S3B26.000000F1210F30 数据手册
5x7
SMDSMD
Crystal
3.2x2.5
Crystal
深圳市星通时频电子有限公司
SHENZHEN SCTF ELECTRONICS CO.,LTD
FEATURE
Rugged AT-cut crystal construction.
Miniature 3.2×2.5mm ceramic package.
Designed for automatic mounting and reflow soldering.
Embossed taping specification.
Pb-free and RoHS/Green compliant.
APPLICATIONS
● Ideally suited designed for Bluetooth wireless communication sets, HDD,DSN, PDA,
GPS,Digital Tuner,Wireless LAN and mobile phone.
Pb
Free
●Electrical Specifications 电气参数
Frequency Tolerance(△F)(at25℃)
±10ppm to ±30ppm
温度频差
Frequency Drift
±10ppm to ±30ppm※(See Notes)
工作温度范围
Operating Temperature Range
-20℃ - +70℃ / -40℃ - +85℃
储存温度范围
Storage Temperature Range
-40℃ - +85℃ /-55℃ - +125℃
老化
Aging(25℃)
±3ppm/ year max.
静电容
Shunt Capacitance(C0)
3pF max.
激励功率
Drive Level
10μw (100μW max.)
绝缘阻抗
Insulaton Resistance(Rs)
500 Megaohms Minimum at D.C100V
负载电容
Load Capacitance(CL)
Suggested by customer
UNIT(单位):mm(毫米)
3.2±0.1
※Notes:±10,±20,±30ppm (-20℃ to +70℃)
±20,±30,±50ppm (-40℃ to +85℃) or depends on customer
●Equivalent Series Resistance and Mode of Operation
等效阻抗和振荡模式
Frequency Range 频率范围
ESR(Ω)等效阻抗
Mode 振荡模式
12.000MHz≤ f <16.000MHz
100Ωmax
Fundamental
16.000MHz≤ f <20.000MHz
80Ωmax
Fundamental
20.000MHz≤ f <24.000MHz
60Ωmax
Fundamental
24.000MHz≤ f <54.000MHz
40Ωmax
Fundamental
4
3
1
2
1.2
0.1
1
2
4
3
1.7
12MHz to 54MHz
0.9
1.3
Frequency Range
调整频差
TYP0.8
频率范围
2.5±0.1
3.2x2.5mm Ceramic Surface Mount
0.7 MAX
Holder Type
0.7
05
●Mechanical Dimensions 外型尺寸
型号
1.3
2.1
suggested solder pad layout
Note) #2, #4 is connected with a cover
(Please connect with a GND or a power supply)
●Reflow Condition(回流焊条件)
260℃±5℃
150℃±5℃
120sec
10sec
CYCLE TIME:200sec Max.
The above specifications are standard for SCTF product
If you have special requirement please Contact SCTF sales with your enquiries
Tel:0086-0755-86097430,0086-0755-86097250
The above specifications are standard for HLX product
Fax:0086-0755-86097259
If you have special requirement please Contact HLX sales with your en
E-mail:sales@ sctf-crystal.com
http://www.sctf-crystal.com
Tel:0086-25-85238320,0086-25-85320830(Direct)
Fax:0086-25-85315213,85301856
S3B26.000000F1210F30 价格&库存
很抱歉,暂时无法提供与“S3B26.000000F1210F30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59789
- 50+0.49016
- 150+0.43630
- 500+0.39591
- 3000+0.31779
- 6000+0.30164
