XC22M4-32.000-F08NNHP
    HCI(杭晶)
    SMD2520_4P
    频率:32MHz;频率公差:±10ppm;负载电容:8pF;
XC22M4-32.000-F08NNHP 数据手册
QUARTZ CRYSTAL UNIT XC22M4 QUARTZ CRYSTAL UNIT SMD 2.5X2.0MM IN CERAMIC SEAM SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Small dimensions 2.5x2.0x0.55 with 4 solder pads.  Highly reliable vacuum seam sealed ceramic package.  Tight tolerances and stabilities over temperature range.  Automotive compliance to AEC-Q200 available.  RoHS compliant, LEAD-FREE and HALOGEN-FREE. APPLICATIONS  Wireless LAN  Bluetooth  Mobil communication  Handheld equipment PRODUCT SPECIFICATIONS XC22M4 PARAMETER Nominal frequency range CONDITIONS / REMARKS 12.000 ~ 60.000MHz Crystal cut and mode AT-cut Frequency tolerance ±10ppm Frequency stability Operating temperature range / / —- Fundamental ±20ppm / ±30ppm —Other options available. ±10ppm ±15ppm Other options available. –20 to +70°C –30 to +85°C Other options available. Equivalent series resistance Load capacitance
XC22M4-32.000-F08NNHP 价格&库存
很抱歉,暂时无法提供与“XC22M4-32.000-F08NNHP”相匹配的价格&库存,您可以联系我们找货
