SL05N06A
N-Channel Enhancement Mode Field Effect Transistor
Product Summary
● VDS
● ID
● RDS(ON)( at VGS=10V)
● RDS(ON)( at VGS=4.5V)
60V
5.0A
<100 mohm
<120 mohm
General Description
● Trench Power MV MOSFET technology
● Excellent package for heat dissipation
● High density cell design for low RDS(ON)
Applications
● DC-DC Converters
● Power management functions
■ Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Limit
Drain-source Voltage
VDS
60
V
Gate-source Voltage
VGS
±20
V
Drain Current
ID
5.0
A
Pulsed Drain Current A
IDM
12
A
Total Power Dissipation @ TC=25℃
PD
1.2
W
RθJA
105
℃/ W
TJ ,TSTG
-55~+150
Thermal Resistance Junction-to-Ambient
B
Junction and Storage Temperature Range
www.slkormicro.com
1
Unit
SL05N06A
■ Electrical Characteristics (TJ=25℃ unless otherwise noted)
Parameter
Symbol
Conditions
Min
Typ
Max
Units
Drain-Source Breakdown Voltage
BVDSS
VGS= 0V, ID=250μA
60
Zero Gate Voltage Drain Current
IDSS
VDS=60V,VGS=0V
1
μA
IGSS1
VGS= ±20V, VDS=0V
±100
nA
IGSS2
VGS= ±10V, VDS=0V
±50
nA
Gate Threshold Voltage
VGS(th)
VDS= VGS, ID=250μA
1.7
2.5
V
VGS= 10V, ID=3A
65
100
Static Drain-Source On-Resistance
RDS(ON)
VGS= 4.5V, ID=1.5A
78
120
IS=3.0A,VGS=0V
0.8
1.2
V
3.0
A
Static Parameter
V
Gate-Body Leakage Current
Diode Forward Voltage
Maximum Body-Diode Continuous Current
1.0
mΩ
VSD
IS
Dynamic Parameters
Input Capacitance
Ciss
330
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
17
Total Gate Charge
Qg
5.1
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
1.7
Turn-on Delay Time
tD(on)
13
Turn-on Rise Time
tr
VDS=30V,VGS=0V,f=1MHZ
90
pF
Switching Parameters
VGS=10V,VDS=30V,ID=3.0A
1.3
51
VGS=10V,VDD=30V, ID=1.5A,RL=1Ω
RGEN=3Ω
Turn-off Delay Time
Turn-off fall Time
A.
B.
ns
tD(off)
19
tf
12
Pulse Test: Pulse Width≤300us,Duty cycle ≤2%.
Device mounted on FR-4 PCB, 1 inch x 0.85 inch x 0.062 inch.
www.slkormicro.com
nC
2
SL05N06A
■ Typical Performance Characteristics
Figure1. Output Characteristics
Figure2. Transfer Characteristics
Figure3. Capacitance Characteristics
Figure4. Gate Charge
Figure5. Drain-Source on Resistance
www.slkormicro.com
Figure6. Drain-Source on Resistance
3
SL05N06A
Figure7. Safe Operation Area
www.slkormicro.com
Figure8. Switching wave
4
SL05N06A
■ SOT-223 Package information
Symbol
A
A1
A2
b
b1
c
D
E
E1
e
L
θ
■ SOT-223 Suggested Pad Layout
www.slkormicro.com
5
Dimensions In Millimeters
Min.
Max.
1.800
0.020
0.100
1.500
1.700
0.660
0.840
2.900
3.100
0.230
0.350
6.300
6.700
6.700
7.300
3.300
3.700
2.300(BSC)
0.750
0°
10°
Dimensions In Inches
Min.
Max.
0.071
0.001
0.004
0.059
0.067
0.026
0.033
0.114
0.122
0.009
0.014
0.248
0.264
0.264
0.287
0.130
0.146
0.091(BSC)
0.030
0°
10°
很抱歉,暂时无法提供与“SL05N06A”相匹配的价格&库存,您可以联系我们找货
