High Performance, Hall Effect-Based
Current Sensor IC with a Low-Resistance Conductor
50A
10 A / 2 0 A / 3 0 A / 4 0 A / 5 0 A / 6 5 A / series
FEATURES
APPLICATIONS
Zero current output voltage is 50%VCC
Motor controller
Current sensing range available: 10A/20A/30A/40A/50A/65A
Load detection and management
1.2MHz chopper frequency, high bandwidth, low noise, single ended analog
Switch-mode power supplies
output
Over-current fault protection
High isolation and withstand voltage (3750V(AC) isolation voltage between
pins 1-8 and 9-16)
Less power loss, internal conductor’s resistance is 0.6mΩ
High bandwidth, up to 250KHz, 1.2µs output rise time in response to step
input current
Total output error
% at Ta=25°C and
3% at Ta=-40~125°C
CrossChip patented temperature compensation
Outputs desensitized to mechanical stress
Differential Hall structure, strong resistance to external magnetic interference
ESD (HBM) 4000V
Operating ambient temperature: -40~125°C
www.tokmas.com
CI5931-65A
CI5930-30A
FUNCTION BLOCK DIAGRAM
ORDERING INFORMATION
Part No.
SENS. (mV/A)
Package
Packing Form
CI5931-10A
200
SOP16
tape reel, 1000 pcs/reel
CI5931-20A
100
SOP16
CI5931-30A
67
SOP16
CI5931-40A
50
SOP16
CI5931-50A
40
SOP16
CI5931-65A
30.75
SOP16
www.tokmas.com
CI5931-65A
CI5930-30A
PINOUT DIAGRAM
SOP16 Package
Name
Number
Description
Name
Number
Description
IP+
1
Current Sampled +
NC
9
NC
IP+
2
Current Sampled +
VCC
10
Power Supply
IP+
3
Current Sampled +
NC
11
NC
IP+
4
Current Sampled +
VOUT
12
Analog Voltage Output
IP-
5
Current Sampled -
VZCR
13
Zero Current Reference
IP-
6
Current Sampled -
NC
14
Signal
Output
NC
IP-
7
Current Sampled -
GND
15
Ground
IP-
8
Current Sampled -
NC
16
NC
ABSOLUTE MAXIMUM RATINGS
Parameter
Symbol
Value
Unit
Power Supply
VCC
7
V
Output Voltage
VOUT
-0.3~VCC+0.3
V
IOUT(SOURCE)
6
mA
IOUT(SINK)
30
mA
Input current peak current (3 s)
IPEAK
100
A
Input current continuous current
ICON
60
A
Isolation Voltage
VISO
3750
VAC
Operating Ambient Temperature
Ta
-40~125
°C
Junction Temperature
TJ
165
°C
Storage Temperature
TS
-55~150
°C
Magnetic Flux Density
B
Not Limited
mT
ESD(HBM)
4000
V
Output Source Current
Output Sink Current
Electrostatic Discharge Voltage (HBM)
Note: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
www.tokmas.com
CI5931-65A
CI5930-30A
ISOLATION CHARACTERISTICS
Parameter
Symbol
Test Conditions
Value
Unit
VISO
Test method: 50 / 60Hz, 1min
3750
VRMS
VTEST
t = 1s (100% production)
4500
VRMS
Basic insulation
1131
VPK or VDC
UL standard 62368-1:2014
800
VRMS
Reinforced Isolation
565
VPK or VDC
400
VRMS
7.8
mm
8000
VPK
Withstand isolation voltage
Working Voltage for Basic Insulation
VWVBI
Working Voltage for Reinforced Isolation
VWVRI
Clearance
Dcl
minimum distance through air from IP
leads to signal leads
Test method per IEC 62368-1,1.2/50µs
waveform,
VTEST
1.3×VIOSM
(qualification)
Note1:Testing is carried out in air or oil to determine the intrinsic surge immunity of the isolation barrier
Maximum surge isolation voltage (Note 1)
VIOSM
RECOMMENDED OPERATING CONDITIONS
Parameter
Symbol
Min.
Max.
Unit
Input voltage (Note 1)
VIN+, VIN- (Note 1)
-1131
1131
VPK
Input voltage (Note 2)
VIN+, VIN- (Note 2)
-565
565
VPK
IP
-50
50
A
Power Supply
VCC
4.5
5.5
V
Operation Temperature
TA
-40
125
°C
Input current (DC / AC RMS) (Note 3)
Note 1: Vin +, VIN – refers to the voltage of current input pins IP + and IP -, relative to pin 15 (GND), Basic Insulation.
Note 2: Vin +, VIN – refers to the voltage of current input pins IP + and IP -, relative to pin 15 (GND), Reinforced Isolation.
Note 3: Decrease due to higher ambient temperature.
ELECTRICAL PARAMETERS (Ta=25°C and VCC=5V, unless otherwise specified)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
Power Supply
VCC
4.5
5
5.5
V
Supply Current
ICC
OUT pin floated
mA
2.470
2.500
2.530
V
2.490
2.500
2.510
V
Internal benchmark
VZCR
Zero Current Output Voltage
VOUT(Q)
IP=0
Output Capacitance Load
CL
1
nF
Output Resistive Load
RL
1.5
kΩ
Res. of Primary Conductor
RP
0.6
1.5
mΩ
Propagation Time
tD
1
2
us
Rise Time
tr
1
2.2
us
CMRR
38
dB
250
kHz
IZCR(SOURCE)
400
uA
IZCR(SINK)
2000
uA
LinERR
0.2
0.5
Common Mode Rejection Ratio
Bandwidth
Reference Output Source Current
Reference Output Sink Current
Nonlinearity
BW
-3dB
www.tokmas.com
CI5931-65A
CI5930-30A
Continued:
Symmetry
SymERR
Power-on Time
TPOR
Output rising from 0 to 90% of steady-state
0.8
1.5
10
us
20A PERFORMANCE CHARACTERISTICS
Parameter
Current Accuracy Range
Sensitivity
Zero Current Differential Output Error
Symbol
Conditions
Min.
Typ.
Max.
Unit
IP
-20
A
Sens
full range of IP
97
100
103
mV/A
40
mV
VOE
-40
Noise
VNOISE(P-P)
40
mV
Zero Current Output Slope
ΔVOUT(Q)
0.34
mV/°C
Sensitivity Slope
ΔSENS
0.017
mV/A /°C
Total Output Error
ETOT
-3.0
3.0
30A PERFORMANCE CHARACTERISTICS
Parameter
Sensitivity
Symbol
Conditions
Min.
Typ.
Max.
Unit
IP
-30
30
A
Sens
full range of IP
65
67
69
mV/A
30
mV
VOE
-30
Noise
VNOISE(P-P)
35
mV
ΔVOUT(Q)
0.05
mV/°C
Sensitivity Slope
ΔSENS
0.01
mV/A /°C
Total Output Error
ETOT
-3.0
3.0
40A PERFORMANCE CHARACTERISTICS
Parameter
Sensitivity
Symbol
Conditions
Min.
Typ.
Max.
Unit
IP
-40
40
A
Sens
full range of IP
48.5
50
51.5
mV/A
25
mV
VOE
-25
Noise
VNOISE(P-P)
25
mV
ΔVOUT(Q)
0.05
mV/°C
Sensitivity Slope
ΔSENS
0.01
mV/A /°C
Total Output Error
ETOT
-3.0
3.0
www.tokmas.com
CI5931-65A
CI5930-30A
50A PERFORMANCE CHARACTERISTICS
Parameter
Sensitivity
Symbol
Conditions
Min.
Typ.
Max.
Unit
IP
-50
50
A
Sens
full range of IP
38.8
40
41.2
mV/A
mV
VOE
-20
Noise
VNOISE(P-P)
25
mV
ΔVOUT(Q)
0.05
mV/°C
Sensitivity Slope
ΔSENS
0.01
mV/A /°C
Total Output Error
ETOT
-3.0
3.0
65A PERFORMANCE CHARACTERISTICS
Parameter
Sensitivity
Symbol
Conditions
Min.
Typ.
Max.
Unit
IP
-65
65
A
Sens
full range of IP
29.83
30.75
31.67
mV/A
15
mV
VOE
-15
Noise
VNOISE(P-P)
mV
ΔVOUT(Q)
0.05
mV/°C
Sensitivity Slope
ΔSENS
0.01
mV/A /°C
Total Output Error
ETOT
-3.0
3.0
www.tokmas.com
CI5931-65A
CI5930-30A
TYPICAL APPLICATION CIRCUITS
Typical Output Application
Signal Attenuation Circuit
Peak Current Detection
Over Current Fault Latch
Rectifier output, instead of current transformer application
www.tokmas.com
Zero Migration Application
CI5931-65A
CI5930-30A
Application of single source zero shift with unidirectional current
Note: the output current of IZCR is < 0.4mA. It is suggested that 0.3mA
should be reserved in design
www.tokmas.com
Gain amplifier application
Note: output direction of VOUT
CI5931-65A
CI5930-30A
Relationship between Package Temperature & Input Current
Input Current (IP) vs. Package temperature
Thickness: 1.6mm, FR-4 double-sided plate, 4oz copper foil
total 10000m2
Test environment: open environment, stagnant air
Package Thermography (Input Current 30A)
Package Thermography (Input Current 40A)
Package Thermography (Input Current 50A)
Package Thermography (Input Current 65A)
www.tokmas.com
CI5931-65A
CI5930-30A
OUTPUT WAVEFORMS AND CURVES
ICC vs. Ta
ICC vs. VCC
AC output voltage waveform (50Hz)
AC output voltage waveform (50kHz)
AC output voltage waveform (100kHz)
AC output voltage waveform (250kHz)
www.tokmas.com
CI5931-65A
CI5930-30A
VOUT vs IP (20A)
VOUT vs IP (20A)
(Positive Current Rising Edge Response)
(Negative Current Rising Edge Response)
VOUT vs IP (20A)
VOUT vs IP (20A)
(Positive Current Falling Edge Response)
(Negative Current Falling Edge Response)
www.tokmas.com
CI5931-65A
CI5930-30A
VOUT vs IP (30A)
VOUT vs IP (30A)
VOUT vs IP (30A)
VOUT vs IP (30A)
www.tokmas.com
CI5931-65A
CI5930-30A
VOUT vs IP (40A)
VOUT vs IP (40A)
VOUT vs IP (40A)
VOUT vs IP (40A)
www.tokmas.com
CI5931-65A
CI5930-30A
20A
VOUTQ vs. Ta
VZCR vs. Ta
VOE vs. Ta
Sens error vs. Ta
VOUT error vs. Ta
VOUT vs. IP
www.tokmas.com
CI5931-65A
CI5930-30A
30A
VOUTQ vs. Ta
VZCR vs. Ta
VOE vs. Ta
Sens error vs. Ta
VOUT error vs. Ta
VOUT vs. IP
www.tokmas.com
CI5931-65A
CI5930-30A
40A
VOUTQ vs. Ta
VZCR vs. Ta
VOE vs. Ta
Sens error vs. Ta
VOUT error vs. Ta
VOUT vs. IP
www.tokmas.com
CI5931-65A
CI5930-30A
PACKAGE INFORMATION
SOP16 PACKAGE
Symbol
Millimeters
Min
Min
A
2.35
2.65
A1
0.10
0.30
b
0.33
0.51
c
0.23
0.32
D
10.10
10.50
E1
7.40
7.60
E
10.00
10.63
e
www.tokmas.com
TYP
1.27 BSC
L
0.40
1.27
h
0.25
0.75
θ
0°
8°
CI5931-65A
CI5930-30A
Package Reference
Reference: shorten pad length and increase creepage distance
www.tokmas.com
很抱歉,暂时无法提供与“CI5931-65A”相匹配的价格&库存,您可以联系我们找货
