LINEAR INTEGRATED CIRCUIT
UTC7312
DUAL
RECORDING/PLAYBACK
PRE-AMPLIFIER CIRCUIT
WITH ALC
DESCRIPTION
The UTC7312 is a monolithic integrated circuit designed
for dual pre-amplifier circuit with ALC for record /playback
amplifier of cassette tape recorder.
FEATURES
*High open loop gain
*Incorporates ALC detector circuit
*No input coupling condenser
*Low noise and current consumption
*Wide ALC range
*Wide operating voltage range: Vcc=5V ~ 12V
*Low Power ON shock noise
DIP-14
12
11
Ripple Filter
10
Input of
Ch2
NFof CH2
Phase
compensat
ion of ch2
13
Output 2
14
ALC input
Ch 2
Vcc
Rippli filter
BLOCK DIAGRAM
9
8
Ch2
Amp
ALC
1
2
3
4
5
6
7
GND
ALC Time
constant
ALC input
Ch 1
Output 1
Phase
compensat
ion of ch1
NFof CH1
Input of
Ch1
Ch1
Amp
YOUWANG ELECTRONICS CO.LTD
1
2017.09.18 V1.2
UTC7312
ABSOLUTE MAXIMUM RATINGS(Ta=25C )
Characteristic
Symbol
Supply Voltage
Supply Current
Power Dissipation
Operating Temperature
Storage Temperature
Vcc
Icc
PD
Topr
Tstr
Value
Unit
14
50
700
-55 to 125
-65 to 150
V
mA
mW
C
C
ELECTRICAL CHARACTERISTICS
( Ta=25C ,Vcc=6V,f=1kHz,,RL=5.1k,unless otherwise specified)
Symbol
Test Condition
Quiescent current
Operating voltage
Closed-llop Voltage Gain
Total Harmonic Distortion
Output Voltage
Output noise Voltage
Characteristic
ICCQ
Vcc
Gvc
THD
Vo
Vno
Vi=0
ALC Voltage
ALC Width
Channel Balance
VALC
W ALC
CB
Min Typ. Max Unit
2.5
5.0
66
Vo=0.5V
Vo=0.5V
THD=1%
Rg=0(internal resistance 1.5k)
DIN/Audio)
Vin=400V
Beginning 0dB to 3dB
Vo=0.5V, CB=Gv1-Gv2
1.2
0.55
35
-1
4.5
69
0.5
1.6
2.0
0.63
47
12.0
72
1.0
5.0
0.7
+1
mA
V
dB
V
mV
V
dB
dB
TYPICAL APPLICATION CIRCUIT
REC
1.8kΩ
RL=5kΩ
Playback
82nF
220μF
0.022μF
10μF
10μF
Vcc=6V
14
13
12
11
1000pF
100μF
Output
of CH2
input2
39kΩ
10
9
8
6
7
UTC7312
0.022μF
82nF
REC
Output
of CH1
Input1
1.8kΩ
4MΩ
22μF
Playback
5
39kΩ
100μF
4
1000pF
3
10μF
2
RL=5kΩ
1
Playback
REC
2
2017.09.18 V1.2
UTC7312
3
2017.09.18 V1.2
UTC7312
TYPICAL PERFORMANCE CHARACTERISTICS
Vomax,Gv vs. Supply Voltage
ICCQ THD vs. Supply Voltage
68
3
6
9
12
2
4
1
2
THD
Supply Voltage (V)
6
9
12
60
Vcc=6V
Vo=0.5V
RL=5.1kΩ
FLAT
50
Gv, THD vs. Frequency
100
1
0.1
0.1
THD
Output Voltage (V)
Vo
Total Harmonic Distortion (%)
1
40
10
1
10k
100k
(Hz)
Vo, THD vs. Input Voltage
Vcc=6V
f=1kHz
RL=5.1kΩ
FLAT
the dot line is
measured at
Vcc=12V
100
10
Output Voltage (V)
2
GV
50
1k
Frequency
60
1
30
15
100
Vcc=6V
Vo=0.5V
RL=5.1kΩ
NAB
2
THD
Supply Voltage (V)
80
70
GV
40
70
ICCQ
6
10
10
1
1
THD
Vo
0.1
0.1
69
1
8
Voltage Gain (dB)
70
2
Gv
Voltage Gain (dB)
71
3
Vomax
f=1kHz
Vcc=0.5V
RL=5.1kΩ
THD=1%
4
Voltage Gain (dB)
10
Quiescent current (mA)
Maximum Output Voltage (V)
5
THD
10
100
1k
Frequency
10k
0.01
100k
0.01
0.01
0.1
(Hz)
1
10
0.01
Input Voltage (mV)
Gvo vs. Frequency
0.1
1
10
Input Voltage (mV)
VALC THDvs. Input Voltgae
80
ALC Voltage (dBV)
100
Vcc=6V
f=1kHz
5
Pin
6.9
1.5
-10
60
1.0
0.5
40
-15
10
100
1k
Frequency
10k
(Hz)
100k
Total Harmonics Distortion (%)
Vcc=6V
Vo=1V
120
100μF
Open Circuit Volatge Gain (dB)
10
-60
-40
-20
Input Voltage (mV)
4
2017.09.18 V1.2
UTC7312
PACKAGE OUTLINE
DIP-14-300-2.54
Unit: mm
1.52 +0.3
-0
0.25±0.05
7.62
6.35±0.25
2.54
15 degree
4.36MAX
19.55±0.3
3.00MIN
0.5MIN
0.46±0.08
2.40MAX
5
2017.09.18 V1.2
UTC7312
ELECTROSTATIC DISCHARGE CAUTION
These devices have limited built-in ESD protection. The leads should be shorted together or the
device placed in conductive foam during storage handing to prevent electrostatic damage to the
devices.
NOTICE
HANGZHOU YOUWANG ELECTRONICS CO.LTD assumes no responsibility for equipment failures that result
from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating
condition ranges, or other parameters) listed in products specifications of any and all HANGZHOU YOUWANG
ELECTRONICS CO.LTD’s products described or contained herein. HANGZHOU YOUWANG ELECTRONICS
CO.LTD’s products are not designed for use in life support appliances, devices or systems where malfunction of
these products can be reasonably expected to result in personal injury. Reproduction in whole or in part is
prohibited without the prior written consent of the copyright owner. The information presented in this document
does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without
notice.
6
2017.09.18 V1.2
UTC7312
Attach
Revision History
Data
REV
Description
1.0
Original
2007.11.28
1.1
Add picture is on page third
2017.09.18
1.2
Page
3
Add “Electrostatic Discharge Caution” and “NOTICE”, and” PACKAGE
OUTLINE”
7
2017.09.18 V1.2
很抱歉,暂时无法提供与“UTC7312”相匹配的价格&库存,您可以联系我们找货
