HY3708P/M/B/PS/PM
N-Channel Enhancement Mode MOSFET
Pin Description
Features
80V/170A
RDS(ON) = 3.8 m(typ.) @ VGS=10V
100% avalanche tested
Reliable and Rugged
G
G
D
D
S
S
TO-220FB-3L
Lead Free and Green Devices Available
G
S
D
TO-220FB-3S
TO-263-2L
(RoHS Compliant)
G
G
TO-3PS-3L
Applications
D
D
S
S
TO-3PM-3S
Power Management for Inverter Systems.
N-Channel MOSFET
Ordering and Marking Information
P
HY3708
Package Code
M
HY3708
YYXXXJWW G
YYXXXJWW G
PS
HY3708
PM
HY3708
YYXXXJWW G
YYXXXJWW G
B
HY3708
P : TO-220FB-3L
B: TO-263-2L
PM: TO-3PM-3S
YYXXXJWW G
Date Code
YYXXX WW
M : TO-220FB-3S
PS: TO-3PS-3L
Assembly Material
G : Lead Free Device
Note: HUAYI lead -free products contain molding compounds/die attach materials and 100% matte tin plate
Termination finish;which are fully compliant with RoHS. HUAYI lead -free products meet or exceed the leadFree requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature.
HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed
900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to
this pr-oduct and/or to this document at any time without notice.
www.hymexa.com
1
V1.0
HY3708P/M/B/PS/PM
Absolute Maximum Ratings
Symbol
Rating
Parameter
Unit
Common Ratings (TC=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
80
VGSS
Gate-Source Voltage
±25
Maximum Junction Temperature
175
°C
-55 to 175
°C
TC=25°C
170
A
TC=25°C
660**
A
TC=25°C
170
TC=100°C
114
TC=25°C
288
TC=100°C
144
TJ
TSTG
IS
Storage Temperature Range
Diode Continuous Forward Current
V
Mounted on Large Heat Sink
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance-Junction to Case
0.52
RJA
Thermal Resistance-Junction to Ambient
62.5
A
W
°C/W
Avalanche Ratings
EAS
Avalanche Energy, Single Pulsed
L=0.5mH
mJ
1168***
Note: * Repetitive rating ; pulse width limiited by junction temperature
** Drain current is limited by junction temperature
*** VD=64V
Electrical Characteristics
Symbol
Parameter
(TC = 25C Unless Otherwise Noted)
Test Conditions
HY3708
Min.
Typ.
Max.
80
1
10
Unit
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
VGS(th)
IGSS
RDS(ON)*
VGS=0V, IDS=250A
VDS=80V, VGS=0V
TJ=85°C
V
A
Gate Threshold Voltage
VDS=VGS, IDS=250A
2.0
3.0
4.0
V
Gate Leakage Current
VGS=±25V, VDS=0V
±100
nA
Drain-Source On-state Resistance
VGS=10V, IDS=85A
3.8
5.0
m
ISD=85 A, VGS=0V
0.8
1.2
V
30
ns
52
nC
Diode Characteristics
VSD *
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
www.hymexa.com
ISD=85A, dlSD/dt=100A/s
2
V1.0
HY3708P/M/B/PS/PM
Electrical Characteristics (Cont.)
Symbol
Parameter
Test Conditions
HY3708
Min.
Typ.
Max.
1.8
6109
995
530
28
18
42
54
152
25
53
Unit
Dynamic Characteristics
RG
Gate Resistance
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
td(ON)
Turn-on Delay Time
Tr
Turn-on Rise Time
td(OFF)
Turn-off Delay Time
Tf
VGS=0V,VDS=0V,F=1MHz
VGS=0V,
VDS=25V,
Frequency=1.0MHz
VDD=40V, R G=6 ,
I DS =85A, V GS=10V,
Turn-off Fall Time
pF
ns
Gate Charge Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=64V, VGS=10V,
IDS=85A
nC
Note * : Pulse test ; pulse width 300s, duty cycle2%.
www.hymexa.com
3
V1.0
HY3708P/M/B/PS/PM
Typical Operating Characteristics
Drain Current
Power Dissipation
350
180
160
ID - Drain Current (A)
Ptot - Power (W)
300
250
200
150
100
50
limited by package
140
120
100
80
60
40
o
TC=25 C,VG=10V
o
TC=25 C
80 100 120 140 160 180 200
Tc - Case Temperature (°C)
60 80 100 120 140 160 180 200
Safe Operation Area
it
100us
ds
on
)L
im
100
1ms
R
1000
10
10ms
DC
1
o
TC=25 C
0.1
0.01
0.1
1
10
100 300
VDS - Drain - Source Voltage (V)
Thermal Transient Impedance
1
Normalized Effective Transient
Duty = 0.5
0.2
0.1
0.1
0.05
0.01
0.02
0.01
0.001
Single
Mounted on minimum pad
o
RJA : 62.5 C/W
0.0001
0.0001
0.001
0.1
0.01
1
10
Square Wave Pulse Duration (sec)
www.hymexa.com
4
V1.0
HY3708P/M/B/PS/PM
Typical Operating Characteristics (Cont.)
Drain-Source On Resistance
Output Characteristics
240
6.0
210
RDS(ON) - On - Resistance (mΩ)
VGS= 5.5,6,7,8,9,10V
180
5V
150
120
4.5V
90
4V
60
30
1.0
2.0
3.0
4.0
5.0
5.5
5.0
4.0
3.5
3.0
2.5
6.0
VGS=10V
4.5
80
120
160
200
Gate-Source On Resistance
14
IDS=85A
1.6
IDS =250A
Normalized Threshold Voltage
12
10
8
6
4
2
1.2
1.0
0.8
0.6
0.4
3
4
5
6
7
8
9
0.2
-50 -25
10
VGS - Gate - Source Voltage (V)
www.hymexa.com
50
75 100 125 150 175
Tj - Junction Temperature (°C)
5
V1.0
HY3708P/M/B/PS/PM
Source-Drain Diode Forward
200
2.4
100
IDS = 85A
2.0
o
1.8
IS - Source Current (A)
Normalized On Resistance
2.2
VGS = 10V
1.6
1.4
1.2
1.0
0.8
10
o
Tj=25 C
1
0.6
0.4
o
0.2
-50 -25
RON@Tj=25 C: 3.8m
50
0.1
0.0
75 100 125 150 175
0.8
1.0
1.2
Gate Charge
VGS - Gate-source Voltage (V)
9000
7500
Ciss
6000
4500
3000
Coss
Crss
8
16
VDS= 64V
IDS= 85A
8
7
6
5
4
3
2
1
24
32
www.hymexa.com
1.4
10
9
Capacitance
10500
VSD - Source - Drain Voltage (V)
Frequency=1MHz
1500
0.2
12000
C - Capacitance (pF)
Tj=175 C
64
96
128
160
QG - Gate Charge (nC)
6
V1.0
HY3708P/M/B/PS/PM
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
7
V1.0
HY3708P/M/B/PS/PM
'HYLFH3HU8QLW
3DFNDJH7\SH
8QLW
4XDQWLW\
72)%/
7XEH
3DFNDJH,QIRUPDWLRQ
72)%/
&20021',0(16,216
6
很抱歉,暂时无法提供与“HY3708B”相匹配的价格&库存,您可以联系我们找货
