SWD9N50D
SWD9N50D
    SAMWIN(芯派)
    TO252
    漏源电压(Vdss):500V;连续漏极电流(Id):9A;导通电阻(RDS(on)@Vgs,Id):680mΩ;
SWD9N50D 数据手册
SW9N50D N-channel Enhanced mode TO-220F/TO-220/TO-252 MOSFET Features ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ TO-220F TO-252 TO-220 BVDSS : 500V ID High ruggedness Low RDS(ON) (Typ 0.68Ω)@VGS=10V Low Gate Charge (Typ 31nC) Improved dv/dt Capability 100% Avalanche Tested Application: DC-DC,LED,PC : 9A RDS(ON) : 0.68Ω 1 2 1 3 1 2 3 2 2 3 1. Gate 2. Drain 3. Source 1 3 General Description This power MOSFET is produced with advanced technology of SAMWIN. This technology enable the power MOSFET to have better characteristics, including fast switching time, low on resistance, low gate charge and especially excellent avalanche characteristics. Order Codes Item 1 Sales Type SW F 9N50D Marking SW9N50D Package TO-220F Packaging TUBE 2 SW P 9N50D SW9N50D TO-220 TUBE 3 SW D 9N50D SW9N50D TO-252 REEL Absolute maximum ratings Symbol VDSS ID Value Parameter TO-220F Drain to source voltage TO-220 TO-252 Unit 500 V Continuous drain current (@TC=25oC) 9* A Continuous drain current (@TC=100oC) 5.7* A 36 A ± 30 V IDM Drain current pulsed VGS Gate to source voltage EAS Single pulsed avalanche energy (note 2) 462 mJ EAR Repetitive avalanche energy (note 1) 64 mJ dv/dt Peak diode recovery dv/dt (note 3) 5 V/ns PD TSTG, TJ TL (note 1) Total power dissipation (@TC=25oC) 23.3 200 181 W Derating factor above 25oC 0.19 1.6 1.4 W/oC Operating junction temperature & storage temperature Maximum lead temperature for soldering purpose, 1/8 from case for 5 seconds. -55 ~ + 150 oC 300 oC *. Drain current is limited by junction temperature. Thermal characteristics Symbol Value Parameter Rthjc Thermal resistance, Junction to case Rthja Thermal resistance, Junction to ambient Copyright@ Semipower Technology Co., Ltd. All rights reserved. TO-220F 5.36 TO-220 0.63 53 60 Unit TO-252 0.69 May.2022. Rev. 5.0 oC/W oC/W 1/7 SW9N50D Electrical characteristic ( TC = 25oC unless otherwise specified ) Symbol Parameter Test conditions Min. Typ. Max. Unit Off characteristics BVDSS Drain to source breakdown voltage VGS=0V, ID=250uA ΔBVDSS / ΔTJ Breakdown voltage temperature coefficient ID=250uA, referenced to 25oC IDSS Drain to source leakage current IGSS 500 V VDS=510V, VGS=0V VDS=408V, V/oC 0.57 TC=125oC 1 uA 50 uA Gate to source leakage current, forward VGS=30V, VDS=0V 100 nA Gate to source leakage current, reverse VGS=-30V, VDS=0V -100 nA 4.5 V 0.8 Ω On characteristics VGS(TH) Gate threshold voltage VDS=VGS, ID=250uA RDS(ON) Drain to source on state resistance VGS=10V, ID=4.5A 0.68 Forward transconductance VDS=30V, ID=4.5A 7 Gfs 2.5 S Dynamic characteristics Ciss Input capacitance Coss Output capacitance Crss Reverse transfer capacitance td(on) Turn on delay time tr td(off) tf Qg Rising time Turn off delay time 1479 VGS=0V, VDS=25V, f=1MHz 126 pF 22.4 19 VDS=250V, ID=9A, RG=25Ω , VGS=10V (note 4,5) 41 ns 74 Fall time 37 Total gate charge Qgs Gate-source charge Qgd Gate-drain charge Rg Gate resistance 31 VDS=400V, VGS=10V, ID=9A (note 4,5) 7 nC 13 VDS=0V, Scan F mode Ω 1.7 Source to drain diode ratings characteristics Symbol Parameter IS Continuous source current ISM VSD Test conditions Min. Typ. Max. Unit 9 A Pulsed source current Integral reverse p-n Junction diode in the MOSFET 36 A Diode forward voltage drop. IS=9A, VGS=0V 1.4 V trr Reverse recovery time Qrr Reverse recovery charge IS=9A, VGS=0V, dIF/dt=100A/us 319 ns 3.48 uC ※. Notes 1. Repeatitive rating : pulse width limited by junction temperature. 2. L = 11.4mH, IAS = 9A, VDD = 50V, RG=25Ω, Starting TJ = 25oC 3. ISD ≤ 9A, di/dt = 100A/us, VDD ≤ BVDSS, Staring TJ =25oC 4. Pulse Test : Pulse Width ≤ 300us, duty cycle ≤ 2%. 5. Essentially independent of operating temperature. Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 5.0 2/7 SW9N50D Fig. 1. On-state characteristics Fig. 2. Transfer Characteristics Fig. 3. On-resistance variation vs. drain current and gate voltage Fig. 4. On state current vs. diode forward voltage Fig 5. Breakdown Voltage Variation vs. Junction Temperature Fig. 6. On resistance variation vs. junction temperature Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 5.0 3/7 SW9N50D Fig. 7. Gate charge characteristics Fig. 9. Maximum safe operating area(TO-220F) Fig. 8. Capacitance Characteristics Fig. 10. Maximum safe operating area(TO-220) Fig. 11. Maximum safe operating area(TO-252) Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 5.0 4/7 SW9N50D Fig. 12. Transient thermal response curve(TO-220F) Fig. 13. Transient thermal response curve(TO-220) Fig. 14. Transient thermal response curve(TO-252) Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 5.0 5/7 SW9N50D Fig. 15. Gate charge test circuit & waveform Fig. 16. Switching time test circuit & waveform VDS 90% RL RGS VDS VDD VIN 10VIN DUT 10% 10% td(on) tr tON td(off) tf tOFF Fig. 17. Unclamped Inductive switching test circuit & waveform Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 5.0 6/7 SW9N50D Fig. 18. Peak diode recovery dv/dt test circuit & waveform DUT + V DS 10V VGS (DRIVER) L IS di/dt IS (DUT) IRM VDS RG 10VGS Diode reverse current VDD Diode recovery dv/dt Same type as DUT VDS (DUT) *. dv/dt controlled by RG *. Is controlled by pulse period VDD VF Body diode forward voltage drop DISCLAIMER * All the data & curve in this document was tested in SEMIPOWER TESTING & APPLICATION CENTER. * This product has passed the PCT,TC,HTRB,HTGB,HAST,PC and Solderdunk reliability testing. * Qualification standards can also be found on the Web site (http://www.semipower.com.cn) * Suggestions for improvement are appreciated, Please send your suggestions to samwin@samwinsemi.com Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 5.0 7/7
SWD9N50D 价格&库存
很抱歉,暂时无法提供与“SWD9N50D”相匹配的价格&库存,您可以联系我们找货
