IRFR310TRPBF
www.VBsemi.com
Power MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) (Ω)
650
2.1
VGS = 10 V
Qg (Max.) (nC)
48
Qgs (nC)
12
Qgd (nC)
19
Configuration
Single
• Low Gate Charge Qg Results in Simple Drive
Requirement
• Improved Gate, Avalanche and Dynamic dV/dt
Ruggedness
Available
RoHS*
COMPLIANT
• Fully Characterized Capacitance and Avalanche Voltage
and Current
• Compliant to RoHS directive 2002/95/EC
D
TO-252
G
G
D
S
S
N-Channel MOSFET
Top View
ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Currente
TC = 25 °C
VGS at 10 V
TC = 100 °C
Pulsed Drain Currenta
Linear Derating Factor
Single Pulse Avalanche Energyb
Repetitive Avalanche Currenta
Repetitive Avalanche Energya
Maximum Power Dissipation
TC = 25 °C
Peak Diode Recovery dV/dtc
Operating Junction and Storage Temperature Range
Soldering Recommendations (Peak Temperature)d
for 10 s
Mounting Torque
6-32 or M3 screw
SYMBOL
LIMIT
UNIT
VDS
VGS
650
± 30
V
ID
4.5
4.2
IDM
EAS
IAR
EAR
PD
dV/dt
TJ, Tstg
18
0.48
325
4
6
60
2.8
- 55 to + 150
300
10
1.1
A
W/°C
mJ
A
mJ
W
V/ns
°C
lbf · in
N·m
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11).
b. Starting TJ = 25 °C, L = 24 mH, RG = 25 Ω, IAS = 3.2 A (see fig. 12).
c. ISD ≤ 3.2 A, dI/dt ≤ 90 A/µs, VDD ≤ VDS, TJ ≤ 150 °C.
d. 1.6 mm from case.
e. Drain current limited by maximum junction temperature.
服务热线:400-655-8788
1
IRFR310TRPBF
www.VBsemi.com
THERMAL RESISTANCE RATINGS
PARAMETER
SYMBOL
TYP.
MAX.
Maximum Junction-to-Ambient
RthJA
65
Maximum Junction-to-Case (Drain)
RthJC
2.1
UNIT
°C/W
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
PARAMETER
SYMBOL
TEST CONDITIONS
VDS
VGS = 0 V, ID = 250 µA
MIN.
TYP.
MAX.
UNIT
650
V
670
mV/°C
2.5
5.0
V
nA
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
Gate-Source Threshold Voltage
Gate-Source Leakage
Zero Gate Voltage Drain Current
Drain-Source On-State Resistance
Forward Transconductance
ΔVDS/TJ
VGS(th)
Reference to 25 °C, ID = 1
VDS = VGS, ID = 250 µA
IGSS
IDSS
RDS(on)
gfs
mAd
VGS = ± 30 V
± 100
VDS = 650 V, VGS = 0 V
25
VDS = 520 V, VGS = 0 V, TJ = 125 °C
250
2.1
Ω
3.9
S
1417
177
7.0
VDS = 1.0 V, f = 1.0 MHz
1912
VDS = 520 V, f = 1.0 MHz
48
84
48
12
19
14
18
4
21
ID = 3.1 Ab
VGS = 10 V
VDS = 50 V, ID = 3.1 A
µA
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Output Capacitance
Coss
Effective Output Capacitance
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-On Delay Time
td(on)
Turn-Off Delay Time
Fall Time
VGS = 0 V
Coss eff.
Total Gate Charge
Rise Time
VGS = 0 V,
VDS = 25 V,
f = 1.0 MHz, see fig. 5
tr
td(off)
VDS = 0 V to 520
VGS = 10 V
Vc
ID = 3.2 A, VDS = 400 V
see fig. 6 and 13b
VDD = 325 V, ID = 3.2 A
RG = 9.1 Ω, RD = 62 Ω,
see fig. 10b
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current
Pulsed Diode Forward Currenta
Body Diode Voltage
IS
ISM
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Forward Turn-On Time
ton
MOSFET symbol
showing the
integral reverse
p - n junction diode
D
A
G
TJ = 25 °C, IS = 3.2 A, VGS = 0
S
Vb
TJ = 25 °C, IF = 3.2 A, dI/dt = 100 A/µsb
1.5
V
493
739
ns
2.1
3.2
µC
Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
b. Pulse width ≤ 300 µs; duty cycle ≤ 2 %.
c. Coss eff. is a fixed capacitance that gives the same charging time as Coss while VDS is rising from 0 % to 80 % VDS.
d. t = 60 s, f = 60 Hz.
服务热线:400-655-8788
2
IRFR310TRPBF
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
10
10
VGS
15V
10V
8.0V
7.0V
6.0V
5.5V
5.0V
BOTTOM 4.5V
5
I D , Drain-to-Source Current (A)
TOP
1
20µs PULSE WIDTH
4.5V TJ = 25 °C
0.1
0.1
1
10
5
TJ = 150 ° C
TJ = 25 ° C
1
0.1
4.0
100
VDS , Drain-to-Source Voltage (V)
4.5V
1
20µs PULSE WIDTH
TJ = 150 ° C
1
10
Fig. 2 - Typical Output Characteristics
100
RDS(on) , Drain-to-Source On Resistance
(Normalized)
8.0
VGS
15V
10V
8.0V
7.0V
6.0V
5.5V
5.0V
BOTTOM 4.5V
0.1
6.0
7.0
8.0
9.0
Fig. 3 - Typical Transfer Characteristics
TOP
5
5.0
VGS , Gate-to-Source Voltage (V)
Fig. 1 - Typical Output Characteristics
10
V DS = 100V
20µs PULSE WIDTH
ID = 3.2A
5.5
5.0
3.5
2.0
0.5
0.0
-60 -40 -20
VGS = 10V
60
80 100 120 140 160
TJ , Junction Temperature ( °C)
Fig. 4 - Normalized On-Resistance vs. Temperature
服务热线:400-655-8788
3
IRFR310TRPBF
2000
10
ISD , Reverse Drain Current (A)
V GS = 0V,
f = 1MHz
C iss = Cgs + C gd , Cds SHORTED
C rss = C gd
C oss = C ds + C gd
1600
C, Capacitance (pF)
www.VBsemi.com
iss
1200
oss
800
400
rss
100
TJ = 150 ° C
1
TJ = 25 ° C
0.1
0.2
A
1
5
1000
Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage
0.8
1.0
1.2
Fig. 7 - Typical Source-Drain Diode Forward Voltage
10
ID = 3.2 A
OPERATION IN THIS AREA LIMITED
BY RDS(on)
VDS = 520V
VDS = 325V
VDS = 130V
16
10us
ID , Drain Current (A)
0.6
VSD ,Source-to-Drain Voltage (V)
V GS = 0 V
0.4
12
8
5
100us
1ms
1
10ms
4
FOR TEST CIRCUIT
SEE FIGURE 13
40
50
0.1
TC = 25 ° C
TJ = 150 ° C
Single Pulse
10
100
1000
QG , Total Gate Charge (nC)
Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage
Fig. 8 - Maximum Safe Operating Area
10000
服务热线:400-655-8788
4
IRFR310TRPBF
www.VBsemi.com
RD
VDS
6.0
VGS
D.U.T.
RG
5.0
- VDD
4.0
10 V
Pulse width ≤ 1 µs
Duty factor ≤ 0.1 %
3.0
Fig. 10a - Switching Time Test Circuit
2.0
VDS
90 %
1.0
0.0
25
50
75
100
125
150
10 %
VGS
TC , Case Temperature ( ° C)
t d(on)
Fig. 9 - Maximum Drain Current vs. Case Temperature
tr
t d(off) t f
Fig. 10b - Switching Time Waveforms
Thermal Response (Z thJC )
10
D = 0.50
1
0.20
0.10
PDM
0.05
0.1
t1
0.02
t2
0.01
Notes:
1. Duty factor D = t 1 / t 2
2. Peak T J = P DM x Z thJC + TC
SINGLE PULSE
(THERMAL RESPONSE)
0.01
0.00001
0.0001
0.001
0.01
0.1
1
10
t1 , Rectangular Pulse Duration (s)
Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case
V DS
tp
15 V
L
VDS
D.U.T.
RG
IAS
20 V
tp
Driver
A
- VDD
0.01 Ω
Fig. 12a - Unclamped Inductive Test Circuit
A
I AS
Fig. 12b - Unclamped Inductive Waveforms
服务热线:400-655-8788
5
EAS , Single Pulse Avalanche Energy (mJ)
IRFR310TRPBF
www.VBsemi.com
800
TOP
BOTTOM
600
ID
2.3A
3.3A
4A
QG
10 V
QGS
400
Q GD
VG
Charge
200
Fig. 13a - Basic Gate Charge Waveform
50
75
100
125
150
Starting TJ , Junction Temperature ( °C)
Current regulator
Same type as D.U.T.
Fig. 12c - Maximum Avalanche Energy vs. Drain Current
50 kΩ
12 V
0.2 µF
0.3 µF
800
V DSav , Avalanche Voltage (V)
D.U.T.
780
VDS
VGS
3 mA
760
IG
ID
Current sampling resistors
Fig. 13b - Gate Charge Test Circuit
740
720
700
A
2
3
4
5
6
I av , Avalanche Current (A)
Fig. 12d - Typical Drain-to Source Voltage vs. Avalanche
Current
服务热线:400-655-8788
6
IRFR310TRPBF
www.VBsemi.com
Peak Diode Recovery dV/dt Test Circuit
D.U.T.
Circuit layout considerations
• Low stray inductance
• Ground plane
• Low leakage inductance
current transformer
RG
dV/dt controlled by R G
Driver same type as D.U.T.
ISD controlled by duty factor "D"
D.U.T. - device under test
Driver gate drive
P.W.
Period
D=
VDD
P.W.
Period
VGS = 10 V*
D.U.T. ISD waveform
Reverse
recovery
current
Body diode forward
current
dI/dt
D.U.T. VDS waveform
Diode recovery
dV/dt
Re-applied
voltage
VDD
Body diode forward drop
Inductor crurent
Ripple ≤ 5 %
ISD
* VGS = 5 V for logic level devices
Fig. 14 - For N-Channel
服务热线:400-655-8788
7
IRFR310TRPBF
www.VBsemi.com
TO-252AA CASE OUTLINE
E
MILLIMETERS
A
C2
e
b2
D1
e1
E1
L
gage plane height (0.5 mm)
L4
b
L5
H
D
L3
b3
C
A1
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
C
0.46
0.61
0.018
0.024
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
5.21
0.205
0.265
E
6.35
6.73
0.250
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
0.090 BSC
e1
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.14
1.52
0.045
0.060
ECN: X12-0247-Rev. M, 24-Dec-12
DWG: 5347
Note
• Dimension L3 is for reference only.
8
服务热线:400-655-8788
IRFR310TRPBF
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
