1N4001 THRU 1N4007
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT GENERAL RECTIFIER
Features
PINNING
1
Cathode
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
2
Anode
Idea for printed circuit board
PIN
DESCRIPTION
Glass passivated Junction chip
Low reverse leakage
High forward surge current capability
DO-214AC/SMA
High temperature soldering guaranteed
250 C/10 seconds at terminals
2
1
Mechanical Data
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0023 ounce, 0.07 grams
Unipolar
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
1N4001 1N4002 1N4003 1N4004 1N4005 1N4006 1N4007
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=110℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
VRRM
VRMS
VDC
M1
M2
M3
M4
M5
M6
M7
50
35
50
100
70
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
1.0
A
IFSM
30
A
VF
1.1
V
5
50
15.0
IR
CJ
RθJA
75.0
TJ,TSTG
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.tw-gmc.com
100
UNITS
1
uA
pF
℃/W
1N4001 THRU 1N4007
Fig.2 Typical Instaneous Reverse
Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current ( μ A)
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
175
100
T J =150°C
10
T J =125°C
T J =100°C
1.0
T J =75°C
0.1
T J =25°C
0.01
Junction Capacitance ( pF)
TJ =
2 5°
C
00
=1
TJ
=1
25
°C
°C
0.5
TJ
Instaneous Forward Current (A)
1.0
0.9
0.2
1.0
1.1
Peak Forward Surage Current (A)
T J =25°C
10
30
25
10
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
1.0
10
Reverse Voltage (V)
35
100
Number of Cycles
www.tw-gmc.com
100
0.1
Fig.5 Maximum Non-Repetitive Peak
1
800
1
0.7
Instaneous Forward Voltage (V)
05
600
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.8
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
0.1
0.6
2
100
1N4001 THRU 1N4007
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
2.4
(94)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
www.tw-gmc.com
3
a
0.3
12
很抱歉,暂时无法提供与“1N4001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.03560
- 100+0.03260
- 500+0.02960
- 1000+0.02660
- 2000+0.02460
- 4000+0.02400
