HKTD90N03
MOSFET (N-CHANNEL)
FEATURES
z Low on-resistance
z Fast switching speed
z Easily designed drive circuits
z Easy to parallel
TO--252
MECHANICAL DATA
z
Case: PDFN5x6
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.016 grams (approximate)
z
Marking:D90N03
z
z
z
EQUIVALENT CIRCUIT
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Drain-source voltage
Gate-source voltage
Continuous drain current
Power dissipation
Symbol
VDS
VGS
ID
PD
RθJA
TJ,TSTG
Thermal resistance from Junction to ambient
Junction and Storage temperature
Value
30
±20V
90
90
18
-55 ~+150
Unit
V
V
A
W
°C/W
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol Min Typ Max Unit
Conditions
Off Characteristics
V(BR)DSS
Drain-Source breakdown voltage
VGS=0V, ID=250uA
30
V
VDS=30V, VGS=0V
Zero gate voltage drain current
µA
IDSS
1
Gate-body leakage current
IGSS
±100 nA VDS=0V, VGS=±20V
VDS=20V,ID=250μA
Gate-threshold voltage (note 1)
VGS(th)
1.6
1
2.5
Drain-source on-resistance (note 1)
Dynamic Characteristics
Input capacitance
Output capacitance
Reverse transfer capacitance
Switching Characteristics
Turn-on delay time
Turn-on rise time
Turn-off delay time
Turn-off fall time
RDS(ON)
3.8
5
mΩ
VGS=10V, ID=20A
5.5
7
mΩ
VGS=4.5V, ID=10A
Ciss
Coss
Crss
2000
320
240
pF
pF
pF
VDS=15V, VGS=0V, f=1MHz
td(on)
tr
td(off)
tf
13
36
42
16
nS
nS
nS
nS
VDD=15V. VGS =10V,ID =30A
Rg=3Ω
Note:1. Pulse test ; Pulse width ≤300µs, Duty cycle ≤ 2% .
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
E-mail:hkt@heketai.com
1/5
HKTD90N03
MOSFET (N-CHANNEL)
Typical Characteristics
2/5
HKTD90N03
MOSFET (N-CHANNEL)
3/5
HKTD90N03
MOSFET (N-CHANNEL)
UTLINE DIMENSIONS
DIMENSION
TO-252 PACKAGE OUTLINE
Symbol
A
A1
B
b
c
c1
D
D1
E
e
e1
M
N
L
L1
L2
V
Φ
Dim
mensionsIn Millimeters
Min
n.
Max.
2.200
2.380
0.000
0.100
0.800
1.400
0.710
0.810
0.460
0.560
0.460
0.560
6.500
6.700
5.130
5.460
6.000
6.200
2.286TYP
4.327
4.727
1.778REF
0.762REF
9.800
10.400
2.9REF
1.400
1.700
4.830REF
1.100
1.300
Dimen
ensionsIn Inches
Min.
Max.
0.087
0.094
0.000
0.004
0.031
0.055
0.028
0.032
0.018
0.022
0.018
0.022
0.256
0.264
0.202
0.215
0.236
0.244
0.090TYP
0.170
0.186
0.070REF
0.018REF
0.386
0.409
0.114REF
0.055
0.067
0.190REF
0.043
0.051
TO-252 SUGGESTED
UGGESTED PAD LAYOUT
Note:
1. Controlling dimension: in millimeters
2. General tolerance: ±0.05mm
0.05mm
3. The pad layout is for reference purposes only
4/5
HKTD90N03
MOSFET (N-CHANNEL)
TO-252 TAPE AND REEL
TO-252 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
TO-252
6.90
10.50
2.70
Ø1.55
1.75
7.50
4.00
8.00
2.00
16.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
TO-252 Tape Leader and Trailer
TO-252 REEL
REEL OPTION
13’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø330.00
100.00
Φ21.00
R151.00
R56.00
R6.50
16.40
21.00
±2
±1
±1
±1
±1
±1
±1
±1
5/5
很抱歉,暂时无法提供与“HKTD90N03”相匹配的价格&库存,您可以联系我们找货
