BCT0102ETA-TR
BCT0102ETA-TR
    BROADCHIP(广芯)
    XTDFN-8L(1x1.4)
    2Bit Bidirectional Level-Shifting
BCT0102ETA-TR 数据手册
BCT0102 2-Bit Bidirectional Voltage-Level Translator BCT0102 2-Bit Bidirectional Voltage-Level Translator GENERAL DESCRIPTION FEATURES This two-bit non-inverting translator is a bidirectional voltage-level translator and can be used to establish digital switching compatibility between mixed-voltage systems. It uses two separate configurable power-supply rails, with the A ports supporting operating voltages from 1.65V to 5.5V while it tracks the VCCA supply, and the B ports supporting operating voltages from 2.3V to 5.5V while it tracks the VCCB supply. This allows the support of both lower and higher logic signal levels while providing bidirectional translation capabilities between any of the 1.8V, 2.5V, 3.3V, and 5V voltage nodes. When the output-enable (OE) input is low, all I/Os are placed in the high-impedance state, which significantly reduces the power-supply quiescent current consumption. OE has an internal pull-down current source, as long as VCCA is powered. To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pull-down resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver.        No Direction-Control Signal Needed Data Rates 24Mbps (Push-Pull) 2Mbps (Open-Drain) 1.65V to 5.5V on A Ports and 2.3V to 5.5V on B Ports (VCCA ≤ VCCB) VCC Isolation: If Either VCC is at GND, Both Ports are in the High-Impedance State No Power-Supply Sequencing Required, Either VCCA or VCCB can be Ramped First IOFF: Supports Partial-Power-Down Mode Operation Available in TSOT23-8, XTDFN1.4X1.0-8L, QFN1.4X1.2-8L package. APPLICATIONS I2C BUS Portable POS Systems Smart Card Readers Cell-Phones GPS Portable Communication Devices ORDERING INFORMATION Order Number Package Type Temperature Range Marking QTY/Reel BCT0102EDA-TR TSOT23-8 -40°C to +85°C SAXX 4000 BCT0102ETA-TR XTDFN1.4X1.0-8L -40°C to +85°C SAXX 3000 BCT0102EGA-TR QFN1.4X1.2-8L -40°C to +85°C SAXX 3000 Note 1: "SA" in Marking is product short code for BCT0102. "XX" in Marking will be appeared as the batch code. REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 1 BCT0102 2-Bit Bidirectional Voltage-Level Translator PIN CONFIGURATION (Top View) 1 B1 2 B2 3 OE 4 MARKING VCCB VCCA 1 8 VCCB A1 A1 2 7 B1 6 A2 A2 3 6 B2 5 GND GND 4 5 OE 8 VCCA 7 TSOT23-8 XTDFN1.4X1.0-8L VCCA 1 A1 2 8 A2 3 7 B1 GND 4 6 B2 VCCB 5 OE QFN1.4X1.2-8L PIN DESCRIPTION PIN NAME FUNCTION SOT DFN/QFN 1 8 VCCB 2 7 B1 Input/Output B. Referenced to VCCB. 3 6 B2 Input/Output B. Referenced to VCCB. 4 5 OE 5 4 GND 6 3 A2 Input/Output A. Referenced to VCCA. 7 2 A1 Input/Output A. Referenced to VCCA. 8 1 VCCA B-Port Supply Voltage. 2.3V≤VCCB≤5.5V. Output Enable (Active High). Pull OE low to place all outputs in 3-state mode. Referenced to VCCA. Ground. A-Port Supply Voltage. 1.65V≤VCCA≤5.5V and VCCA≤VCCB. REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 2 BCT0102 2-Bit Bidirectional Voltage-Level Translator ABSOLUTE MAXIMUM RATINGS VCCA, Supply Voltage Range....................................................................................................................... -0.3V to 6V VCCB, Supply Voltage Range....................................................................................................................... -0.3V to 6V VI, A Port, B Port, OE Input Voltage Range (2)........................................................................................... -0.3V to 6V VO, Voltage Range Applied to Any Output in the High- Impedance or Power-Off State (2) A Port....................................................................................................................................................... -0.3V to 6V B Port....................................................................................................................................................... -0.3V to 6V VO, Voltage Range Applied to Any Output in the High or Low State (2) (3) A Port........................................................................................................................................... -0.3V to VCCA + 0.3V B Port........................................................................................................................................... -0.3V to VCCB + 0.3V IIK, Input Clamp Current (VI < 0) ....................................................................................................................... -50mA IOK, Output Clamp Current (VO < 0) ................................................................................................................. -50mA IO, Continuous Output Current.......................................................................................................................... ±50mA Continuous Current through VCCA, VCCB, or GND...................................................................................… ±100mA Operating Temperature Range............................................................................................................. -40℃ to +85℃ Junction Temperature.......................................................................................................................................... 150℃ Storage Temperature Range.............................................................................................................. -65℃ to +150℃ Lead Temperature (Soldering, 10sec)................................................................................................................. 260℃ ESD HBM B Port............................................................................................................................................................8KV HBM Other Pin.......................................................................................................................................................4KV NOTE: 1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute Maximum rating conditions for extended periods may affect device reliability. 2. The input and output negative-voltage ratings may be exceeded if the input and output current ratings are observed. 3. The value of VCCA and VCCB are provided in the recommended operating conditions table. REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 3 BCT0102 2-Bit Bidirectional Voltage-Level Translator ELECTRICAL CHARACTERISTICS (VCCA = 1.65V to 5.5V, VCCB = 2.3V to 5.5V, typical values are at TA = +25℃, unless otherwise noted) PARAMETER CONDITIONS RECOMMENDED OPERATING CONDITIONS Supply Voltage (3) MIN TYP MAX UNITS (1) (2) VCCA 1.65 5.5 VCCB 2.3 5.5 VCCA = 1.65V to 1.95V, VCCB = 2.3V to 5.5V VCCI - 0.2 VCCI VCCA = 2.3V to 5.5V, VCCB = 2.3V to 5.5V VCCI - 0.4 VCCI B Port I/Os VCCI - 0.4 VCCI OE Input VCCA×0.8 5.5 A Port I/Os 0 0.15 B Port I/Os 0 0.15 OE Input 0 VCCA×0.25 V A Port I/Os High-Level Input Voltage (VIH) V Low-Level Input Voltage V (VIL) Input Transition Rise or Fall Rate (Δt/ΔV) A Port I/Os Push-Pull Driving 10 B Port I/Os Push-Pull Driving 10 Control Input 10 ns/V ELECTRICAL CHARACTERISTICS A Port High Level Output Voltage (VOHA) IOH = -20µA, VIB ≥VCCB - 0.4V A Port Low Level Output Voltage (VOLA) IOL = 1mA, VIB ≤ 0.15V B Port High Level Output Voltage (VOHB) IOH = -20µA, VIA ≥VCCA - 0.4V B Port Low Level Output Voltage (VOLB) IOL = 1mA, VIA ≤ 0.15V Input Leakage Current (II) VCCA×0.7 0.4 V VCCB×0.7 OE 0.4 0.5 Power Off Leakage A Port VCCA = 0V, VCCB = 0V to 5.5V 0.1 Current (IOFF) B Port VCCA = 0V to 5.5V, VCCB = 0V 0.1 OE = 0V 0.1 3-State Output Leakage (IOZ) A or B Port μA VCCA = 1.65V to VCCB, VCCB 0.1 VI = VO = OPEN, = 2.3V to 5.5V IO = 0 VCCA =5.5V, VCCB = 0V 0.1 VCCA = 0V, VCCB = 5.5V 0.1 Quiescent Supply Current (ICCA) VCCA = 1.65V to VCCB, VCCB Quiescent Supply Current (ICCB) Quiescent Supply Current (ICCA + ICCB) μA 7 VI = VO = OPEN, = 2.3V to 5.5V IO = 0 VCCA =5.5V, VCCB = 0V 0.1 VCCA = 0V, VCCB = 5.5V 0.1 μA VI = VO = OPEN, VCCA = 1.65V to VCCB, VCCB IO = 0 = 2.3V to 5.5V μA 7.1 REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 4 BCT0102 2-Bit Bidirectional Voltage-Level Translator ELECTRICAL CHARACTERISTICS (VCCA = 1.65V to 5.5V, VCCB = 2.3V to 5.5V, typical values are at TA = +25℃, unless otherwise noted) PARAMETER CONDITIONS MIN VCCA = 1.65V to VCCB, Quiescent Supply Current (ICCZA) TYP MAX UNITS 0.1 VI = VCCI, IO = 0, VCCB = 2.3V to 5.5V OE = GND VCCA =5.5V, VCCB = 0V 0.1 VCCA = 0V, VCCB = 5.5V 0.1 μA VCCA = 1.65V to VCCB, 0.1 VI = VCCI, IO = 0, VCCB = 2.3V to 5.5V OE = GND VCCA =5.5V, VCCB = 0V 0.1 VCCA = 0V, VCCB = 5.5V 0.1 μA Quiescent Supply Current (ICCZB) OE Input Capacitance (CI) VCCA = 3.3V, VCCB = 3.3V Input/Output Capacitance A Port (CIO) 3.6 pF 5.4 VCCA = 3.3V, VCCB = 3.3V Input/Output Capacitance B Port (CIO) pF 6.3 NOTES: 1. VCCI is the VCC associated with the input port. 2. VCCO is the VCC associated with the output port. 3. VCCA must be less than or equal to VCCB, and VCCA must not exceed 5.5V. REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 5 BCT0102 2-Bit Bidirectional Voltage-Level Translator TIMING REQUIREMENTS (typical values are at TA = +25℃, unless otherwise noted) VCCB = 2.5V VCCB = 3.3V VCCB = 5V TYP TYP TYP Push-Pull Driving 21 22 24 Open-Drain Driving 2 2 2 47 45 41 500 500 500 20 22 24 2 2 2 50 45 41 500 500 500 23 24 2 2 43 41 500 500 UNITS (TA = +25℃ , VCCA = 1.8V, unless otherwise noted.) Data Rate Mbps Push-Pull Driving Pulse Duration (tW) Data Inputs Open-Drain Driving ns (TA = +25℃, VCCA = 2.5V, unless otherwise noted.) Push-Pull Driving Data Rate Mbps Open-Drain Driving Push-Pull Driving Pulse Duration (tW) Data Inputs Open-Drain Driving ns (TA = +25℃, VCCA = 3.3V, unless otherwise noted.) Push-Pull Driving Data Rate Mbps Open-Drain Driving Push-Pull Driving Pulse Duration (tW) Data Inputs Open-Drain Driving ns (TA = +25℃, VCCA = 5V, unless otherwise noted.) Push-Pull Driving 24 Data Rate Mbps Open-Drain Driving 2 Push-Pull Driving Pulse Duration (tW) 41 Data Inputs Open-Drain Driving ns 500 REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 6 BCT0102 2-Bit Bidirectional Voltage-Level Translator SWITCHING CHARACTERISTICS (VCCA = 1.8V, typical values are at TA = +25℃, unless otherwise noted) FROM TO TEST (INPUT) (OUTPUT) CONDITIONS PARAMETER tPHL A VCCB = 3.3V VCCB = 5V Push-Pull Driving 2.4 3.0 4.3 Open-Drain Driving 26.0 26.3 26.7 Push-Pull Driving 4.0 3.6 3.5 Open-Drain Driving 175 145 110 Push-Pull Driving 2.0 1.9 2.1 Open-Drain Driving 26.0 26.1 26.2 Push-Pull Driving 1.7 1.5 1.4 Open-Drain Driving 133 69 51 B tPLH tPHL B VCCB = 2.5V UNITS ns A ns tPLH tEN (tPZH & tPZL) OE A or B 17 15 14 tDIS (tPHZ & tPLZ) OE A or B 614 616 626 Push-Pull Driving 6.6 5.8 5.4 Open-Drain Driving 89 31 10 Push-Pull Driving 5.6 4.6 3.9 Open-Drain Driving 128 98 58 Push-Pull Driving 2.9 2.7 2.6 Open-Drain Driving 1.9 1.7 1.6 Push-Pull Driving 4.6 5.9 8.0 Open-Drain Driving 2.2 2.3 2.9 0.5 0.5 0.5 Push-Pull Driving 21 22 24 Open-Drain Driving 2 2 2 ns trA A Port Rise Time trB B Port Rise Time tfA ns A Port Fall Time tfB tsk(0) ns ns B Port Fall Time ns Channel-to-Channel Skew Data Rate Mbps REV2.4 www.broadchip.com ns Copyright © BROADCHIP TECHNOLOGY CO., LTD 7 BCT0102 2-Bit Bidirectional Voltage-Level Translator SWITCHING CHARACTERISTICS (VCCA = 2.5V, typical values are at TA = +25℃, unless otherwise noted) FROM TO TEST (INPUT) (OUTPUT) CONDITIONS PARAMETER VCCB = 2.5V VCCB = 3.3V VCCB = 5V Push-Pull Driving 2.7 3.3 4.8 Open-Drain Driving 26.2 26.4 26.7 Push-Pull Driving 2.6 2.4 2.3 Open-Drain Driving 169 144 110 Push-Pull Driving 2.4 2.3 2.4 Open-Drain Driving 26.3 26.4 26.5 Push-Pull Driving 2.0 1.9 1.8 Open-Drain Driving 165 118 55 UNITS tPHL A B ns tPLH tPHL B A ns tPLH tEN (tPZH & tPZL) OE A or B 14 13 12 tDIS (tPHZ & tPLZ) OE A or B 630 635 640 Push-Pull Driving 3.2 2.8 2.6 Open-Drain Driving 120 70 10 Push-Pull Driving 4.5 3.4 2.6 Open-Drain Driving 122 96 62 Push-Pull Driving 4.9 5.0 4.8 Open-Drain Driving 2.0 1.9 1.7 Push-Pull Driving 4.8 6.1 8.3 Open-Drain Driving 1.9 2.1 2.7 0.5 0.5 0.5 Push-Pull Driving 20 22 24 Open-Drain Driving 2 2 2 ns trA A Port Rise Time trB B Port Rise Time tfA ns A Port Fall Time tfB tsk(0) ns ns B Port Fall Time ns Channel-to-Channel Skew ns Data Rate Mbps REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 8 BCT0102 2-Bit Bidirectional Voltage-Level Translator SWITCHING CHARACTERISTICS (VCCA = 3.3V, typical values are at TA = +25℃, unless otherwise noted) FROM TO (INPUT) (OUTPUT) PARAMETER TEST CONDITIONS 3.5 4.9 Open-Drain Driving 26.3 26.7 Push-Pull Driving 2.2 2.0 Open-Drain Driving 133 104 Push-Pull Driving 3.0 3.2 Open-Drain Driving 26.6 26.8 Push-Pull Driving 1.8 1.7 Open-Drain Driving 132 83 UNITS B ns tPLH tPHL B VCCB = 5V Push-Pull Driving tPHL A VCCB = 3.3V A ns tPLH tEN (tPZH & tPZL) OE A or B 12 11 tDIS (tPHZ & tPLZ) OE A or B 630 635 Push-Pull Driving 2.2 2.0 Open-Drain Driving 87 36 Push-Pull Driving 2.9 2.3 Open-Drain Driving 87 56 Push-Pull Driving 6.2 5.8 Open-Drain Driving 2.3 2.0 Push-Pull Driving 6.5 8.2 Open-Drain Driving 2.0 2.5 0.5 0.5 Push-Pull Driving 23 24 Open-Drain Driving 2 2 ns trA trB tfA tfB tsk(0) A Port Rise Time ns B Port Rise Time ns A Port Fall Time ns B Port Fall Time ns Channel-to-Channel Skew ns Data Rate Mbps REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 9 BCT0102 2-Bit Bidirectional Voltage-Level Translator SWITCHING CHARACTERISTICS (VCCA = 5.0V, typical values are at TA = +25℃, unless otherwise noted) FROM TO TEST (INPUT) (OUTPUT) CONDITIONS PARAMETER tPHL A VCCB = 5V Push-Pull Driving 5.4 Open-Drain Driving 26.7 Push-Pull Driving 1.9 Open-Drain Driving 120 Push-Pull Driving 5.6 Open-Drain Driving 27.3 Push-Pull Driving 1.7 Open-Drain Driving 126 UNITS B ns tPLH tPHL B A ns tPLH tEN (tPZH & tPZL) OE A or B 10 tDIS (tPHZ & tPLZ) OE A or B 636 ns trA trB tfA tfB tsk(0) Push-Pull Driving 1.8 Open-Drain Driving 79 Push-Pull Driving 2.2 Open-Drain Driving 73 Push-Pull Driving 8.7 Open-Drain Driving 2.7 Push-Pull Driving 8.6 Open-Drain Driving 2.4 A Port Rise Time ns B Port Rise Time ns A Port Fall Time ns B Port Fall Time ns Channel-to-Channel Skew 0.5 Push-Pull Driving 24 Open-Drain Driving 2 ns Data Rate Mbps REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 10 BCT0102 2-Bit Bidirectional Voltage-Level Translator APPLICATION INFORMATION The BCT0102 can be used to bridge the digital-switching compatibility gap between two voltage nodes to successfully interface logic threshold levels found in electronic systems. It should be used in a point-to-point topology for interfacing devices or systems operating at different interface voltages with one another. Its primary target application use is for interfacing with open-drain drivers on the data I/Os such as I2C or 1-wire, where the data is bidirectional and no control signal is available. The BCT0102 can also be used in applications where a push-pull driver is connected to the data I/Os Block Diagram The BCT0102 architecture (see Figure 1) is an auto-direction-sensing based translator that does not require a direction-control signal to control the direction of data flow from A to B or from B to A. These two bidirectional channels independently determine the direction of data flow without a direction-control signal. Each I/O pin can be automatically reconfigured as either an input or an output, which is how this auto-direction feature is realized. VCCA VCCB T1 R1 10KΩ One shot One shot T2 Gate Bias R2 10KΩ B A N Figure 1 Block Diagram of BCT0102 I/O Cell REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 11 BCT0102 2-Bit Bidirectional Voltage-Level Translator The BCT0102 employs two key circuits to enable this voltage translation: An N-channel pass-gate transistor topology that ties the A port to the B port. Output one-shot (O.S.) edge-rate accelerator circuitry to detect and accelerate rising edges on the A or B ports. Input Driver Requirements The fall time (tfA, tfB) of a signal depends on the output impedance of the external device driving the data I/Os of the BCT0102. Similarly, the tPHL and data rates also depend on the output impedance of the external driver. The values for tfA, tfB, tPHL, and data rates in the datasheet assume that the output impedance of the external driver is less than 50Ω. Power Up During operation, ensure that V CCA ≤ VCCB at all times. The sequencing of each power supply will not damage the device during the power up operation, so either power supply can be ramped up first. Output Load Considerations We recommend careful PCB layout practices with short PCB trace lengths to avoid excessive capacitive loading and to ensure that proper O.S. triggering takes place. PCB signal trace-lengths should be kept short enough such that the round trip delay of any reflection is less than the one-shot duration. This improves signal integrity by ensuring that any reflection sees a low impedance at the driver. The O.S. circuits have been designed to stay on for approximately 30ns. The maximum capacitance of the lumped load that can be driven also depends directly on the one-shot duration. With very heavy capacitive loads, the one-shot can time-out before the signal is driven fully to the positive rail. The O.S. duration has been set to best optimize trade-offs between dynamic ICC, load driving capability, and maximum bit-rate considerations. Both PCB trace length and connectors add to the capacitance that the BCT0102 output sees, so it is recommended that this lumped-load capacitance be considered to avoid O.S. retriggering, bus contention, output signal oscillations, or other adverse system-level affects. REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 12 BCT0102 2-Bit Bidirectional Voltage-Level Translator Enable and Disable The BCT0102 has an OE input that is used to disable the device by setting OE low, which places all I/Os in the Hi-Z state. OE has an internal pull-down current source, as long as VCCA is powered. The disable time (tDIS) indicates the delay between the time when OE goes low and when the outputs are disabled (Hi-Z). The enable time (tEN) indicates the amount of time the user must allow for the one-shot circuitry to become operational after OE is taken high. Pull-up or Pull-down Resistors on I/O Lines Each A port I/O has an internal 10kΩ pull-up resistor to VCCA, and each B port I/O has an internal 10kΩ pull-up resistor to VCCB. If a smaller value of pull-up resistor is required, an external resistor must be added from the I/O to VCCA or VCCB (in parallel with the internal 10kΩ resistors). Adding lower value pull-up resistors will effect VOL levels, however. The internal pull-ups of the BCT0102 are disabled when the OE pin is low. Typical Application Circuit Figure 2 Typical Application Circuit REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 13 BCT0102 2-Bit Bidirectional Voltage-Level Translator Test Circuits Figure 3 Load Circuits and Voltage Waveforms REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 14 BCT0102 2-Bit Bidirectional Voltage-Level Translator PACKAGE OUTLINE DIMENSIONS TSOT23-8 Outline Drawing REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 15 BCT0102 2-Bit Bidirectional Voltage-Level Translator XTDFN1.4X1.0-8L Outline Drawing REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 16 BCT0102 2-Bit Bidirectional Voltage-Level Translator QFN1.4X1.2-8L Outline Drawing REV2.4 www.broadchip.com Copyright © BROADCHIP TECHNOLOGY CO., LTD 17
BCT0102ETA-TR 价格&库存
很抱歉,暂时无法提供与“BCT0102ETA-TR”相匹配的价格&库存,您可以联系我们找货
BCT0102ETA-TR
    • 1+1.57780
