H.ELE.
Specifications for Approval
PRODUCT TYPE
Quartz Crystal HSX531S
NOMINAL FREQUENCY 20.000000MHz
H.ELE SAMPLE O/N
H.ELE P/N
EOS‐G80424‐1
X1H020000FK1H‐X
RELEASE DATE
VERSION
00
MSL
Level 01
GREEN PRODUCT
Pb free RoHS Compliant
2016/09/02
HF‐Halogen free REACH Compliant
CUSTOMER P/N
APPLICATION & MODEL
APPROVED BY CUSTOMER
(DATE)
Harmony Electronics Corp.
Country of Origin: Taiwan Factory
Thailand Factory
China Factory
F. S. TSAI Y. W. LEE U. F. CHEN
(APPROVE) (CHECK) (PREPARE)
HARMONY ELECTRONICS CORPRATION
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
TEL: 886‐2‐26588883 Email: contactus@hele.com.tw
REV. No.
DATE
REASON
2016/09/02 New
REVISE CONTENTS
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
Contents
ITEM
PAGE
1. QUARTZ CRYSTAL UNIT SPECIFICATION
1
2. DIMENSIONS
2
3. MARKING
2
4. INSIDE STRUCTURE
3
5. HANDLING SUGGESTIONS
3‐4
6. EMBOSS CARRIER TAPE&REEL
4‐5
7. PACKAGE
5‐6
8. MECHANICAL PERFORMANCE
6‐7
9. ENVIRONMENTAL PERFORMANCE
7
10. APPENDIX
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
1. QUARZ CRYSTAL UNIT SPECIFICATION
Electrical Spec.
Items
1. Frequency (FL)
Min
Type
Max
20.000000
2. Mode of oscillation:
Unit
Fundamental
3. Frequency tolerance
Notes
MHz
‐30
+30
ppm
50
Ω
SERIES
5. Storage temperature range
‐40
+85
6. Operable temperature range
‐20
+85
7. Temperature stability
‐50
+50
ppm
8. Loading capacitance (CL)
20.0
pF
9. Drive level (DL)
10
300
μW
10. Shunt Capacitance (C0)
2.0
pF
500
MΩ
at DC 100V
12. Aging:
‐5
+5
23. Circuit:
Measured in HP/E5100A,S&A 250B
4. Equivalent resistance (RR)
11. Insulation resistance
at 25℃±3℃
‐20℃ ~ +85℃
ppm/Year
Note:
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
1
2. DIMENSION
* Note: The Index mark was defined by the BASE suppliers.
3. MARKING
Note:
1. Laser marking.
2. Date Code:
Y=Year
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2023
2024
2025
2026
2027
2028
2029
1
2
3
4
5
6
7
8
9
Code
M=Month Jan.
Code
A
Feb.
Mar.
Apr.
May.
Jun.
Jul.
Aug.
Sep.
Oct.
Nov.
Dec.
B
C
D
E
F
G
H
J
K
L
M
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
2
4. INSIDE STRUCTURE
Reference drawing
No.
Component
(1)
Base
(2)
Lid
(3)
Kovar
Material
Al2O3
Fe‐ Ni ‐Co
Fe‐ Ni ‐Co
Rectangular
At‐Cut
(4)
Crystal Blank
SiO2
(5)
(6)
Electrode
PAD
Connective
Adhesive
W, Ni, Au
(7)
Note
Ag
※The use prohibition chemistry substance of Table 1 of DHE‐0204‐1 (HE‐QA‐24) is not included in
this item.
5. HANDDLING SUGGESTION
Reflow Conditions
Please stay with our proposed reflow
conditions and do soldering 2 times max.
(1) Preheat
160~180deg.C 120 sec.
(2) Primary heat 220 deg.C 60 sec.
(3) Peak
260 deg.C 10 sec. Max.
Manual Solder iron (Example)
Bit temp.: 350℃ max., Time: 3sec max. ,
Each terminal solder a 1 time max.
Mounting Conditions
Our products are suitable for most automated SMT processes. However, we strongly advise all
our customers to conduct SMT sampling prior to mass production in order to make sure
production processes will not affect the properties and specifications of our product.
Seal welding and mounting procedures involving the use of ultra‐sonic processes are not
recommended and will affect and/or damage the internal properties of our product.
Excessive shock during the mounting process will also affect the product and we strongly
recommend setting SMT conditions to minimize such conditions.
If a possibility of the PCB being warped exists we strongly advise to ensure the degree of
warping will not affect the product.
Please also ensure the operating characteristics and or soldering conditions are all within the
specifications of use for our product.
Ultimately the worst case scenario of all the above will lead to cases of non‐oscillation but
other negative effects are also likely should our products be used in an inappropriate way.
Please note such cases of misuse and its related quality issues are not included in our product
warranty.
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
3
Cleansing Conditions
General cleaning solutions may be used to clean our products but we always recommend
testing to be performed prior to mass production processes. Ultrasonic cleaning procedures are
not recommended and we strongly advise other forms of cleansing to be evaluated first.
Unsuitable cleansing may lead to a number of negative effects such as damage to the product
surface, discoloration of the product, corrosion of the package, package contamination,
illegible marking, etc. Please note cases of unadvised treatment and its related quality issues
are not included in our product warranty.
Storage Conditions
Please ensure our products are preserved appropriately in their original packaging.
Irregular environmental instances of moisture will affect our product’s stability and may cause
problems such as frequency instability, soldering ability and conditions, package defects, and
other problems. It is essential to keep our products in a clean dust‐free environment out of
direct sunlight.
Our products’ storage conditions should at least meet the following condition:
Environmental Temperature: + 40 degrees Celsius Maximum
Relative Humidity: 80% Maximum
Please note storage instances which do not conform to our guidelines and the related quality
issues produced as an outcome are not included in our product warranty.
6. EMBOSS CARRIER TAPE AND REEL
Carrier Tape
2.0±0.05
1.55±0.05
8.0±0.1
12.0±0.2
5.5±0.05
0.30±0.05
1.75±0.1
5.4±0.1
4.0±0.1
1.4±0.1
3.6±0.1
User Direction of feed
Terminal
Empty Sealed
Empty Sealed
Components
Ledder
80mm(Min)
400mm(Min)
40mm(min)
Top Cover tape
Embossed Carrier tape
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
4
Reel
Standard Packing Quantity: 1,000PCS / REEL
180+0/-3
13.2±0.5
60.5±0.5
12
0°
3.0±0.2
13±0.5
16±1.4
Material of The Tape
Tape
Carrier tape
Top tape
Material
PS Conductive
Polyester
Joint of tape
The carrier‐tape and top cover‐tape should not be jointed.
Release strength of cover tape
It has to between 0.1N to 0.7N under
following condition.
Pulling direction: 165° to 180°
Speed: 300mm/min.
Other standards shall be based on JIS C 0806‐1990.
Otherwise unless specified.
7. PACKAGE
Label
Up side(Produce)
Under side(Fixing Hole)
One reel quantity: [1000pcs]&[3000pcs]
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
5
1 Top and bottom with 2.3cm thickness
foam-rubber cushion for protection
2 Carton's Q'TY:1~15 pcs.
3 Carton Type=A,B,C use 4 trigon pillar to fasten the Reel.
4 Need to add 3 pages dry agent in each outer box.
Item
Specifications
Code
Test Methods
1
Shock
Dropping from 100 cm height 3 times onto 30 mm hard wooden
board Refer to: JIS C 60068‐2‐6
A
2
Vibration
Frequency 10‐55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z
3 axes, 2 cycles and duration of 2 hours to each direction.
Refer to: MIL‐HDBK‐781A 6.5.2/ JIS C 60068‐2‐6
A
3
Leakage Test
Leak Rate 1.0x10‐9 Pa‐m3/sec. Max. Measured by Helium leak
detector.
4
Solder ability
After applying ROSIN Flux, dipping in solder bath at 245deg.C ±5deg.C
for 3 ±0.5 sec.
Refer to: JIS C 60068‐2‐20
Mount a sample on board.
Apply Pressure to the center of
board until it is bent to 3 mm
and hold for 5 ±1 sec.
Pressure speed: 0.5 mm/sec.
Refer to: EIAJ ET‐7403
5
Bending Strength
B
A
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
6
6
7
Mount a sample on the circuit
board. Apply pressure vertically
to the side of specimen attached
to the circuit board with the
pressure jig. Pressure: 5N for
10±1 sec.
Adhesion
Body strength
A
Apply pressure to the center of
body with the R0.5 pressure jig.
pressure :10N for 10±1sec
A
9. ENVIRONMENT PERFORMANCE
Item
1
Specifications
Code
Test Methods
Resistance of
Soldering Heat
Performing as the following reflow:
A
1
2
3
4
Humidity
Temperature 60℃±2℃, RH 90~95%, duration of 240 hours.
Back to room temperature first, then in 1~2 hours, the component
shall be checked.
Refer to: JIS C 60068‐2‐3
A
Storage in Low
Temperature
‐40deg.C ±2deg.C, duration of 240 hours.
Back to the room temperature first, then in 1~2 hours, the
component shall be checked.
Refer to: JIS C 60068‐2‐1
A
Storage in High
Temperature
+85deg.C ±2deg.C, duration of 240 hours.
A
Temperature cycles ‐40deg.C ±2deg.C (30min) +85deg.C ±2deg.C (30min) 25 cycles.
And Temperature Increasing/reducing time<3mins. Back to the
room temperature first, then in 1~2 hours, the component shall be
checked.
Refer to: JIS C 0025
Specifications code
A
A
Specifications
Frequency variation shall be within ±5ppm and equivalent resistance shall be within
±15% or 2Ω
B
More than 90% of lead shall be covered by new solder.
KAOHSIUNG
TAIPEI
THAILAND
SHENZHEN
S UZHOU
7
FACTORY LOCATION
HEAD OFFICE/TAIWAN FACTORY
SERVICE CENTER
TAIPEI OFFICE
NO.39, HUADONG RD., DALIAO DIST., DAFA INDUSTRIAL
PARK, KAOHSIUNG CITY 831, TAIWAN.
(114) 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT,
TAIPEI CITY 114, TAIWAN
TEL: 886‐2‐26588883
FAX: 886‐2‐26588683
CHINA FACTORY
CONTACT INFORMATION
JU YUAN INDUSTRIAL PARK, QIAO TANG ROAD, TANG
WEI COMMUNITY, FUYONG, BAOAN DISTRICT, SHEN
ZHEN CITY, CHINA (Post Code:518103).
E‐MAIL: contactus@hele.com.tw
THAILAND FACTORY
66MOO 5, KAONGU‐BEOKPRAI RD., T.BEOKPRAI, A.
BANPONG, RATCHABURI PROVINCE 70110, THAILAND.
