IRF3205STRPBF
www.VBsemi.com
N-Channel 60 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS
60
RDS(on) VGS = 10 V
4
V
m
Configuration
• Package with low thermal resistance
A
150
ID
• TrenchFET® power MOSFET
• 100 % Rg and UIS tested
Single
TO-263
D
G
Top View
G
D
S
N-Channel MOSFET
S
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
SYMBOL
VDS
LIMIT
Drain-Source Voltage
PARAMETER
Gate-Source Voltage
VGS
± 20
Continuous Drain Current
TC = 25 °C a
ID
TC = 125 °C
Continuous Source Current (Diode Conduction) a
Pulsed Drain Current
b
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
Maximum Power Dissipation b
IDM
350
65
PD
TC = 125 °C
Operating Junction and Storage Temperature Range
V
65
120
EAS
TC = 25 °C
UNIT
150
IS
IAS
L = 0.1 mH
60
211
220
70
A
mJ
W
TJ, Tstg
-55 to +175
°C
SYMBOL
RthJA
LIMIT
UNIT
RthJC
0.65
THERMAL RESISTANCE RATINGS
PARAMETER
Junction-to-Ambient
Junction-to-Case (Drain)
PCB Mount
c
40
°C/W
Notes
a. Package limited.
b. Pulse test; pulse width 300 μs, duty cycle 2 %.
c. When mounted on 1" square PCB (FR4 material).
服务热线:400-655-8788
1
IRF3205STRPBF
www.VBsemi.com
SPECIFICATIONS (TC = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
Static
Drain-Source Breakdown Voltage
Gate-Source Threshold Voltage
Zero Gate Voltage Drain Current
Drain-Source On-State Resistance a
Forward Transconductance
b
TYP.
VDS
VGS = 0, ID = 250 μA
60
VDS = VGS, ID = 250 μA
2.0
VDS = 0 V, VGS = ± 20 V
IDSS
ID(on)
On-State Drain Current a
MIN.
VGS(th)
IGSS
Gate-Source Leakage
TEST CONDITIONS
RDS(on)
gfs
MAX.
4.0
± 100
VGS = 0 V
VDS = 60 V
1
VGS = 0 V
VDS = 60 V, TJ = 125 °C
50
VGS = 0 V
VDS = 60 V, TJ = 175 °C
250
VGS = 10 V
VDS 5 V
120
VGS = 10 V
ID = 30 A
6
VGS = 10 V
ID = 30 A, TJ = 125 °C
12
VGS = 10 V
ID = 30 A, TJ = 175 °C
15
94
7000
96
360
145
24
VDS = 15 V, ID = 30 A
UNIT
V
nA
μA
A
m
S
Dynamic b
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge c
Gate-Source Charge
Qg
Qgs
c
Qgd
Gate-Drain Charge
Gate Resistance
Rg
Turn-On Delay Time c
td(on)
Rise Time c
tr
td(off)
Turn-Off Delay Time c
Fall Time c
VGS = 0 V
VDS = 25 V, f = 1 MHz
VGS = 10 V
VDS = 30 V, ID = 75 A
f = 1 MHz
VDD = 30 V, RL = 0.4 Ω
ID 75 A, VGEN = 10 V, Rg = 1 Ω
tf
Source-Drain Diode Ratings and Characteristics b
ISM
Pulsed Current a
Forward Voltage
VSD
IF = 75 A, VGS = 0
715
27
0.3
1
1.7
16
24
14
21
34
51
9
14
0.9
450
1.5
pF
nC
Ω
ns
A
V
Notes
a. Pulse test; pulse width 300 μs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
IRF3205STRPBF
www.VBsemi.com
TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted)
225
150
VGS = 10 V thru 7 V
200
120
150
ID - Drain Current (A)
175
VGS = 6 V
125
100
75
50
60
TC = 25 °C
30
VGS = 4 V
25
8
12
16
TC = 125 °C
TC = -55 °C
4
6
8
10
VGS - Gate-to-Source Voltage (V)
VDS - Drain-to-Source Voltage (V)
Transfer Characteristics
Output Characteristics
1.5
200
1.2
160
gfs - Transconductance (S)
TC = -55 °C
0.9
0.6
TC = 25 °C
0.3
0.0
TC = -55 °C
TC = 125 °C
4
6
8
TC = 25 °C
120
80
40
TC = 125 °C
0.020
10 000
0.016
8000
0.012
0.008
VGS = 10 V
6000
60
80
56
70
Ciss
4000
2000
0.004
Transconductance
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
0.000
28
100
On-Resistance vs. Drain Current
120
Coss
Crss
40
50
60
Capacitance
服务热线:400-655-8788
3
IRF3205STRPBF
www.VBsemi.com
2.1
RDS(on) - On-Resistance(Normalized)
10
ID = 110 A
VDS = 20 V
8
6
4
2
60
80
0.9
-50
-25
50
75 100 125 150 175
TJ - Junction Temperature (°C)
Gate Charge
On-Resistance vs. Junction Temperature
0.05
IS - Source Current (A)
1.2
Qg - Total Gate Charge (nC)
10
TJ = 150 °C
1
0.1
TJ = 25 °C
0.01
0.001
0.0
0.2
0.4
0.6
0.8
1.0
0.04
0.03
0.02
TJ = 150 °C
0.01
0.00
1.2
TJ = 25 °C
4
6
8
VSD - Source-to-Drain Voltage (V)
Source Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
10
80
0.2
-0.2
ID = 5 mA
-0.6
-1.0
ID = 250 μA
-1.4
-50
-25
50
75 100 125 150 175
0.6
VGS(th) Variance(V)
1.5
0.6
100
100
-1.8
ID = 10 A
VGS = 10 V
1.8
ID = 10 mA
77
74
71
68
65
-50
-25
50
75 100 125 150 175
TJ - Temperature (°C)
Threshold Voltage
Drain Source Breakdown vs. Junction Temperature
服务热线:400-655-8788
4
IRF3205STRPBF
www.VBsemi.com
THERMAL RATINGS (TA = 25 °C, unless otherwise noted)
1000
IDM Limited
ID Limited
100 μs
100
1 ms
10
1
0.1
0.01
0.01
10 ms
100 ms
1 s, 10 s, DC
Limited by R DS(on)*
BVDSS Limited
TC = 25 °C
Single Pulse
0.1
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
Normalized Effective Transient
Thermal Impedance
1
0.1
0.01
0.001
0.0001
10-4
10-3
10-2
10-1
1
10
100
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
服务热线:400-655-8788
5
IRF3205STRPBF
www.VBsemi.com
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10-1
1
Normalized Thermal Transient Impedance, Junction-to-Case
Note
• The characteristics shown in the two graphs
- Normalized Transient Thermal Impedance Junction-to-Ambient (25 °C)
- Normalized Transient Thermal Impedance Junction-to-Case (25 °C)
are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single
pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part
mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities
can widely vary depending on actual application parameters and operating conditions.
服务热线:400-655-8788
6
IRF3205STRPBF
www.VBsemi.com
TO-263 (D2PAK): 3-LEAD
L2
E1
K
6
D4
-A-
-Bc2
D2
D3
A
E
L3
L
D
D1
E3
A
A
b2
b
e
Detail “A”
c
E2
L4
0.010 M A M
2 PL
L1
DETAIL A (ROTATED 90°)
c*
c
c1
c1
M
b
b1
SECTION A-A
Notes
1. Plane B includes maximum features of heat sink tab and plastic.
2. No more than 25 % of L1 can fall above seating plane by max.
8 mils.
3. Pin-to-pin coplanarity max. 4 mils.
4. *: Thin lead is for SUB, SYB.
Thick lead is for SUM, SYM, SQM.
5. Use inches as the primary measurement.
6. This feature is for thick lead.
DIM.
A
b
b1
b2
Thin lead
Thick lead
Thin lead
Thick lead
c2
D
D1
D2
D3
D4
E
E1
E2
E3
e
K
L
L1
L2
L3
L4
M
INCHES
MILLIMETERS
MIN.
MAX.
0.160
0.190
0.020
0.039
0.020
0.035
0.045
0.055
0.013
0.018
0.023
0.028
0.013
0.017
0.023
0.027
0.045
0.055
0.340
0.380
0.220
0.240
0.038
0.042
0.045
0.055
0.044
0.052
0.380
0.410
0.245
0.355
0.375
0.072
0.078
0.100 BSC
0.045
0.055
0.575
0.625
0.090
0.110
0.040
0.055
0.050
0.070
0.010 BSC
0.002
MIN.
MAX.
4.064
4.826
0.508
0.990
0.508
0.889
1.143
1.397
0.330
0.457
0.584
0.711
0.330
0.431
0.584
0.685
1.143
1.397
8.636
9.652
5.588
6.096
0.965
1.067
1.143
1.397
1.118
1.321
9.652
10.414
6.223
9.017
9.525
1.829
1.981
2.54 BSC
1.143
1.397
14.605
15.875
2.286
2.794
1.016
1.397
1.270
1.778
0.254 BSC
0.050
ECN: T13-0707-Rev. K, 30-Sep-13
DWG: 5843
服务热线:400-655-8788
7
IRF3205STRPBF
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead
0.420
0.355
0.635
(16.129)
(9.017)
(10.668)
0.145
(3.683)
0.135
(3.429)
0.200
0.050
(5.080)
(1.257)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
8
IRF3205STRPBF
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS
compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 /
EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic
equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
