FDD8770-VB
FDD8770-VB
    VBSEMI(微碧)
    TO252
    类型:N沟道;漏源电压(Vdss):20V;连续漏极电流(Id):65A;导通电阻(RDS(on)@Vgs,Id):6mΩ@4.5V,65A;
FDD8770-VB 数据手册
FDD8770 www.VBsemi.com N-Channel 20-V (D-S)175 _C MOSFET FEATURES PRODUCT SUMMARY rDS(on) () ID (A)a 0.0045 @ VGS = 4.5 V 100 0.006 @ VGS = 2.5 V 90 VDS (V) 20 D TrenchFETr Power MOSFET D 175_C Maximum Junction Temperature D 100% Rg Tested D TO-252 G Drain Connected to Tab G D S Top View S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TA = 25_C UNLESS OTHERWISE NOTED) Parameter Symbol Limit Drain-Source Voltage VDS 20 Gate-Source Voltage VGS "15 TC = 25_C Continuous Drain Currenta TC = 100_C Pulsed Drain Current Continuous Source Current (Diode Conduction)a TC = 25_C Maximum Power Dissipation TA = 25_C Operating Junction and Storage Temperature Range Unit V 100 ID 80 IDM 200 IS 65 A 71 PD W 8.3b, c TJ, Tstg - 55 to 175 _C THERMAL RESISTANCE RATINGS Parameter Symbol t v 10 sec. Maximum Junction-to-Ambientb Maximum Junction-to-Case Steady State RthJA RthJC Typical Maximum 15 18 40 50 1.75 2.1 Unit _C/W Notes a. Package Limited b. Surface Mounted on 1” x 1” FR4 Board c. t v 10 sec 服务热线:400-655-8788 1 FDD8770 www.VBsemi.com SPECIFICATIONS (TJ = 25_C UNLESS OTHERWISE NOTED) Parameter Typa Symbol Test Condition Min Max V(BR)DSS VGS = 0 V, ID = 250 A 20 VGS(th) VDS = VGS, ID = 250 A 0.5 IGSS VDS = 0 V, VGS = "12 V "100 VDS = 20 V, VGS = 0 V 1 VDS = 20 V, VGS = 0 V, TJ = 125_C 50 Unit Static Drain-Source Breakdown Voltage Gate Threshold Voltage Gate-Body Leakage Zero Gate Voltage Drain Current IDSS On-State Drain Currentb ID(on) Drain-Source On-State Resistanceb Forward Transconductanceb rDS(on) gfs VDS = 5 V, VGS = 4.5 V nA A 100 A VGS = 4.5 V, ID = 20 A 0.0045 VGS = 4.5 V, ID = 20 A, TJ = 125_C 0.0055 VGS = 2.5 V, ID = 20 A 0.006 VDS = 5 V, ID = 40 A V 1.5  20 S Dynamica Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 375 Total Gate Chargec Qg 26 Gate-Source Chargec Gate-Drain Chargec Gate Resistance Turn-On Delay Timec Rise Timec Turn-Off Delay Qgs Fall Timec VGS = 0 V, VDS = 20 V, f = 1 MHz 730 35 nC 7 Rg 1 td(on) td(off) pF 5 VDS = 10 V,, VGS = 4.5 V,, ID = 40 A Qgd tr Timec 3660 VDD = 10 V, RL = 0.25  ID ^ 40 A, VGEN = 4.5 V, RG = 2.5  tf 3.7 20 35 120 190 45 70 20 35  ns Source-Drain Diode Ratings and Characteristic (TC = 25_C) Pulsed Current ISM 100 A Voltageb VSD IF = 100 A, VGS = 0 V 1.2 1.5 V Source-Drain Reverse Recovery Time trr IF = 40 A, di/dt = 100 A/s 35 70 ns Diode Forward Notes a. Guaranteed by design, not subject to production testing. b. Pulse test; pulse width v 300 s, duty cycle v 2%. c. Independent of operating temperature. 服务热线:400-655-8788 2 FDD8770 www.VBsemi.com TYPICAL CHARACTERISTICS (25_C UNLESS NOTED) Output Characteristics Transfer Characteristics 100 100 VGS = 4.5 thru 3 V 80 60 I D - Drain Current (A) I D - Drain Current (A) 80 2.5 V 40 2V 20 60 40 TC = 125_C 20 25_C 1V 0 0 2 4 6 8 0 0.0 10 0.5 VDS - Drain-to-Source Voltage (V) 1.0 - 55_C 1.5 2.0 2.5 3.0 3.5 VGS - Gate-to-Source Voltage (V) Transconductance On-Resistance vs. Drain Current 120 0.012 TC = - 55_C r DS(on) - On-Resistance (  ) g fs - Transconductance (S) 100 25_C 80 125_C 60 40 20 0 0.009 VGS = 4.5 V 0.006 VGS = 4.5 V 0.003 0.000 0 20 40 60 80 80 0 100 90 VGS - Gate-to-Source Voltage (V) V GS - Gate-to-Source Voltage (V) C - Capacitance (pF) Ciss 3000 2000 Coss Crss Gate Charge 12 4000 1000 120 ID - Drain Current (A) Capacitance 5000 110 100 0 VGS = 10 V ID = 40 A 9 6 3 0 0 4 8 12 16 VDS - Drain-to-Source Voltage (V) 服务热线:400-655-8788 20 0 10 20 30 40 50 60 70 Qg - Total Gate Charge (nC) 3 FDD8770 www.VBsemi.com TYPICAL CHARACTERISTICS (25_C UNLESS NOTED) On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage 100 VGS = 4.5 V ID = 20 A 1.6 I S - Source Current (A) r DS(on) - On-Resistance () (Normalized) 2.0 1.2 0.8 0.4 0.0 - 50 - 25 0 25 50 75 100 125 150 TJ = 150_C TJ = 25_C 10 1 175 0 0.3 TJ - Junction Temperature (_C) 0.6 0.9 1.2 1.5 VSD - Source-to-Drain Voltage (V) THERMAL RATINGS Maximum Avalanche Drain Current vs. Case Temperature Safe Operating Area 200 50 100 I D - Drain Current (A) I D - Drain Current (A) 40 30 20 10 s Limited by rDS(on) 100 s 10 1 ms 10 ms 100 ms dc TC = 25_C Single Pulse 10 0 1 0 25 50 75 100 125 150 175 0.1 1 10 100 VDS - Drain-to-Source Voltage (V) TC - Case Temperature (_C) Normalized Thermal Transient Impedance, Junction-to-Case 2 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10 -4 服务热线:400-655-8788 10 -3 10 -2 10 -1 1 Square Wave Pulse Duration (sec) 10 100 600 4 FDD8770 www.VBsemi.com TO-252AA CASE OUTLINE E MILLIMETERS A C2 e b2 D1 e1 E1 L gage plane height (0.5 mm) L4 b L5 H D L3 b3 C A1 INCHES DIM. MIN. MAX. MIN. MAX. A 2.18 2.38 0.086 0.094 A1 - 0.127 - 0.005 b 0.64 0.88 0.025 0.035 b2 0.76 1.14 0.030 0.045 b3 4.95 5.46 0.195 0.215 C 0.46 0.61 0.018 0.024 C2 0.46 0.89 0.018 0.035 D 5.97 6.22 0.235 0.245 D1 5.21 - 0.205 - E 6.35 6.73 0.250 0.265 E1 4.32 - 0.170 - H 9.40 10.41 0.370 0.410 e 2.28 BSC e1 0.090 BSC 4.56 BSC 0.180 BSC L 1.40 1.78 0.055 L3 0.89 1.27 0.035 0.070 0.050 L4 - 1.02 - 0.040 L5 1.14 1.52 0.045 0.060 ECN: X12-0247-Rev. M, 24-Dec-12 DWG: 5347 Note • Dimension L3 is for reference only. 服务热线:400-655-8788 5 FDD8770 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. 6
FDD8770-VB 价格&库存
很抱歉,暂时无法提供与“FDD8770-VB”相匹配的价格&库存,您可以联系我们找货
FDD8770-VB
  • 100+1.60912
  • 500+1.57053
  • 3000+1.52650
