WSF30150A
N-Ch MOSFET
General Description
Product Summery
The WSF30150A is the highest performance trench
N-Ch MOSFET with extreme high cell density ,
which provide excellent RDSON and gate charge for
most of the synchronous buck converter
applications .
BVDSS
RDSON
ID
30V
2.2mΩ
145A
Applications
The WSF30150A meet the RoHS and Green
Product requirement , 100% EAS guaranteed with full
function reliability approved.
z High Frequency Point-of-Load Synchronous
Buck Converter
z Networking DC-DC Power System
Features
z Power Tool Application
Advanced high cell density Trench technology
Super Low Gate Charge
Excellent CdV/dt effect decline
TO-252 Pin Configuration
100% EAS Guaranteed
Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=100℃
IDM
Rating
Units
Drain-Source Voltage
30
V
Gate-Source Voltage
±20
V
1,7
145
A
1,7
75
A
310
A
372
mJ
86
A
78
W
Continuous Drain Current, VGS @ 10V
2
Pulsed Drain Current
EAS
Single Pulse Avalanche Energy
IAS
Avalanche Current
3
4
PD@TC=25℃
Total Power Dissipation
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
Unit
55
1.6
℃/W
℃/W
Rev 1: May.2021
WSF30150A
N-Ch MOSFET
Electrical Characteristics (TJ=25°C, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
Reference to 25℃ , ID=1mA
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS=0V , ID 250uA
Typ.
Max.
Unit
V
0.022
V/℃
VGS=10V , ID=20A
2.2
3.5
VGS=4.5V , ID=15A
3.1
4.2
1.2
1.6
2.5
V
-6.1
mV/℃
VDS=24V , VGS=0V , TJ=25℃
2
VDS=24V , VGS=0V , TJ=55℃
10
VGS=VDS , ID =250uA
VGS(th) Temperature Coefficient
Min.
30
mΩ
uA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forwar Trd
VDS=5V , ID=15A
32
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.1
2.5
Ω
Qg
Total Gate Charge (4.5V)
22
4.3
8.3
Qgs
Qgd
ansconductance
VDS=15V , VGS=4.5V , ID=20A
Gate-Source Charge
Gate-Drain Charge
Td(on)
Turn-On Delay Time
16
Tr
Rise Time Rise Time
VDD=15V , VGEN=10V , RG=6Ω,
11
Td(off)
Turn-Off Delay Time
ID=1A, RL=15Ω.
35
nC
ns
Tf
Turn-Off Fall Time
40
Ciss
Input Capacitance
2450
Coss
Output Capacitance
590
Crss
Reverse Transfer Capacitance
245
Min.
Typ.
Max.
Unit
85
mJ
Min.
VDS=15V , VGS=0V , f=1MHz
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=15A
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Conditions
1,6
Continuous Source Current
Pulsed Source Current2,6
2
Diode Forward Voltage
VG=VD=0V , Force Current
VGS=0V , IS=20A , TJ=25℃
Typ.
Max.
Unit
50
A
310
A
1.2
V
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSF30150A”相匹配的价格&库存,您可以联系我们找货
