STU606S
www.VBsemi.com
N-Channel 6 0-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
60
• TrenchFET® Power MOSFET
• 175 °C Junction Temperature
rDS(on) (Ω)
ID (A)a
0.025 at VGS = 10 V
45
0.030 at VGS = 4.5 V
RoHS*
40
COMPLIANT
VDS (V)
TO-252
Available
D
G
Drain Connected to Tab
G
D
S
S
Top View
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted
Parameter
Gate-Source Voltage
Continuous Drain Current (TJ = 175 °C)b
TC = 25 °C
TC = 100 °C
Symbol
Limit
Unit
VGS
± 20
V
45
ID
35
IDM
100
Continuous Source Current (Diode Conduction)
IS
23
Avalanche Current
IAS
Pulsed Drain Current
Single Avalanche Energy (Duty Cycle ≤ 1 %)
Maximum Power Dissipation
L = 0.1 mH
TC = 25 °C
TA = 25 °C
EAS
mJ
100
PD
W
3a
TJ, Tstg
Operating Junction and Storage Temperature Range
A
- 55 to 175
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta
Maximum Junction-to-Case
Symbol
t ≤ 10 sec
Steady State
RthJA
RthJC
Typical
Maximum
18
22
40
50
3.2
4
Unit
°C/W
Notes:
a. Surface Mounted on 1" x 1" FR4 board, t ≤ 10 sec.
服务热线:400-655-8788
1
STU606S
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min
Typa
Max
2.0
3.0
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
V(BR)DSS
VGS = 0 V, ID = 250 µA
60
VGS(th)
VDS = VGS, ID = 250 µA
1.0
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
VDS = 60 V, VGS = 0 V
1
VDS = 60 V, VGS = 0 V, TJ = 125 °C
50
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currentb
ID(on)
VDS = 60 V, VGS = 0 V, TJ = 175 °C
Drain-Source On-State Resistanceb
b
Forward Transconductance
rDS(on)
gfs
VDS = 5 V, VGS = 10 V
V
nA
µA
250
50
A
VGS = 10 V, ID = 15 A
0.025
VGS = 10 V, ID = 15 A, TJ = 125 °C
0.055
VGS = 10 V, ID = 15 A, TJ = 175 °C
0.069
VGS = 4.5 V, ID = 10 A
0.030
VDS = 15 V, ID = 15 A
VGS = 0 V, VDS = 25 V, f = 1 MHz
140
Ω
S
Dynamica
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
c
Gate-Drain Charge
Qgd
Turn-On Delay Timec
td(on)
Rise Timec
Turn-Off Delay Timec
Fall Timec
tr
td(off)
1500
pF
60
11
VDS = 30 V, VGS = 10 V, ID = 23 A
17
3
nC
3
VDD = 30 V, RL = 1.3 Ω
ID ≅ 23 A, VGEN = 10 V, Rg = 2.5 Ω
tf
8
15
15
25
30
45
25
40
ns
Source-Drain Diode Ratings and Characteristics (TC = 25 °C)
Pulsed Current
ISM
Diode Forward Voltage
VSD
IF = 15 A, VGS = 0 V
1.0
1.5
V
Reverse Recovery Time
trr
IF = 15 A, di/dt = 100 A/µs
30
60
ns
50
A
Notes:
a. For design aid only; not subject to production testing.
b. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
STU606S
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C unless noted
50
100
VGS = 10 thru 6 V
5V
40
I D - Drain Current (A)
80
60
40
4V
TC = 125 °C
10
25 °C
3V
- 55 °C
6
8
1
2
3
4
5
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
32
6
0.10
TC = - 55 °C
0.08
r DS(on) - On-Resistance (Ω)
g fs - Transconductance (S)
25 °C
24
125 °C
16
8
VGS = 4.5 V
0.04
VGS = 10 V
0.02
0.00
10
15
40
ID - Drain Current (A)
Transconductance
On-Resistance vs. Drain Current
50
10
V GS - Gate-to-Source Voltage (V)
1000
800
C - Capacitance (pF)
0.06
Ciss
600
400
200
Coss
Crss
VDS = 30 V
ID = 23 A
8
6
4
2
40
50
Capacitance
60
4
6
8
10
12
Qg - Total Gate Charge (nC)
Gate Charge
服务热线:400-655-8788
3
STU606S
www.VBsemi.com
100
2.5
VGS = 10 V
ID = 15 A
I S - Source Current (A)
rDS(on) - On-Resistance
(Normalized)
2.0
1.5
1.0
TJ = 150 °C
TJ = 25 °C
10
0.5
0.0
- 50
1
- 25
50
75
100
125
150
TJ - Junction Temperature ( °C)
On-Resistance vs. Junction Temperature
175
0.6
0.9
1.2
1.5
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
服务热线:400-655-8788
4
STU606S
www.VBsemi.com
THERMAL RATINGS
100
25
*rDS(on) Limited
10 µs
100 µs
10
10
1 ms
10 ms
1
100 ms
dc
TC = 25 °C
Single Pulse
5
50
75
100
125
150
175
0.1
1
10
100
*VGS > minimum VGS at which rDS(on) is specified
TA - Ambient Temperature (°C)
Maximum Drain Current
vs. Ambient Temperature
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01 10- 4
10- 3
10- 2
10- 1
1
10
Square Wave Pulse Duration (sec)
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
STU606S
www.VBsemi.com
TO-252AA CASE OUTLINE
E
MILLIMETERS
A
C2
e
b2
D1
e1
E1
L
gage plane height (0.5 mm)
L4
b
L5
H
D
L3
b3
C
A1
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
C
0.46
0.61
0.018
0.024
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
5.21
0.205
E
6.35
6.73
0.250
0.265
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
0.090 BSC
e1
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
L3
0.89
1.27
0.035
0.070
0.050
L4
1.02
0.040
L5
1.14
1.52
0.045
0.060
ECN: X12-0247-Rev. M, 24-Dec-12
DWG: 5347
Note
• Dimension L3 is for reference only.
服务热线:400-655-8788
6
STU606S
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR DPAK (TO-252)
0.224
0.243
0.087
(2.202)
0.090
(2.286)
0.420
(10.668)
(6.180)
(5.690)
0.180
0.055
(4.572)
(1.397)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
7
STU606S
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
