HY4504P/B
N-Channel Enhancement Mode MOSFET
Features
Pin Description
40V/250A
RDS(ON) = 2.3 m(typ.) @ VGS=10V
100% avalanche tested
Reliable and Rugged
Lead Free and Green Devices Available
S
GD
(RoHS Compliant)
GD
S
TO-220FB-3L
TO-263-2L
Applications
z
Switching Application
z
Power Management for DC/DC
Ordering and Marking Information
P
HY4504
Package Code
P : TO-220FB-3L
B
HY4504
Date Code
YYXXX WW
YYXXXJWW G YYXXXJWW G
N-Channel MOSFET
B: TO-263-2L
Assembly Material
G : Lead Free Device
Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hymexa.com
1
V1.0
HY4504P/B
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (TC=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
40
VGSS
Gate-Source Voltage
±20
Maximum Junction Temperature
175
°C
-55 to 175
°C
250
A
805**
A
TJ
TSTG
IS
Storage Temperature Range
Diode Continuous Forward Current
TC=25°C
V
Mounted on Large Heat Sink
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
TC 25°C
TC 25°C
250
TC 100°C
A
162
TC 25°C
288
W
144
TC=100°C
RJC
Thermal Resistance-Junction to Case
0.52
RJA
Thermal Resistance-Junction to Ambient
62.5
°C/W
Avalanche Ratings
EAS
Avalanche Energy, Single Pulsed
L=0.5mH
J
1.8***
Note: * Repetitive rating ; pulse width limiited by junction temperature
** Drain current is limited by junction temperature
*** VD=32V
Electrical Characteristics
Symbol
Parameter
(TC = 25C Unless Otherwise Noted)
Test Conditions
HY4504
Min.
Typ.
Max.
40
1
10
Unit
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
VGS(th)
IGSS
RDS(ON)*
VGS=0V, IDS=250A
VDS=
=40V, VGS 0V
TJ 85°C
V
A
Gate Threshold Voltage
VDS=VGS, IDS=250A
2.0
3.0
4.0
V
Gate Leakage Current
VGS=±20V,
VDS 0V
±100
nA
Drain-Source On-state Resistance
VGS=10V, IDS=125A
2.3
3.0
m
Diode Characteristics
VSD *
Diode Forward Voltage
ISD=125 A, VGS=0V
0.8
1.2
V
trr
Reverse Recovery Time
ISD=125A,
38
ns
Qrr
Reverse Recovery Charge
dlSD/dt=100A/s
62
nC
www.hymexa.com
2
V1.0
HY4504P/B
Electrical Characteristics (Cont.)
Symbol
Parameter
Test Conditions
HY4504
Min.
Typ.
Max.
1.0
6985
1863
682
35
62
195
30
80
Unit
Dynamic Characteristics
RG
Gate Resistance
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
td(ON)
Turn-on Delay Time
Tr
Turn-on Rise Time
td(OFF)
Turn-off Delay Time
Tf
VGS=0V,V=
= 1MHz
DS 0V,F
VGS=0V,
VDS=25V,
Frequency=1.0MHz
VDD=20V, R G=6 ,
I DS =125A, VGS=10V,
Turn-off Fall Time
pF
ns
Gate Charge Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=32V, VGS=10V,
IDS=125A
nC
Note * : Pulse test ; pulse width 300s, duty cycle2%.
www.hymexa.com
3
V1.0
HY4504P/B
Typical Operating Characteristics
Power Dissipation
Drain Current
ID - Drain Current (A)
Ptot - Power (W)
250
200
150
100
262
250
limited by package
200
175
150
125
100
50
75
o
TC=25 C
o
50
20 40 60 80 100 120 140 160 180 200
TC=25 C,VG=10V
Tc - Case Temperature (°C)
Safe Operation Area
1000
100
it
im
)L
n
s(o
Rd
100us
10ms
1ms
10
DC
1
0.1
10
1
100
400
VDS - Drain - Source Voltage (V)
Thermal Transient Impedance
Normalized Effective Transient
1
Duty = 0.5
0.2
0.1
0.1
0.05
0.01
0.02
0.001
0.01
Mounted on minimum pad
o
RJA : 62.5 C/W
Single
0.0001
0.0001
0.001
0.1
0.01
1
10
Square Wave Pulse Duration (sec)
www.hymexa.com
4
V1.0
HY4504P/B
Typical Operating Characteristics (Cont.)
Drain-Source On Resistance
Output Characteristics
400
4.5
VGS= 5.5,6,7,8,9,10V
RDS(ON) - On - Resistance (mΩ)
350
300
5V
250
200
150
100
4.5V
50
4V
1.0
2.0
3.0
4.0
5.0
4.0
3.5
3.0
VGS=10V
2.5
2.0
1.5
1.0
6.0
100
150
Gate-Source On Resistance
1.6
IDS =250μA
IDS=125A
6
1.4
Normalized Threshold Voltage
250
7
5
4
3
2
1
3
4
5
6
7
8
9
1.0
0.8
0.6
0.4
0.2
-50 -25
10
VGS - Gate - Source Voltage (V)
www.hymexa.com
1.2
50
75
100 125 150
Tj - Junction Temperature (°C)
5
V1.0
HY4504P/B
Source-Drain Diode Forward
2.0
100
IDS = 125A
1.8
1.6
IS - Source Current (A)
Normalized On Resistance
200
VGS = 10V
1.4
1.2
1.0
0.8
o
Tj=25 C
10
o
Tj=150 C
1
0.6
o
RON@Tj=25 C: 2.3mΩ
0.4
-50 -25
50
75
0.1
0.0
100 125 150
1.2
1.4
10
VGS - Gate-source Voltage (V)
9000
C - Capacitance (pF)
1.0
Gate Charge
VDS= 32V
9
Ciss
7500
6000
4500
Coss
IDS= 125A
8
7
6
5
4
3
2
1
Crss
Capacitance
10500
VSD - Source - Drain Voltage (V)
Frequency=1MHz
1500
0.4
12000
3000
0.2
8
16
24
32
www.hymexa.com
86
129
172
215
QG - Gate Charge (nC)
6
V1.0
HY4504P/B
Avalanche Test Circuit
VDS
L
tp
VDSX(SUS)
DUT
VDS
IAS
RG
VDD
VDD
IL
tp
EAS
0.01Ω
tAV
VDS
RD
V
DS
DUT
RG
90%
VGS
VDD
10%
VGS
tp
td(on) tr
www.hymexa.com
7
td(off) tf
V1.0
HY4504P/B
Package Information
TO-220FB-3L
COMMON DIMENSIONS
SYMBOL
www.hymexa.com
mm
MIN
NOM
MAX
A
4.37
4.57
4.77
A1
1.25
1.30
1.45
A2
2.20
2.40
2.60
b
0.70
0.80
0.95
b2
1.17
1.27
1.47
c
0.40
0.50
0.65
D
15.10
15.60
16.10
D1
8.80
9.10
9.40
D2
5.50
E
9.70
10.00
10.30
E3
7.00
e
2.54 BSC
e1
5.08 BSC
H1
6.25
6.50
6.85
L
12.75
13.50
13.80
L1
3.10
3.40
ĭ3
3.40
3.60
3.80
Q
2.60
2.80
3.00
8
V1.0
HY4504P/B
TO-263-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
MIN
N
MAX
A
4.37
4.57
4.77
A1
1.22
1.27
1.42
A2
2.49
2.69
2.89
A3
0.25
b
0.7
0.81
0.96
b1
1.17
1.27
1.47
c
0.3
0.38
0.53
D1
8.5
8.7
8.9
D4
6.6
E
9.86
10.16
10.36
E5
7.06
e
2.54 BSC
H
14.7
15.1
15.5
H2
1.07
1.27
1.47
L
2
2.3
2.6
L1
1.4
1.55
1.7
L4
ș
www.hymexa.com
0.25 BSC
0°
9
5°
9°
V1.0
HY4504P/B
Devices Per Unit
Package Type
Unit
Quantity
TO-220FB-3L
Tube
50
TO-263-2L
Tube
50
Classification Profile
www.hymexa.com
10
V1.0
HY4504P/B
Classification Reflow Profiles
Profile Feature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 C
150 C
60-120 seconds
150 C
200 C
60-120 seconds
3 C/second max.
3C/second max.
183 C
60-150 seconds
217 C
60-150 seconds
See Classification Temp in table 1
See Classification Temp in table 2
Time (tP)** within 5C of the specified
classification temperature (Tc)
20** seconds
30** seconds
Average ramp-down rate (Tp to Tsmax)
6 C/second max.
6 C/second max.
6 minutes max.
8 minutes max.
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmax to TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak
(Tp)*
package
body
Temperature
Time 25C to peak temperature
* Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Table 1. SnPb Eutectic Process – Classification Temperatures (Tc)
3
Package
Volume mm
Thickness
很抱歉,暂时无法提供与“HY4504B”相匹配的价格&库存,您可以联系我们找货
