MOT2N65C
MOT2N65D
N-CHANNEL MOSFET
PRODUCT CHARACTERISTICS
VDSS
RDS(on)typ(@V GS =10 V)
Qg@type
ID
Symbol
650V
4.3Ω
12nC
2A
2.Drain
1.Gate
APPLICATIONS
* High efficiency switch mode power supplies
* Electronic lamp ballasts based on half bridge
* LED power supplies
3.Source
4
4
FEATURES
* Fast switching capability
* Avalanche energy specified
* Improved dv/dt capability, high ruggedness
1
2
1
3
2
3
TO-251
TO-252
ORDER INFORMATION
Order codes
Halogen-Free
Halogen
N/A
N/A
Package
Packing
2500 pieces /Reel
70 pieces /Tube
TO-252
TO-251
MOT2N65D
MOT2N65C
ABSOLUTE MAXIMUM RATINGS (TC = 25°С, unless otherwise specified)
SYMBOL
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
Avalanche Current (Note 2)
VDSS
VGSS
I AR
ID
IDM
EAS
dv/dt
Continuous
Pulsed (Note 2)
Avalanche Energy
Single Pulsed (Note 3)
Peak Diode Recovery dv/dt (Note 4)
Power Dissipation
TO-251/TO-252
Drain Current
RATINGS
650
±30
2.0
2.0
8.0
110
4.5
44
UNIT
V
V
A
A
A
mJ
V/ns
W
°С
°С
°С
PD
TJ
+150
Junction Temperature
-55 ~ +150
TOPR
Operating Temperature
TSTG
Storage Temperature
-55 ~ +150
Notes: 1. Absolute maximum ratings are those values beyond which the device could be permanently damaged.
Absolute maximum ratings are stress ratings only and functional device operation is not implied.
2. Repetitive Rating : Pulse width limited by TJ.
3. L=55mH, IAS=2.0A, VDD=50V, RG=25 Ω, Starting TJ = 25°C
4. ISD≤2.4A, di/dt≤200A/μs, VDD ≤ BVDSS, Starting TJ = 25°C
-1-
www.mot-mos.com
MOT2N65C
MOT2N65D
N-CHANNEL MOSFET
ELECTRICAL CHARACTERISTICS (TJ =25°С, unless otherwise specified)
PARAMETER
Off characteristics
Drain-Source Breakdown Voltage
Drain-Source Leakage Current
SYMBOL
BVDSS
IDSS
TEST CONDITIONS
MIN TYP MAX UNIT
VGS = 0V, ID = 250μA
650
VDS = 650V, VGS = 0V
Forward
VGS = 30V, VDS = 0V
Gate-Source Leakage Current
IGSS
Reverse
VGS = -30V, VDS = 0V
Breakdown Voltage Temperature Coefficient △BVDSS/△TJ ID=250μA, Referenced to 25°C
On characteristics
Gate Threshold Voltage
VGS(TH)
VDS = VGS, ID = 250μA
2.0
Static Drain-Source On-State Resistance
RDS(ON)
VGS = 10V, ID =1A
Dynamic characteristics
Input Capacitance
CISS
VDS =25V, VGS =0V,
Output Capacitance
COSS
f =1MHz
Reverse Transfer Capacitance
CRSS
Switching characteristics
Turn-On Delay Time
tD (ON)
VDD =30V, ID =0.5A,
Turn-On Rise Time
tR
RG=25Ω (Note 1, 2)
Turn-Off Delay Time
tD(OFF)
Turn-Off Fall Time
tF
Total Gate Charge
QG
VDS=50V, VGS=10V,
Gate-Source Charge
QGS
ID=1.3A (Note 1, 2)
Gate-Drain Charge
QGD
Drain-source diode characteristics
Drain-Source Diode Forward Voltage
VSD
VGS = 0 V, ISD = 2.0 A
Continuous Drain-Source Current
ISD
Pulsed Drain-Source Current
ISM
0.4
V
10
μA
100 nA
-100 nA
V/°С
4.3
4.0
6.0
V
Ω
240
35
4.6
pF
pF
pF
40
40
50
22
12
ns
ns
5.2
2
1.4
2.0
8.0
Notes: 1. Pulse Test: Pulse width ≤ 300μs, Duty cycle≤2%
2. Essentially independent of operating temperature
-2-
www.mot-mos.com
ns
ns
nC
nC
nC
V
A
A
MOT2N65C
MOT2N65D
N-CHANNEL MOSFET
TEST CIRCUITS AND WAVEFORMS
D.U.T.
VDS
L
RG
Driver
VGS
VDD
* dv/dt controlled by RG
* ISD controlled by pulse period
* D.U.T.-Device Under Test
Same Type
as D.U.T.
Peak Diode Recovery dv/dt Test Circuit
VGS
(Driver)
Period
P. W.
D=
P.W.
Period
VGS= 10V
IFM, Body Diode Forward Current
ISD
(D.U.T.)
di/dt
IRM
Body Diode Reverse Current
Body Diode Recovery dv/dt
VDS
(D.U.T.)
VDD
Body Diode
Forward Voltage Drop
Peak Diode Recovery dv/dt Waveforms
-3-
www.mot-mos.com
MOT2N65C
MOT2N65D
N-CHANNEL MOSFET
TEST CIRCUITS AND WAVEFORMS(Cont.)
VDS
90%
VGS
10%
tD(ON)
tD(OFF)
tF
tR
Switching Test Circuit
Switching Waveforms
VGS
QG
10V
QGS
QGD
Charge
Gate Charge Test Circuit
Gate Charge Waveform
BVDSS
IAS
ID(t)
VDS(t)
VDD
tp
Unclamped Inductive Switching Test Circuit
Time
Unclamped Inductive Switching Waveforms
-4-
www.mot-mos.com
MOT2N65C
MOT2N65D
N-CHANNEL MOSFET
TY PICAL CHARACTERISTICS
Drain Current vs. Drain-Source
Breakdown Voltage
Drain Current vs. Gate Threshold Voltage
300
250
Drain Current, ID (µA)
250
200
150
100
50
200
150
100
50
450
600 750
Drain-Source Breakdown Voltage, BVDSS (V)
Characteristics
Drain-Source Diode Forword
Current, ISD (A)
1.0
VGS=10V, ID=1A
0.8
0.6
0.4
0.2
1.2
1.8 2.4 3.0 3.6
Gate Threshold Voltage, VTH (V)
Drain-Source Diode Forword Current vs.
Source to Drain Voltage
2.4
1.2
Drain Current, ID (A)
300
2.0
1.6
1.2
0.8
0.4
2.1 2.8 3.5 4.2
Drain to Source Voltage, VDS (V)
-5-
0.2
0.4
0.6
0.8
1.0
Source to Drain Voltage, VSD (V)
www.mot-mos.com
MOT2N65C
MOT2N65D
N-CHANNEL MOSFET
n TO-251 PACKAGE OUTLINE DIMENSIONS
-6-
www.mot-mos.com
MOT2N65C
MOT2N65D
N-CHANNEL MOSFET
n TO-252 PACKAGE OUTLINE DIMENSIONS
-7-
www.mot-mos.com
很抱歉,暂时无法提供与“MOT2N65D”相匹配的价格&库存,您可以联系我们找货
