UCLAMP0571P.TNT
Features
Description
Ultra small package: 1.6x1.0x0.5mm
Protects one data or power line
Ultra low leakage: nA level
Low clamping voltage
2-pin leadless package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 120A (5/50ns)
– IEC61000-4-5 (Lightning) 170A (8/20μs)
RoHS Compliant
The UCLAMP0571P.TNT is an uni-directional
TVS diode, utilizing leading monolithic silicon
technology to provide fast response time and low ESD
clamping voltage, making this device an ideal so-lution
for protecting voltage sensitive data and power line.
The UCLAMP0571P.TNT complies with the IEC
61000-4-2 (ESD) standard with ±15kV air and ±8kV
contact discharge. It is assembled into an ultra-small
1.6x1.0x0.5mm lead-free DFN package. The small size
and high ESD surge protection make
UCLAMP0571P.TNT an ideal choice to protect cell
phone, digital cameras, audio players and many other
portable applications.
Package: DFN1610-2
Circuit Diagram
Applications
1.6
1.0
Mobile Phones
Battery Protection
Power Line Protection
Vbat pin for Mobile Devices
Hand Held Portable Applications
0.5
Marking Diagram
Ordering Information
Part Number
Packaging
UCLAMP0571P.TNT 3000/Tape & Reel
Reel Size
7 inch
Transparent top view
0571-87006810
www.dowosemi.cn
1/4
UCLAMP0571P.TNT
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
2200
W
Peak Pulse Current (8/20µs)
IPP
170
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
Test Condition
Min
Typ
VRWM
Breakdown Voltage
VBR
Max Unit
5
IT = 1mA
Reverse Leakage Current
IR
VRWM = 5V
Clamping Voltage
VC
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
IPP = 170A (8 x 20µs pulse)
Junction Capacitance
CJ
VR = 0V, f = 1MHz
5.2
5.6
V
V
1.0
µA
6
V
11
13
V
560
650
pF
Portion Electronics Parameter
Symbol
IT
IPP
Parameter
Test Current
Maximum Reverse Peak Pulse Current
Vc
Clamping Voltage @Ic
IF
Forward Current
VF
Forward Voltage @IF
0571-87006810
www.dowosemi.cn
2/4
UCLAMP0571P.TNT
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Junction Capacitance vs. Reverse Voltage
Voltage (V)
Clamping Voltage vs. Peak Pulse Current
-20
60
80
100
Time (nS)
Peak Pulse Power vs. Pulse Time
IEC61000−4−2 Pulse Waveform
120
100
80
60
40
50
75
100
125
150
Ambient Temperature_Ta(℃)
100
80
60
40
-20
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
0571-87006810
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
120
www.dowosemi.cn
3/4
60
UCLAMP0571P.TNT
DFN1610-2 Package Outline Drawing
e
D
h
b
E
L
A
Bottom View
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.75
0.80
0.85
0.030
0.032
0.034
c
0.10
0.15
0.20
0.004
0.006
0.008
D
1.55
1.60
1.65
0.062
0.064
0.066
h
SYM
A1
c
e
1.10 BSC
0.044 BSC
E
0.95
1.00
1.05
0.038
0.040
0.042
L
0.35
0.40
0.45
0.014
0.016
0.018
h
0.15
0.20
0.25
0.006
0.008
0.010
Suggested Land Pattern
Y3
Y2
SYM
DIMENSIONS
MILLIMETERS
INCHES
X
1.00
0.040
Y1
0.62
0.025
Y2
0.60
0.024
Y3
1.22
0.049
Z
1.85
0.074
Y1
Z
X
0571-87006810
www.dowosemi.cn
4/4
很抱歉,暂时无法提供与“UCLAMP0571P.TNT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29198
- 100+0.25418
- 300+0.23528
- 1000+0.22111
- 5000+0.20977
- 8000+0.20410
