground Pin/Adjustable  Supply Voltage Input  Output Voltage  ABSOLUTE MAXIMUM RATING    Parameter    Value  18V 150C  ‐40C – 85C  20C / W  12.5C / W  ‐40C ‐ 150C  260C, 10S  Max Input Voltage  Max Operating Junction Temperature(Tj)  Ambient Temperature(Ta)  SOT‐223  Package Thermal Resistance(jc)  TO‐252  Storage Temperature(Ts)  Lead Temperature & Time    Note:  Exceed these  limits  to  damage  to the  device.  Exposure  to  absolute  maximum  rating  conditions may affect  device reliability.      RECOMMENDED WORK CONDITIONS    Parameter  Value  Max. 16V ‐40C –125C  Input Voltage Range  Operating Junction Temperature(Tj)     Exceptional for ZD1117‐12V, the maximum input voltage for ZD1117‐12V is 20V.    www.zettadevice.com 2   ZD1117   ELECTRICAL CHARACTERISTICS  Tj=25C  Symbol    Parameter    Vref  Reference Voltage                                  Vout  Output Voltage                                      ΔVout  Line  Regulation                                      ΔVout  Load Regulation    www.zettadevice.com Conditions ZD1117‐ADJ  10mA≤Iout≤1A , Vin=3.25V  ZD1117‐1.2V  0≤Iout≤1A , Vin=3.2V  ZD1117‐1.5V  0≤Iout≤1A , Vin=3.5V ZD1117‐1.8V  0≤Iout≤1A , Vin=3.8V  ZD1117‐2.5V  0≤Iout≤1A , Vin=4.5V  ZD1117‐3.3V  0≤Iout≤1A , Vin=5.3V  ZD1117‐5.0V  0≤Iout≤1A , Vin=7.0V  ZD1117‐12.0V  0≤Iout≤1A , Vin=14V  ZD1117‐1.2V  Iout=10mA,   2.7V≤Vin≤15V  ZD1117‐ADJ  Iout=10mA,  2.75V≤Vin≤16V  ZD1117‐1.5V  Iout=10mA,   3.0V≤Vin≤16V  ZD1117‐1.8V  Iout=10mA,   3.3V≤Vin≤16V  ZD1117‐2.5V  Iout=10mA,   4.0V≤Vin≤16V  ZD1117‐3.3V  Iout=10mA,   4.8V≤Vin≤16V  ZD1117‐5.0V  Iout=10mA,   6.5V≤Vin≤16V  ZD1117‐12.0V  Iout=10mA,   13.5V≤Vin≤20V  ZD1117‐ADJ  Vin  =2.7V,  10mA≤Iout≤1A  ZD1117‐ADJ  Vin  =2.75V,  10mA≤Iout≤1A  ZD1117‐1.5V  Vin=3.0V, 10mA≤Iout≤1A  ZD1117‐1.8V  Vin=3.3V, 10mA≤Iout≤1A  ZD1117‐2.5V  Vin=4.0V, 10mA≤Iout≤1A  ZD1117‐3.3V  Vin=4.8V, 10mA≤Iout≤1A  ZD1117‐5.0V  Vin=6.5V, 10mA≤Iout≤1A  ZD1117‐12.0V  Vin=13.5V,   10mA≤Iout≤1A  3 Min Typ  Max  Unit 1.275  V  1.224  V  1.53  V  1.836  V  2.55  V  3.366  V  5.1  V  12.24  V  0.2  %/V  0.2  %/V  0.2  %/V  0.2  %/V  0.2  %/V  0.2  %/V  0.2  %/V  0.2  %/V  30  mV  30  mV  30  mV  30  mV  30  mV  30  mV  30  mV  30  mV    1.225  1.25  1.176  1.2  1.47  1.5  1.764  1.8  2.45  2.5  3.234  3.3              4.9  5    11.76  12      0.1    0.1    0.1          0.1      0.1    0.1    0.1    0.1            10    10    10    10    10              10    10        10    ZD1117   ELECTRICAL CHARACTERISTICS continued  Tj=25C  Symbol    Parameter  Conditions        Iout=100mA  Vdrop  Dropout Voltage  Ilimit  Current Limit  Vin‐Vout=2V, Tj=25°C  Minimum Load Current  ZD1117‐ADJ  Imin                      Iq  Iout=1A  ZD1117‐1.2V, Vin =10V  ZD1117‐1.5V, Vin =12V  ZD1117‐1.8V, Vin =12V  Quiescent Current  ZD1117‐2.5V,Vin =12V  ZD1117‐3.3V, Vin =12V  ZD1117‐5.0V, Vin =12V  ZD1117‐12.0V, Vin =20V      IAdj    ZD1117‐ADJ  Adjust Pin Current  ΔV/ΔT  Temperature coefficient        JC  Vin  =5V,  10mA≤Iout≤1A            SOT‐223  Thermal Resistance                      ZD1117‐ADJ  Iadj change    1  Vin  =5V,  10mA≤Iout≤1A    Ichange  Min  TO‐252  TO‐220  Typ  Max  Unit  1.23  1.3  V  1.3  1.5  V      A  2  10  mA  2  5  mA  2  5  mA  2  5  mA  2  5  mA  2  5  mA  2  5  mA  2  5  mA  120  uA  10  uA    55    0.2  ±100  20  10  4.5          ppm    °C/W    Note1: All test are conducted under ambient temperature 25°C and within a short period of time 20ms  Note2: Load current smaller than minimum load current of ZD1117‐ADJ will lead to unstable or oscillation output.    BLOCK DIAGRAM      www.zettadevice.com 4   ZD1117   DETAILED DESCRIPTION    ZD1117 is a series of low dropout voltage, three terminal regulators. Its application circuit is very simple:  the fixed version only needs two capacitors and the adjustable version only needs two resistors and two capacitors to  work.  It is composed of some modules including start‐up circuit, bias circuit, bandgap, thermal shutdown, current limit,  power transistors and its driver circuit and so on.    The thermal shut down modules can assure chip and its application system working safety when the junction  temperature is larger than 140°C.    The bandgap module provides stable reference voltage, whose temperature coefficient is compensated by careful design  considerations. The temperature coefficient is under 100 ppm/°C. And the accuracy of output voltage is guaranteed by  trimming technique.      TYPICAL APPLICATION    ZD1117 has an adjustable version and six fixed versions (1.2V, 1.5V, 1.8V, 2.5V, 3.3V, 5V and 12V)    Fixed Output Voltage Version    ZD1117  Vin  Vin        10uF  Vout  Vout  10uF  Gnd        Application circuit of ZD1117 fixed version    1) Recommend using 10uF tan capacitor as bypass capacitor (C1) for all application circuit.  2) Recommend using 10uF tan capacitor to assure circuit stability.    Adjustable Output Voltage Version    ZD1117‐ADJ provides a 1.25V reference voltage. Any output voltage between 1.25V~12V can be achievable by  choosing two external resistors (schematic is shown below), R1 and R2    ZD1117‐ADJ  Vin  Vin    10uF  Vout  Vout    ADJ  R1  10uF    R2        Application Circuit of ZD1117‐ADJ    The output voltage of adjustable version follows the equation: Vout=1.25(1+R2/R1)+IAdjR2. We can ignore  IAdj because IAdj (about 50uA) is much less than the current of R1 (about 2~10mA).    www.zettadevice.com 5   ZD1117   1) To meet the minimum load current (>10mA) requirement, R1 is recommended to be 125ohm or lower. As  ZD1117‐ADJ can keep itself stable at load current about 2mA, R1 is not allowed to be higher than 625ohm.  2) Using a bypass capacitor (CADJ) between the ADJ pin and ground can improve ripple rejection. This bypass  capacitor prevents ripple from being amplified as the output voltage is increased. The impedance  of CADJ  should be less than R1 to prevent ripple from being amplified. As R1 is normally in the range of 100Ω~500Ω,  the value of CADJ  should satisfy this equation: 1/(2frippleCADJ)
ZD1117ILTR18 价格&库存
很抱歉,暂时无法提供与“ZD1117ILTR18”相匹配的价格&库存,您可以联系我们找货
ZD1117ILTR18
  • 1+0.22880
库存:490
ZD1117ILTR18
  • 10+0.20931
  • 100+0.18339
  • 300+0.17043
  • 2500+0.16071
  • 5000+0.15293
  • 10000+0.14904
库存:34097
