IRF5305STR
www.VBsemi.com
P-Channel 60 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 60
RDS(on) () Max.
ID (A)
0.048at VGS = - 10 V
- 35
0.060at VGS = - 4.5 V
- 30
Qg (Typ.)
60
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg and UIS Tested
• Compliant to RoHS Directive 2002/95/EC
APPLICATIONS
S
• Power Switch
• Load Switch in High Current Applications
• DC/DC Converters
D2PAK (TO-263)
G
G D
D
S
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
- 60
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 150 °C)
TC = 25 °C
TC = 70 °C
Pulsed Drain Current (t = 300 µs)
Avalanche Current
Single Avalanche Energya
Maximum Power Dissipationa
Operating Junction and Storage Temperature Range
L = 0.1 mH
TC = 25 °C
TA = 25 °Cc
ID
Unit
V
- 35
- 30
IDM
- 100
IAS
- 32
EAS
51
A
mJ
b
PD
61
6.1
W
TJ, Tstg
- 55 to 150
°C
Unit
THERMAL RESISTANCE RATINGS
Parameter
Symbol
Limit
Junction-to-Ambient (PCB Mount)c
RthJA
60
Junction-to-Case (Drain)
RthJC
3
°C/W
Notes:
a. Duty cycle 1 %.
b. See SOA curve for voltage derating.
c. When mounted on 1" square PCB (FR-4 material).
服务热线:400-655-8788
1
IRF5305STR
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VDS = 0 V, ID = - 250 µA
- 60
VGS(th)
VDS = VGS, ID = - 250 µA
-1
IGSS
VDS = 0 V, VGS = ± 20 V
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
On-State Drain Currenta
Drain-Source On-State Resistancea
Forward Transconductancea
IDSS
- 2.5
± 250
VDS = - 60 V, VGS = 0 V
-1
VDS = - 60 V, VGS = 0 V, TJ = 125 °C
- 50
VDS = - 60 V, VGS = 0 V, TJ = 150 °C
- 250
VDS - 10 V, VGS = - 10 V
ID(on)
RDS(on)
gfs
- 30
V
nA
µA
A
VGS = - 10 V, ID = - 14 A
0.048
VGS = - 4.5 V, ID = - 12 A
0.060
VDS = - 20 V, ID = - 14 A
40
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
Gate-Drain
Chargec
200
67
VDS = - 30V , VGS = - 10 V, ID = - 14 A
Rise Timec
Fall Timec
f = 1 MHz
td(on)
tr
c
td(off)
nC
13.5
14
Rg
Turn-On Delay Timec
pF
120
Qgd
Gate Resistance
Turn-Off Delay Time
1650
VGS = 0 V, VDS = - 30 V, f = 1 MHz
VDD = - 30 V, RL = 2
ID - 10 A, VGEN = - 10 V, Rg = 1
tf
Drain-Source Body Diode Ratings and Characteristics TC = 25 °C
0.5
2.5
5
10
63
12
Pulsed Current
ISM
- 100
Forward Voltagea
VSD
Reverse Recovery Time
Peak Reverse Recovery Current
Reverse Recovery Charge
IF = - 10 A, VGS = 0 V
- 0.8
IF = - 10 A, dI/dt = 100 A/µs
40
trr
IRM(REC)
Qrr
ns
b
IS
Continuous Current
A
- 1.5
V
38
57
ns
2.3
3.5
A
60
nC
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
IRF5305STR
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
40
0.100
VGS = 10 V thru 4 V
0.080
RDS(on) - On-Resistance (Ω)
ID - Drain Current (A)
30
VGS = 3 V
VGS = 4.5 V
0.060
VGS = 10 V
0.040
0.020
0.000
0.5
1.5
60
VDS - Drain-to-Source Voltage (V)
Output Characteristics
80
100
On-Resistance vs. Drain Current
1.0
0.040
ID = 14 A
0.034
0.8
0.6
TC = 25 °C
0.4
0.2
TC = 125 °C
TC = - 55 °C
2
1
0.016
3
4
0.010
5
2
4
6
8
10
VGS - Gate-to-Source Voltage (V)
Transfer Characteristics
On-Resistance vs. Gate-to-Source Voltage
50
10
TC = 25 °C
ID = 14 A
TC = - 55 °C
40
g fs - Transconductance (S)
TJ = 125 °C
0.022
TJ = 25 °C
30
TC = 125 °C
8
VDS = 30 V
6
VDS =25 V
4
VDS = 48 V
2
12
18
Transconductance
24
30
28
42
56
70
Qg - Total Gate Charge (nC)
Gate Charge
服务热线:400-655-8788
3
IRF5305STR
www.VBsemi.com
2.3
100
ID = 250 μA
VGS(th) (V)
IS - Source Current (A)
2.0
TJ = 150 °C
10
1.7
TJ = 25 °C
1
1.4
1.1
- 50
0.1
0.0
0.2
0.4
0.6
0.8
1.0
1.2
- 25
50
75
100
VSD - Source-to-Drain Voltage (V)
TJ - Temperature (°C)
Source-Drain Diode Forward Voltage
Threshold Voltage
125
150
125
150
51
2000
VDS (V) Drain-to-Source Voltage
ID = 250 μA
C - Capacitance (pF)
1600
Ciss
1200
800
400
Coss
49
47
45
Crss
43
- 50
40
- 25
50
75
100
Drain Source Breakdown vs. Junction Temperature
Capacitance
2.2
40
VGS = 10 V
1.9
30
RDS(on) - On-Resistance (Normalized)
ID = 14 A
1.6
VGS = 4.5 V
1.3
1.0
0.7
- 50
50
75
100
125
150
TJ - Junction Temperature (°C)
50
75
100
TC - Case Temperature (°C)
On-Resistance vs. Junction Temperature
Current Derating
125
150
服务热线:400-655-8788
4
IRF5305STR
www.VBsemi.com
1000
100
IDAV (A)
TJ = 150 °C
100
TJ = 25 °C
10
100 μs
10
1 ms
Limited by R DS(on)*
10 ms
DC, 1 s, 100 ms
1
0.1
1
0.000001
TC = 25 °C
Single Pulse
0.01
0.00001
0.0001
0.001
0.01
0.1
0.1
Time (s)
Single Pulse Avalanche Current Capability vs. Time
BVDSS Limited
1
10
* VGS > minimum VGS at which RDS(on) is specified
100
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.02
0.05
Single Pulse
0.01
10-4
10-3
10-2
10-1
Square Wave Pulse Duration (s)
1
10
30
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
5
IRF5305STR
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead
0.420
0.355
0.635
(16.129)
(9.017)
(10.668)
0.145
(3.683)
0.135
(3.429)
0.200
0.050
(5.080)
(1.257)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
6
IRF5305STR
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
