Green Product
MDT30N06L
60V N-Channel Power MOSFET
KEY CHARACTERISTICS
DESCRIPTION
● VDS = 60V,ID = 30A
The MDT30N60L uses advanced trench technology to provide
RDS(ON) < 30mΩ @ VGS=10V
excellent RDS(ON), low gate charge. It can be used in a wide
RDS(ON) < 40mΩ @ VGS=4.5V
variety of applications.
● High density cell design for lower Rdson
Application
● Fully characterized avalanche voltage and current
●Power switching application
● Good stability and uniformity with high EAS
●Hard switched and High frequency circuits
● Excellent package for good heat dissipation
●Uninterruptible power supply
100% UIS TESTED!
100% DVDS TESTED!
TO-252-2L Top View
Schematic diagram
Package Marking And Ordering Information
Device Marking
30N06
Ordering Codes
MDT30N06L
Package
Product Code
TO-252
Packing
30N06
Absolute Maximum Ratings (TA=25℃
Parameter
unless otherwise noted)
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
Drain Current-Continuous
ID
(Note
1)
Drain Current-Pulsed
IDM
Maximum Power Dissipation(Tc=25℃)
PD
(Note
2)
Single pulse avalanche energy
EAS
Operating Junction and Storage Temperature Range
TJ,TSTG
Reel
Limit
Unit
60
V
±20
V
30
A
80
A
44
W
56
mJ
-55 To 175
3.4
℃/W
Thermal Characteristic
Thermal Resistance,Junction-to-Case
Page1
RθJC
www.mns-kx.com
V1.0
Green Product
MDT30N06L
Electrical Characteristics (TA=25℃ unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Off Characteristics
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=250μA
60
V
Zero Gate Voltage Drain Current
IDSS
VDS=60V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=250μA
1.3
1.8
2.3
V
Drain-Source On-State Resistance(Note 3)
RDS(ON)
VGS=10V, ID=10A
25
30
VGS=4.5V, ID=10A
30
40
VDS=5V,ID=10A
11
S
670
pF
76
pF
66
pF
19.2
nS
On Characteristics
Forward Transconductance
gFS
mΩ
Dynamic Characteristics
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Switching
VDS=25V,VGS=0V,
f=1.0MHz
Characteristics (Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=30V, ID=10A,
6.4
nS
td(off)
VGS=10V,RGEN=10Ω
29.2
nS
8.2
nS
21
nC
5
nC
6.5
nC
1.2
V
33.6
nS
32.1
nC
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=48V,ID=10A
VGS=10V
Drain-Source Diode Characteristics
Diode Forward Voltage
VSD
Reverse Recovery Time
Trr
Reverse Recovery Charge
Qrr
VGS=0V,IS=20A
(note3)
Tj=25℃,IF=10A,di/dt=100A/uS
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. EAS condition :T j=25℃,VDD=30V,VGS=10V,L=0.5mH,Rg=25Ω
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production.
Page2
www.mns-kx.com
V1.0
Green Product
MDT30N06L
Characteristics Curves
Page3
Figure 1 Output Characteristics
Figure 2 Transfer Characteristics
Figure 3 On-Resistance vs. ID and VGS
Figure 4 On-Resistance vs. Junction Temperature
Figure 5 On-Resistance vs. VGS
Figure 6 Body Diode Forward Voltage
www.mns-kx.com
V1.0
Green Product
MDT30N06L
Figure 7 Gate-Charge Characteristics
Figure 9
Maximum Forward Biased Safe
Operation Area
Figure 11
Page4
Figure 8 Capacitance Characteristics
Figure 10 Single Pulse Power Rating
Junction-to-Ambient
Normalized Maximum Transient Thermal Impedance
www.mns-kx.com
V1.0
Green Product
MDT30N06L
Test Circuit and Waveform
Gate Charge Test Circuit
Gate Charge Test Waveform
Resistive Switching Test Circuit
Resistive Switching Test Waveforms
Unclamped Inductive Switching (UIS) Test Circuit
Unclamped Inductive Switching (UIS) Test Waveforms
Diode Recovery Test Circuit
Page5
www.mns-kx.com
Diode Recovery Test Waveforms
V1.0
Green Product
MDT30N06L
Package Description
Values(mm)
Items
MIN
MAX
A
6.30
6.90
A1
B
5.70
6.30
C
2.10
2.50
D
0.30
0.60
E1
0.60
0.90
E2
0.70
1.00
F
0.30
0.60
G
0.70
1.20
L1
9.60
10.50
L2
2.70
3.10
H
0.60
1.00
M
5.10
5.50
N
2.09
2.49
R
0 .3
T
1.40
1.60
Y
5.10
6.30
TO-252
Page6
www.mns-kx.com
Package
V1.0
Green Product
MDT30N06L
NOTE:
1. Exceeding the maximum ratings of the device in performance may cause damage to the device, even the permanent
failure, which may affect the dependability of the machine. Please do not exceed the absolute maximum ratings of
the device when circuit designing.
2. When installing the heat sink, please pay attention to the torsional moment and the smoothness of the heat sink.
3. MOSFETs is the device which is sensitive to the static electricity, it is necessary to protect the device from being
damaged by the static electricity when using it.
4. Shenzhen Minos reserves the right to make changes in this specification sheet and is subject to change without
prior notice.
CONTACT:
深圳市迈诺斯科技有限公司(总部)
Address:深圳市福田区华富街道田面社区深南中路4026号田面城市大厦22B-22C
Mobile:13632637333
Phone:0755-83273777
Page7
www.mns-kx.com
V1.0
很抱歉,暂时无法提供与“MDT30N06L”相匹配的价格&库存,您可以联系我们找货
