HSH6117
P-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSH6117 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON
and gate charge for most of the synchronous
buck converter applications.
The HSH6117 meet the RoHS and Green
Product requirement, 100% EAS guaranteed
with full function reliability approved.
VDS
-60
V
RDS(ON),max
14
mΩ
ID
-80
A
TO263 Pin Configuration
Super Low Gate Charge
100% EAS Guaranteed
Green Device Available
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
VDS
Rating
Units
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, -VGS @ -10V1
-80
A
ID@TC=100℃
-10V1
-45
A
-170
A
330
mJ
40
A
200
W
IDM
EAS
IAS
PD@TC=25℃
Pulsed Drain
Current2
Single Pulse Avalanche
Energy3
Avalanche Current
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
62
℃/W
0.81
℃/W
1
HSH6117
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-60
V
VGS=-10V , ID=-18A
14
VGS=-4.5V , ID=-12A
17
-1.0
-2.5
V
4.28
mV/℃
VDS=-48V , VGS=0V , TJ=25℃
1
VDS=-48V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =-250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-10V , ID=-18A
43
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.6
Qg
Total Gate Charge
85
Qgs
Gate-Source Charge
11
Qgd
Gate-Drain Charge
30
Td(on)
Turn-On Delay Time
VDS=-30V , VGS=-10V , ID=-12A
nC
18
Rise Time
VDD=-30V , VGS=-10V , RG=6,
12
Turn-Off Delay Time
ID=-1A
100
Fall Time
68
Ciss
Input Capacitance
4635
Coss
Output Capacitance
524
Crss
Reverse Transfer Capacitance
241
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
-40
A
VGS=0V , IS=-1A , TJ=25℃
-1.2
V
Tr
Td(off)
Tf
VDS=-30V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,5
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-30V,VGS=-10V,L=0.5mH,IAS=-40A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSH6117
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSH6117
www.hs-semi.cn
Ver 2.0
4
HSH6117
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSH6117”相匹配的价格&库存,您可以联系我们找货
