RPM SERIES
HIGE PULSE LOAD MELF RESISTORS
Feature
• Advanced carbon film technology
• Excellent overall pulse load capability
• Compliant to RoHS directive 2011/65/EU
• Compliant to REACH (EC No. 1907/2006)) (last updated: 27/06/2018)
www.thunder-resistor.com
sales@thunder-resistor.com
Page 1 of 9
1.
RPM series high pulse load melf resistors
2.
PART NUMBER:
Part number of the resistor is identified by the series name, size code, power rating,
tolerance, temperature coefficient, packing type and resistance value.
Example:
RPM
73P
0204
F
T
Type
Power
Rating
Metric
Size
Tol.
TCR
Packing
151
Resistance
(1) Style: RPM SERIES
(2) Power Rating:
(3) DIN size:
please see the data sheet
DIN: 0204, 0207
(4) Tolerance:
F=±1%; G=±2%; J=±5%
(5)
0= >100ppm/℃
T.C.R.:
(6) Packaging Type:
(7)
3.
T=REEL/BOX
Resistance Value: 100K(104); 22K(223); 2K1(212); 120R(121); 10R(100);
1.8R(1R8); 0.33R(R99)………
Structure of the resistors:
Page 2 of 9
4.
COLOR BAND-CODE:
There are 2 bands of color rings as significant figures for 0204 size with G(±2%) and
J(±5%) tolerance resistors shown in the left figure with tolerance code.
There are 3 bands of rings as significant figures for 0204 size with F(±1%) tolerance
resistors shown in the right figure without tolerance code.
There are four color bands for other sizes resistors with G(±2%) and J(±5%) tolerance
shown in the left figure.
There are five color bands for other size resistors with F(±1%) tolerance shown in the
right figure.
Page 3 of 9
5.
ELECTRICAL CHARACTERISTICS
Unless otherwise specified, all values are tested at the following condition:
Temperature: 21℃ to 25℃; Relative humidity: 45% to 70%;
Rated Continuous Working Voltage (RCWV)=
Resistance value out of range is available on request.
Power Rating Resistance Value
Page 4 of 9
6.
ENVIRONMENTAL CHARACTERISTICS
(1) Temperature Coefficient Test
IEC 60115-1, 4.8: Test of resistors at room temperature and 60°C or 100°C on
request above room temperature. Then measure the resistance. The Temperature
Coefficient is calculated by the following equation and its value should be within the
range requested.
Re sistor Temperatur e Coefficien t
R
R0
t
t0
R R0
1
10 6
R0
t t0
= Resistance value under the testing temperature
= Resistance value at the room temperature
= the 2nd testing temperature
= Room temperature
(2) Short Time Over Load Test
IEC60115-1 4.13: At 10 times rated voltage or 2 times the maximum working voltage
whichever is lower for 5 seconds, the resistor should be free from defects. The
change of the resistance value should be within ± (0.25%+0.05Ω) as compared with
the value before the test.
(3) Solderability
IEC 60115-1, 4.17: 235±5°C for 3±0.5 Seconds, there are at least 95% solder
coverage on the termination.
(4) Resistance to soldering heat:
IEC 60115-1, 4.18: 260±3°C for 10±1 Seconds, The change of the resistance value
should be within ±(0.25%+0.05 Ω) as compared with the value before the test.
(5) ESD human body mode
IEC 60115-1, 4.38: 0204 size 6kV and 0207 size 16kV, 3 pos.+3 neg. (equivalent to
MIL-STD-883, method 3015) The change of the resistance value should be within
±(0.50%+0.05 Ω) as compared with the value before the test.
Page 5 of 9
(6) Climatic sequence
IEC 60115-1, 4.19: -55°C to Room Temp. to +155°C to Room Temp. (5 cycles). The
change of the resistance value shall be within ± (2.0%+0.05Ω) as compared with the
value before the load. After the test the resistors shall be free from the electrical or
mechanical damage.
(7) Damp Heat Steady State
IEC 60115-1, 4.24: 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
or the maximum working voltage whichever is lower. The change of the resistance
value should be within ± (5.0%+0.05Ω) as compared with the value before the load.
(8) Load Life Test
IEC 60115-1, 4.25: 70±2°C at RCWV or the maximum working voltage whichever
is lower for 1,000+48/-0 Hr. (1.5Hr. on, 0.5Hr. off). The resistors shall be arranged not
much effected mutually by the temperature of others and the excessive ventilation
shall not be performed. The change of the resistance value should be within ±
(9) Accidental Overload Test
IEC 60115-1, 4.26:
4 times RCWV for 1 Minute. No evidence of flaming or arcing
(10) Resistance to Solvent
IEC 60115-1, 4.30: IPA for 5±0.5 Min. with ultrasonic. No deterioration occurred.
(11) Surge compatibility test
IEC 60115-1, 4.27: Surge voltage capability up to maximum10 kV 1.2/50 μs pulse,
5 pulses at 12 s intervals; for permissible resistance change ± (0.5 % R + 0.05 Ω)
IEC 60115-1, 4.27: Surge voltage capability up to maximum 10 kV 10/700 μs pulse,
10 pulses at 1 m intervals; for permissible resistance change ± (0.5 % R + 0.05 Ω)
Page 6 of 9
The pulse loading voltage see the following graphs:
Page 7 of 9
Page 8 of 9
Disclaimer
All products, product specifications and data are
subject to change without notice to improve reliability,
function or design or otherwise.
Thunder Precision Resistors makes no warranty,
representation or guarantee regarding the suitability
of the products for any particular purpose or the
continuing production of any product to the
maximum extent permitted by applicable law.
Page 9 of 9
很抱歉,暂时无法提供与“PRM16M0207J0T104”相匹配的价格&库存,您可以联系我们找货
