AP18P10GH-HF
www.VBsemi.com
P-Channel 100 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 100
RDS(on) (Ω)
ID (A)
0.100 at V GS = - 10 V
- 16
0.120 at VGS = - 4.5 V
- 15
Qg (Typ.)
11.7
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg and UIS Tested
• Compliant to RoHS Directive 2002/95/EC
APPLICATIONS
• Power Switch
• DC/DC Converters
S
TO-252
G
Drain Connected to Tab
G
D
S
D
Top View
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
- 100
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 150 °C)
TC = 25 °C
TC = 70 °C
IDM
Pulsed Drain Current
Avalanche Current
Single Avalanche Energya
Maximum Power Dissipationa
Operating Junction and Storage Temperature Range
ID
L = 0.1 mH
TC = 25 °C
TA = 25 °Cc
V
- 16
- 14
- 50
IAS
- 18
EAS
16.2
PD
Unit
32.1
A
mJ
b
2.5
W
TJ, Tstg
- 55 to 150
°C
Unit
THERMAL RESISTANCE RATINGS
Parameter
Symbol
Limit
Junction-to-Ambient (PCB Mount)c
RthJA
50
Junction-to-Case (Drain)
RthJC
3.9
°C/W
Notes:
a. Duty cycle ≤ 1 %.
b. See SOA curve for voltage derating.
c. When Mounted on 1" square PCB (FR-4 material).
服务热线:400-655-8788
1
AP18P10GH-HF
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
VDS
VDS = 0 V, ID = - 250 µA
- 100
VGS(th)
VDS = VGS, ID = - 250 µA
-1
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
IGSS
Gate-Body Leakage
Zero Gate Voltage Drain Current
On-State Drain Currenta
Drain-Source On-State Resistancea
Forward Transconductancea
IDSS
- 2.5
VDS = 0 V, VGS = ± 20 V
± 250
VDS = - 100 V, VGS = 0 V
-1
VDS = - 100 V, VGS = 0 V, TJ = 125 °C
- 50
VDS = - 100 V, VGS = 0 V, TJ = 150 °C
- 250
VDS ≤ - 10 V, VGS = - 10 V
ID(on)
RDS(on)
gfs
- 15
V
nA
µA
A
VGS = - 10 V, ID = - 3.6 A
0.100
VGS = - 4.5 V, ID = - 3.4 A
0.120
VDS = - 15 V, ID = - 3.6 A
12
Ω
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
Gate-Drain Chargec
Qgd
Rise Timec
VDS = - 50 V, VGS = - 10 V, ID = - 3.6 A
VDS = - 50 V, VGS = - 4.5 V, ID = - 3.6 A
Fall Timec
td(off)
pF
23.2
34.8
11.7
17.6
3.5
f = 1 MHz
VDD = - 50 V, RL = 17.2 Ω
ID ≅ - 2.9 A, VGEN = - 10 V, Rg = 1 Ω
tf
Drain-Source Body Diode Ratings and Characteristics TC = 25 °C
1.2
5.7
11.5
7
14
12
18
33
50
9
18
- 8.8
Pulsed Current
ISM
- 15
Forward Voltagea
VSD
Reverse Recovery Time
Peak Reverse Recovery Current
Reverse Recovery Charge
IF = - 2.9 A, VGS = 0 V
- 0.8
IF = - 2.9 A, dI/dt = 100 A/µs
98
trr
IRM(REC)
Qrr
Ω
ns
b
IS
Continuous Current
nC
4.8
td(on)
tr
c
65
41
Rg
Gate Resistance
Turn-On Delay Timec
Turn-Off Delay Time
1055
VGS = 0 V, VDS = - 50 V, f = 1 MHz
A
- 1.5
V
50
75
ns
-4
-6
A
147
nC
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
AP18P10GH-HF
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
50
0.25
V GS = 10 V thru 5 V
V GS = 4 V
R DS(on) - On-Resistance (Ω)
I D - Drain Current (A)
40
30
V GS = 3 V
10
0.20
0.15
V GS = 4.5 V
0.10
V GS = 10 V
2
3
4
6
V DS - Drain-to-Source Voltage (V)
12
15
ID - Drain Current (A)
Output Characteristics
On-Resistance vs. Drain Current
2.0
0.60
1.6
9
1.2
0.8
T C = 25 °C
0.4
0.45
T J = 150 °C
0.30
T J = 25 °C
0.15
T C = 125 °C
T C = - 55 °C
0.0
0.00
2
3
4
V GS - Gate-to-Source Voltage (V)
2
4
6
8
10
Transfer Characteristics
On-Resistance vs. Gate-to-Source Voltage
25
10
VGS - Gate-to-Source Voltage (V)
g fs - Transconductance (S)
ID = 3.6 A
T C = - 55 °C
15
T C = 25 °C
10
T C = 125 °C
5
V DS = 50 V
6
V DS = 25 V
4
V DS = 80 V
2
6
9
Transconductance
12
15
10
15
Qg - Total Gate Charge (nC)
Gate Charge
服务热线:400-655-8788
3
AP18P10GH-HF
www.VBsemi.com
100
- 1.1
I S - Source Current (A)
- 1.4
T J = 150 °C
ID = 250 μA
VGS(th) (V)
10
- 1.7
T J = 25 °C
1
- 2.0
0.1
0.0
0.3
0.6
0.9
- 2.3
- 50
1.2
50
75
V SD - Source-to-Drain Voltage (V)
T J - Temperature (°C)
Source-Drain Diode Forward Voltage
Threshold Voltage
100
125
150
100
125
150
- 100
1200
VDS - Drain-to-Source Voltage (V)
1600
C - Capacitance (pF)
- 25
Ciss
800
400
- 106
ID = 250 μA
- 112
- 118
- 124
Coss
Crss
60
80
- 130
- 50
100
- 25
50
75
TJ - Junction Temperature (°C)
Capacitance
Drain Source Breakdown vs. Junction Temperature
2.1
10
V GS = 10 V
ID = 3.6 A
V GS = 4.5 V
1.3
0.9
(Normalized)
8
1.7
6
4
2
0.5
- 50
50
75
100
125
150
50
75
100
T J - Junction Temperature (°C)
T C - Case Temperature (°C)
On-Resistance vs. Junction Temperature
Current Derating
125
150
服务热线:400-655-8788
4
AP18P10GH-HF
www.VBsemi.com
100
100
Limited by R DS(on)*
IDAV (A)
10
TJ = 25 °C
TJ = 150 °C
10
100 μs
1 ms
1
10 ms
100 ms
1 s, 10 s, DC
0.1
TA = 25 °C
Single Pulse
BVDSS Limited
1
10-6
10-5
10-4
10-3
10-2
10-1
Time (s)
Single Pulse Avalanche Current Capability vs. Time
0.01
0.1
1
10
100
* V GS > minimum VGS at which RDS(on) is specified
Safe Operating Area
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.05
0.1
10 -4
0.02
Single Pulse
10 -3
10 -2
10 -1
1
10
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
AP18P10GH-HF
www.VBsemi.com
TO-252AA Case Outline
E
C2
L3
H
D
b2
D1
e1
E1
L
gage plane height (0.5 mm)
e
L5
L4
b
C
A1
INCHES
MILLIMETERS
A
b3
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
0.024
C
0.46
0.61
0.018
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
4.10
0.161
E
6.35
6.73
0.250
0.265
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
e1
0.090 BSC
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.01
1.52
0.040
0.060
ECN: T16-0236-Rev. P, 16-May-16
DWG: 5347
Notes
• Dimension L3 is for reference only.
服务热线:400-655-8788
6
AP18P10GH-HF
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR DPAK (TO-252)
0.224
0.243
0.087
(2.202)
0.090
(2.286)
(10.668)
0.420
(6.180)
(5.690)
0.180
0.055
(4.572)
(1.397)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
服务热线:400-655-8788
7
AP18P10GH-HF
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
