High Frequency SMD Crystal
Actual Size
Actual Size
FEATURE
- Inverted-mesa structured quartz blanks for high frequency
in fundamental mode up to 400MHz.
- Tight tolerance 10 ppm available.
TYPICAL APPLICATION
- Wireless LAN, Telecom
- High-Speed, High-Volume Data Transmissions
XX Type
XX
DIMENSION (mm)
XV Type
RoHS Compliant Standard
SOLDER PAD LAYOUT (mm)
[ T O P V IE W ]
#1
#2
2.2
Marking #2 and #4 are connected to
metal cap of top
#2
0.9
1.5
[ B O T T O M V IE W ]
2.1
#1
#3
1.5
[ S ID E V IE W ]
GND #4
1.1
0.65 ± 0.1
2.5 ± 0.2
3.2 ± 0.2
#4
1.2
#3
XV
(XX)
1.0
(XX)
[ TOP VIEW ]
5.0±0.2
GND #4
#3
3.2±0.2
3.8
#1
[ BOTTOM VIEW ]
3.8
2.2
#2
1.5
0.9
2.2
#1
#2
metal cap of top
1.2
1.0max
[ SIDE VIEW ]
#4
#3
(XV)
1.2
(XV)
ELECTRICAL SPECIFICATION
Parameter
Min.
Storage Temp. Range
Standard Frequency
Level of Drive
Shunt Capacitance (C0)
Insulation Resistance
Aging
Typical
Max.
Unit
-55
125
122.326, 122.344,122.408, 122.430, 125, 156.125
10
300
3.0
500 MΩ@ DC100V
±3.0
MHz
µw
pF
ppm / year
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
EQUIVALENT SERIES RESISTANCE (E.S.R)
TYPE FREQUENCY
MODE
80MHz ≦Freq. ≦400 MHz
A1
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±5
±10
E.S.R
很抱歉,暂时无法提供与“XXBBBCNANF-16M”相匹配的价格&库存,您可以联系我们找货
