LSE80R680GT
LSE80R680GT
    LONTEN(龙腾半导体)
    TO-263(D²Pak)
    类型:-;漏源电压(Vdss):-;连续漏极电流(Id):-;功率(Pd):-;导通电阻(RDS(on)@Vgs,Id):-;阈值电压(Vgs(th)@Id):-;栅极电荷(Qg@Vgs):-;输入电...
LSE80R680GT 数据手册
LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Lonten N-channel 800V, 8A, 0.68Ω LonFETTM Power MOSFET Description Product Summary LonFET VDS @ Tj,max 850V RDS(on),max 0.68Ω device has extremely low on resistance, making it IDM 8A especially suitable for applications which require Qg,typ 19.5nC TM Power MOSFET is fabricated using advanced super junction technology. The resulting superior power density and outstanding efficiency. Features  Ultra low RDS(on)  Ultra low gate charge (typ. Qg = 19.5nC)  100% UIS tested  RoHS compliant TO-220 TO-220MF TO-263 TO-262 D Applications TO-252  Power faction correction (PFC).  Switched mode power supplies (SMPS).  Uninterruptible power supply (UPS). TO-251 G S TO-247 Pb N-Channel MOSFET Absolute Maximum Ratings Parameter Drain-Source Voltage Continuous drain current Symbol Value Unit 800 V 8 A 5 A 24 A VGSS ±30 V EAS 235 mJ IAR 8 A VDSS ( TC = 25°C ) ID ( TC = 100°C ) Pulsed drain current IDM 1) Gate-Source voltage Avalanche energy, single pulse 2) Avalanche current, repetitive 3) Power Dissipation TO-220MF ( TC = 25°C ) - Derate above 25°C Power Dissipation TO-220/TO-252/TO-263/TO-247 31 W 0.25 W/°C PD ( TC = 25°C ) - Derate above 25°C 83 W 0.66 W/°C -55 to +150 °C Operating and Storage Temperature Range TJ, TSTG Continuous diode forward current IS 8 A Diode pulse current IS,pulse 24 A Version 1.3,Apr-2020 1 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Thermal Characteristics TO-220/TO-252/TO-263/TO-247 Parameter Symbol Value Unit Thermal Resistance, Junction-to-Case RθJC 1.5 °C/W Thermal Resistance, Junction-to-Ambient RθJA 62 °C/W Tsold 260 °C Value Unit Soldering temperature, wavesoldering only allowed at leads. (1.6mm from case for 10s) Thermal Characteristics TO-220MF Parameter Symbol Thermal Resistance, Junction-to-Case RθJC 4 °C/W Thermal Resistance, Junction-to-Ambient RθJA 62.5 °C/W Tsold 260 °C Soldering temperature, wavesoldering only allowed at leads. (1.6mm from case for 10s) Package Marking and Ordering Information Device Device Package Marking Units/Tube LSC80R680GT TO-220 LSC80R680GT 50 LSD80R680GT TO-220MF LSD80R680GT 50 LSE80R680GT TO-263 LSE80R680GT LSF80R680GT TO-262 LSF80R680GT LSG80R680GT TO-252 LSG80R680GT LSH80R680GT TO-251 LSH80R680GT 72 LSB80R680GT TO-247 LSB80R680GT 30 Electrical Characteristics Parameter Units/Reel 800 50 2500 Tc = 25°C unless otherwise noted Symbol Test Condition Min. Typ. Max. Unit Static characteristics Drain-source breakdown voltage BVDSS VGS=0 V, ID=0.25 mA 800 - - V Gate threshold voltage VGS(th) VDS=VGS, ID=0.25mA 2.5 3.5 4.5 V Drain cut-off current IDSS VDS=800 V, VGS=0 V, μA Tj = 25°C - - 1 Tj = 125°C - 10 - Gate leakage current, Forward IGSSF VGS=30 V, VDS=0 V - - 100 nA Gate leakage current, Reverse IGSSR VGS=-30 V, VDS=0 V - - -100 nA Drain-source on-state resistance RDS(on) VGS=10 V, ID=4 A - Tj = 25°C - 0.58 0.68 Ω Tj = 150°C - 1.5 - Gate resistance RG f=1 MHz, open drain - 7.6 - Input capacitance Ciss VDS = 100 V, VGS = 0 V, - 873 - Output capacitance Coss f = 250 kHz - 26 - Ω Dynamic characteristics Version 1.3,Apr-2020 2 pF www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Reverse transfer capacitance Crss - 2.54 - Turn-on delay time td(on) - 12 - Rise time tr VDD = 400V, ID = 4A - 30 - Turn-off delay time td(off) RG = 10Ω, VGS=10V - 60 - Fall time tf - 15 Gate to source charge Qgs - 4.5 - Gate to drain charge Qgd VDD=640 V, ID=4A, - 7.2 - Gate charge total Qg VGS=0 to 10 V - 19.5 - - 5 - V - - 1.4 V - 245 - ns - 2.33 - μC - 19 - A ns - Gate charge characteristics Vplateau nC Reverse diode characteristics Diode forward voltage VSD Reverse recovery time trr Reverse recovery charge Qrr Peak reverse recovery current Irrm VGS=0 V, IF=4A VR=400 V, IF=4A, dIF/dt=100 A/μs Notes: 1. Limited by maximum junction temperature, maximum duty cycle is 0.75. 2. IAS = 2.8A, VDD = 60V, Starting Tj= 25°C. 3. Repetitive Rating: Pulse width limited by maximum junction temperature. Version 1.3,Apr-2020 3 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Electrical Characteristics Diagrams Figure 1. On-Region Characteristics Figure 2. Transfer Characteristics Common Source VDS=20 V Pulse test VGS=10V VGS=7V Common Source Tc = 25°C Pulse test TC=25℃ VGS=6.5V TC=125℃ VGS=6V VGS=5.5V Drain−source voltage VDS (V) Gate−source voltage VGS (V) Figure 3. On-Resistance Variation vs. Drain Current Figure 4. Threshold Voltage vs. Temperatur VGS = 10V IDS=0.25 mA Pulse test Tc = 25°C Pulse test Drain current ID (A) Junction temperature Tj (°C) Figure 5. Breakdown Voltage vs. Temperature Figure 6. On-Resistance vs. Temperature VGS=0 V IDS=0.25 mA Pulse test VGS=10 V IDS=3.5 A Pulse test Junction temperature Tj (°C) Version 1.3,Apr-2020 Junction temperature Tj (°C) 4 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Figure 7. Capacitance Characteristics Figure 8. Gate Charge Characterist Ciss = Cgs + Cgd (Cds = shorted) Coss = Cds + Cgd Crss = Cgd Notes: f = 250 kHz VGS=0 V VDS=640 V IDS = 4A Ciss Coss Crss Drain-Source Voltage VDS (V) Total Gate Charge QG (nC) Figure 9.1 Maximum Safe Operating Area Figure 9.2 Maximum Safe Operating Area TO-220MF TO-220/TO-252/TO-263/TO-247 100us10us 10us 1ms 100us 1ms Limited by Rdson Limited by Rdson DC Drain-Source Voltage VDS (V) DC Drain-Source Voltage VDS (V) Figure 10.1 Power Dissipation vs. Temperature Figure 10.2 Power Dissipation vs. Temperature TO-220MF TO-220/TO-252/TO-263/TO-247 Case temperature Tc (°C) Case temperature Tc (°C) Version 1.3,Apr-2020 5 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Gate Charge Test Circuit & Waveform Switching Test Circuit & Waveforms Unclamped Inductive Switching Test Circuit & Waveforms Version 1.3,Apr-2020 6 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Mechanical Dimensions for TO-220 COMMON DIMENSIONS SYMBOL MM INCH MIN NOM MAX MIN NOM MAX A 4.37 4.57 4.70 0.172 0.180 0.185 A1 1.25 1.30 1.40 0.049 0.051 0.055 A2 2.20 2.40 2.60 0.087 0.094 0.102 b 0.70 0.80 0.95 0.028 0.031 0.037 b2 1.17 1.27 1.47 0.046 0.050 0.058 c 0.45 0.50 0.60 0.018 0.020 0.024 D 15.10 15.60 16.10 0.594 0.614 0.634 D1 8.80 9.10 9.40 0.346 0.358 0.370 D2 5.50 — — 0.217 — — E 9.70 10.00 10.30 0.382 0.394 0.406 E3 7.00 — — 0.276 — — e 2.54BSC 0.1BSC e1 5.08BSC 0.2BSC H1 6.25 6.50 6.85 0.246 0.256 0.270 L 12.75 13.50 13.80 0.502 0.531 0.543 L1 — 3.10 3.40 — 0.122 0.134 Øp 3.40 3.60 3.80 0.134 0.142 0.150 Q 2.60 2.80 3.00 0.102 0.110 0.118 TO-220 Part Marking Information Lonten Logo Lonten LSC80R680GT “AB” Foundry & Assembly Code ABYWW99 Part Number “99” Manufacturing Code “YWW” Date Code Version 1.3,Apr-2020 7 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Mechanical Dimensions for TO-220MF COMMON DIMENSIONS SYMBOL MM INCH MIN NOM MAX MIN NO MA E 9.96 10.1 10.3 0.39 0.40 0.40 A 4.50 4.70 4.90 0.17 0.18 0.19 A1 2.34 2.54 2.74 0.09 0.10 0.10 A2 0.30 0.45 0.60 0.01 0.00 0.02 A4 2.65 2.76 2.96 0.10 0.10 0.11 C 0.40 0.50 0.65 0.01 0.02 0.02 D 15.57 15.8 16.1 0.61 0.62 0.63 H1 6.70REF e 0.264REF 2.54BSC 0.1BSC ØP 3.03 3.18 3.38 0.11 0.12 0.13 L 12.68 12.9 13.2 0.49 0.51 0.52 L1 2.88 3.03 3.18 0.11 0.11 0.12 ØP3 3.15REF 0.124REF F3 3.15 3.30 3.45 0.12 0.13 0.13 G3 1.25 1.35 1.55 0.04 0.05 0.06 b1 1.18 1.28 1.43 0.04 0.05 0.05 b2 0.70 0.80 0.95 0.02 0.03 0.03 TO-220MF Part Marking Information Lonten Logo “AB” Foundry & Assembly Code “YWW” Date Code Version 1.3,Apr-2020 Lonten LSD80R680GT ABYWW99 Part Number “99” Manufacturing Code 8 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Mechanical Dimensions for TO-251 COMMON DIMENSIONS SYMBOL MM MIN NOM MAX A 2.20 2.30 2.38 A2 0.97 1.07 1.17 b 0.68 0.78 0.90 b2 0.00 0.04 0.10 b2’ 0.00 0.04 0.10 b3 5.20 5.33 5.46 c 0.43 0.53 0.61 D 5.98 6.10 6.22 D1 5.30REF E 6.40 6.60 6.73 E1 4.63 — — e 2.286BSC H 16.22 16.52 16.82 L1 9.15 9.40 9.65 L3 0.88 1.02 1.28 L5 1.65 1.80 1.95 TO-251 Part Marking Information Lonten Logo “AB” Foundry & Assembly Code Lonten LSH80R680GT ABYWW99 Part Number “99” Manufacturing Code “YWW” Date Code Version 1.3,Apr-2020 9 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Mechanical Dimensions for TO-252 COMMON DIMENSIONS SYMBOL mm MIN NOM MAX A 2.20 2.30 2.38 A1 0.00 — 0.20 A2 0.97 1.07 1.17 b 0.68 0.78 0.90 b3 5.20 5.33 5.46 c 0.43 0.53 0.61 D 5.98 6.10 6.22 D1 5.30REF E 6.40 E1 4.63 e 6.60 6.73 — — 2.286BSC H 9.40 L 1.38 10.10 10.50 1.50 1.75 L1 2.90REF L2 0.51BSC L3 0.88 — 1.28 L4 0.50 — 1.00 L5 1.65 1.80 1.95 θ 0° — 8° TO-252 Part Marking Information Lonten Logo “AB” Foundry & Assembly Code Lonten LSG80R680GT ABYWW99 Part Number “99” Manufacturing Code “YWW” Date Code Version 1.3,Apr-2020 10 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Mechanical Dimensions for TO-263 COMMON DIMENSIONS SYMBOL MM INCH MIN NOM MAX MIN NOM MAX A 4.37 4.57 4.77 0.172 0.180 0.188 A1 1.22 1.27 1.42 0.048 0.050 0.056 A2 2.49 2.89 2.89 0.098 0.114 0.114 A3 0.00 0.13 0.25 0.000 0.005 0.010 b 0.70 0.81 0.96 0.028 0.032 0.034 b1 1.17 1.27 1.47 0.046 0.050 0.058 c 0.30 0.38 0.53 0.012 0.015 0.021 D1 8.50 8.70 8.90 0.335 0.343 0.350 D4 6.60 — — 0.260 — — E 9.86 10.16 10.36 0.389 0.400 0.408 E5 7.06 — — 0.278 — — e 2.54 BSC 0.100 BSC H 14.70 15.10 15.50 0.579 0.594 0.610 H2 1.07 1.27 1.47 0.042 0.050 0.058 L 2.00 2.30 2.60 0.079 0.091 0.102 L1 1.40 1.55 1.70 0.055 0.061 0.067 L4 θ 0.25 BSC 0° 5° 0.010 BSC 9° 0° 0.197° 0.354° TO-263 Part Marking Information Lonten Logo “AB” Foundry & Assembly Code “YWW” Date Code Version 1.3,Apr-2020 Lonten LSE80R680GT ABYWW99 Part Number “99” Manufacturing Code 11 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Mechanical Dimensions for TO-262 TO-262 Part Marking Information Lonten Logo “AB” Foundry & Assembly Code “YWW” Date Code Version 1.3,Apr-2020 Lonten LSF80R680GT ABYWW99 Part Number “99” Manufacturing Code 12 www.lonten.cc LSB80R680GT/LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Mechanical Dimensions for TO-247 SYMBOL mm MIN NOM MAX A 4.80 5.00 5.20 A1 2.21 2.41 2.59 A2 1.85 2.00 2.15 b 1.11 1.21 1.36 b2 1.91 2.01 2.21 b4 2.91 3.01 3.21 c 0.51 0.61 0.75 D 20.80 21.00 21.30 D1 16.25 16.55 16.85 E 15.50 15.80 16.10 E1 13.00 13.30 13.60 E2 4.80 5.00 5.20 E3 2.30 2.50 2.70 e 5.44BSC L 19.82 19.92 20.22 L1 — — 4.30 ØP 3.40 3.60 3.80 ØP1 — — 7.30 S 6.15BSC TO-247 Part Marking Information Lonten Logo “AB” Foundry & Assembly Code Lonten LSB80R680GT ABYWW99 Part Number “99” Manufacturing Code “YWW” Date Code Version 1.3,Apr-2020 13 www.lonten.cc LSC80R680GT/LSD80R680GT/LSE80R680GT/ LSF80R680GT/LSG80R680GT/LSH80R680GT LonFET Disclaimer The content specified herein is for the purpose of introducing LONTEN's products (hereinafter "Products"). The information given in this document shall in no event be regarded as a guarantee of conditions or characteristics. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. LONTEN does not assume any liability for infringement of patents, copyrights, or other intellectual property rights of third parties by or arising from the use of the Products or technical information described in this document. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). LONTEN shall bear no responsibility in any way for use of any of the Products for the above special purposes. Although LONTEN endeavors to improve the quality and reliability of its products, semiconductor products have specific characteristics such as the occurrence of failure at a certain rate and malfunctions under certain use conditions. Please be sure to implement safety measures to guard them against the possibility of physical injury, and injury or damage caused by fire in the event of the failure of a LONTEN product. The content specified herein is subject to change for improvement without notice. When using a LONTEN product, be sure to obtain the latest specifications. Version 1.3,Aug-2019 14 www.lonten.cc
LSE80R680GT 价格&库存
很抱歉,暂时无法提供与“LSE80R680GT”相匹配的价格&库存,您可以联系我们找货
