SHEN ZHEN XIN FEI HONG ELECTRONICS CO.,LTD
FH3060D
30V N-Channel MOSFET
Features
30V/60A
RDS(ON)= 8.5m Ω typ @ VGS=10V
RDS(ON)= 11.5m Ω typ @ VGS=4.5V
Applications
Power switching application
Load switching
Uninterruptible power supply
Lead free and Green Device Available
TO-252
D
D
G
G
S
S
Schematic diagram
Marking and pin assignment
TO-252 top view
Absolute Maximum Ratings (TA=25°C unless otherwise noted)
Symbol
V DSS
V GSS
Parameter
Drain-to-Source Voltage
Gate-to-Source Voltage
ID
Continuous Drain Current
I DP
Pulsed Drain Current
PD
Maximum Power Dissipation
TJ , T STG
TC=25°C
TC=100°C
T C=25°C
TC=25°C
TC=100°C
Junction & Storage Temperature Range
Maximum
Unit
30
±20
60
37
148
54
21
-55~150
V
V
A
A
A
°C
Typical
Unit
2.3
62.5
℃/W
W
Thermal Characteristics
Symbol
Rθjc
Rθja
www.xfhong.com
Parameter
Thermal Resistance-Junction to Case
Thermal Resistance-Junction to Ambient
1/5
Ver1.1
FH3060D
Electrical Characteristics (TA=25°C unless otherwise noted)
Symbol
Parameter
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
VGS(th)
Gate Threshold Voltage
IGSS
Gate Leakage Current
RDS(on)1
Drain-Source On-Resistance
Test Conditions
Min.
Typ
Max. Unit
VGS=0V,ID=250uA
VDS=30V,VGS=0V
TJ=85°C
VDS=VGS,ID=250uA
30
1
1.7
1
10
3
VGS=±20V, VDS=0V
VGS=10V, ID=15A
VGS=4.5V, ID=15A
8.5
11.5
ISD=15A,VGS=0V
0.88
IF=15A,
dI/dt=100A/us
23
15
VGS=0V, VDS=0V,
Frequency=1MHz
1.5
920
187
130
15
25
60
17
22
5
6.5
±100
10
15
V
uA
V
nA
mΩ
Diode Characteristics
VSD1
IS
trr
Qrr
Diode Forward Voltage
Diode Continuous Forward Current
Reverse Recovery Time
Reverse Recovery Charge
Dynamic Characteristics2
RG
Gate Resistance
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
td(on)
Turn-On Delay Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
Gate Charge Characteristics2
Qg
Total Gate Charge
Qgs
Gate-to-Source Charge
Qgd
Gate-to-Drain Charge
VGS=0V, VDS=30V
Frequency=1MHz
VDD=15V, RL=30Ω
ID=15A, VGS=10V
RG=6Ω
VDS=15V,VGS=10V
ID=15A
1.3
60
V
A
ns
nC
Ω
pF
ns
nC
Note: 1: Pulse test; pulse width ≦ 300ns, duty cycle ≦ 2%.
2: Guaranteed by design, not subject to production testing.
www.xfhong.com
2/5
Ver1.1
FH3060D
Typical Operating Characteristics
www.xfhong.com
3/5
Ver1.1
FH3060D
www.xfhong.com
4/5
Ver1.1
FH3060D
Package Information : TO-252
www.xfhong.com
5/5
Ver1.1
很抱歉,暂时无法提供与“FH3060D”相匹配的价格&库存,您可以联系我们找货
