High Voltage 2-Electrode Gas Discharge Tube (GDT)
UN2E5 Series
UN2E5-XXXDL
Description
UN2E5-XXXD
The high voltage (1.0- 3.5KV) gas discharge tubes are designed for
surge protection
and
high isolation
applications,
and
for
applications for which bias voltages or signal levels of several
hundred volts are normally present.
Schematic Symbol
Agency Approvals
Features
u
Non-Radioactive
u
RoHS compliant
u
Low insertion loss
u
Excellent response to fast rising transients
u
Ultra low capacitance
u
2.5KA surge capability tested with 8/20μs pulse as defined by
IEC 61000-4-5
Product Characteristics
Materials
UNION XXXXD
Applications
u
u
u
u
u
Product Marking
CRT terminals
CATV equipment
Antennas
Power supplies
Medical electronics
< 0.5Amps
Glow Voltage
~180 Volts
Storage and
Operational
Temperature
-40 to +90°C
Climatic category
(IEC 60068-1)
SOCAY Electronics Co., Ltd.
XXXX -Nominal voltage
D
-2.5KA
Glow to Arc
Transition Current
Weight
Revision March 6, 2014
Nickel-plated with Tinplated wires
UN2E5-XXXDL
~1.0g
UN2E5-XXXD
~0.85g
40/ 90/ 21
www.socay.com
1/4
@SOCAY Electronics Co., Ltd. 2014
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
UN2E5 Series
Dimensions
(Unit: mm)
Axial Leaded Devices (UN2E5-XXXDL)
Without wire Devices (UN2E5-XXXD)
Electrical Characteristics
Service Life
Part Number
Marking
DC
Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
@100V/S
@100V/μs
@1KV/μs
Minimum
Insulation
Resistance
Maximum
Arc
Capacitance Voltage
Nominal
Impulse
Discharge
Current
Max
Impulse
Discharge
Current
@1MHz
@1A
@8/20μs
±5 times
@8/20μs
1 time
UN2E5-1000DL
UN2E5-1000D
1000D
1000V±20%
<1500V
<1600V
1 GΩ
(at 100V)
<1.0pF
~25V
2.5KA
5KA
UN2E5-1600DL
UN2E5-1600D
1600D
1600V±20%
<2200V
<2400V
1 GΩ
(at 100V)
<1.0pF
~25V
2.5KA
5KA
UN2E5-2000DL
UN2E5-2000D
2000D
2000V±20%
<3000V
<3500V
1 GΩ
(at 100V)
<1.0pF
~25V
2.5KA
5KA
UN2E5-2500DL
UN2E5-2500D
2500D
2500V±20%
<3800V
<4000V
1 GΩ
(at 100V)
<1.0pF
~25V
2.5KA
5KA
UN2E5-2700DL
UN2E5-2700D
2700D
2700V±20%
<3800V
<4000V
1 GΩ
(at 100V)
<1.0pF
~25V
2.5KA
5KA
UN2E5-3000DL
UN2E5-3000D
3000D
3000V±20%
<4300V
<4500V
1 GΩ
(at 100V)
<1.0pF
~25V
2.5KA
5KA
UN2E5-3500DL
UN2E5-3500D
3500D
3500V±20%
<4800V
<5000V
1 GΩ
(at 100V)
<1.0pF
~25V
2.5KA
5KA
Notes:
1). Terms in accordance with ITU-T K.12 and GB/T 9043-2008
2). At delivery AQL 0.65 level Ⅱ, DIN ISO 2859
www.socay.com
2/4
UN2E5 Series
Electrical Rating
Item
Test Condition / Description
DC Spark-over Voltage
Impulse Spark-over
Voltage
The voltage is measured with a slowly rate of rise dv / dt=100V/s
The maximum impulse spark-over voltage is measured with a rise time of
dv / dt=100V//μs or 1KV/μs
Insulation Resistance
Capacitance
Requirement
The resistance of gas tube shall be measured each terminal each other terminal,
please see above spec.
The capacitance of gas tube shall be measured each terminal to each other
terminal.
Test frequency :1MHz
The maximum current applying a waveform of 8/20μs that can be applied across
the terminals of the gas tube. One hour after the test is completed, re-testing of the
DC spark-over voltage does not exceed ±30% of the nominal DC spark-over
voltage. Dwell time between pulses is 3 minutes.
I
To meet
the specified
value
1.0
0.9
Nominal Impulse
Discharge Current
0.5
0.1
0.0
8μsec
20μsec
30% Max
T
Recommended soldering profile
Reflow soldering
Wave soldering
Soldering profile applied a single process
Soldering Parameters - Hand Soldering
Solder Iron Temperature: 350°C +/-5°C
Heating Time: 5 seconds max.
www.socay.com
3/4
UN2E5 Series
Part Numbering
UN2E5 – XXX D L
L,
No,
with axial wire
without wire
8/20μs Level
D, 2.5KA
Nominal DC Spark-over Voltage
1000 = 1000V
3000=3000V
1600 = 1600V
3500=3500V
2000 = 2000V
2500 = 2500V
Series
Packaging Information
Part Number
Unit: mm
Description
Quantity
UN2E5-XXXDL
100PCS per Tray, 10 Trays / Inner Carton
1000
UN2E5-XXXD
1000
Tray used in UN2E5-XXXDL
Cautions and warnings
u
Gas discharge tubes (GDT) must not be operated directly in power supply networks.
u
Gas discharge tubes (GDT) may become hot in case of longer periods of current stress (danger of burning).
u
Gas discharge tubes (GDT) may be used only within their specified values. In the event of overload, the head contacts may
fail or the component may be destroyed.
u
Damaged Gas discharge tubes (GDT) must not be re-used.
www.socay.com
4/4
很抱歉,暂时无法提供与“SC2E5-3000DL”相匹配的价格&库存,您可以联系我们找货
