MMBT2907A
Silicon Epitaxial Planar Transistor( PNP)
E
Epitaxial planar die construction.
Complementary NPN Type available(MMBT2222A)
Absolute Maximum Ratings*
Symbol
SOT-23
B
Mark: 2F
T=
25°C unless otherwise noted
A
Parameter
Value
Units
V CBO
Collector-Base Voltage
- 60
V
VCEO
Collector-Emitter Voltage
- 60
V
V EBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-600
mA
PC
Collector Dissipation
250
mW
-55~150
Junction and Storage Temperature
Electrical Characteristics
Parameter
K
Features
T j,T stg
E L M
C
TA = 25°C unless otherwise noted
Symbol
Test conditions
MIN
TYP
MAX
UNIT
IC=-10 μ A,IE =0
-60
V
V (BR)CEO
IC=-10mA,IB=0
-60
V
Emitter-base breakdown voltage
V (BR)EBO
IE=-10 μA,IC=0
-5
V
Collector cut-off current
ICBO
VCB =-50V,I E=0
- 20
nA
ICEX
VCE =-30V,VBE(off) =-0.5V
- 50
nA
Emitter cut-off current
I EBO
VEB=-5V,IC=0
- 10
nA
Collector-base breakdown voltage
V (BR)CBO
Collector-emitter breakdown voltage
DC current gain
h FE
VCE=-10V,IC=-10mA
100
VCE=-10V,IC=-150mA
100
VCE =-10V,IC=-500mA
50
300
Collector-emitter saturation voltage
V CE(sat)
I C = - 15 0 m A I B = - 15m
A
- 0.4
V
Base-emitter voltage
V BE
A
- 1.3
V
Transition frequency
fT
VCE =20V, I C= 50mA
Collector Output Capacitance
C Ob
http:// www.jksemi.com
B
B
VCB =10V, IE =0
f=1MHz
200
MHz
80
2021-10-21
PF
版次: c
MMBT2907A
Parameter
Symbol
Test conditions
Turn-on Time
t on
VCE =-30V
45
ns
Delay Time
td
IC=-150mA
10
ns
Rise Time
tr
IB1=-15mA
40
ns
Turn-off Time
toff
VCE =-6V
100
ns
Storage Time
ts
IC=-150mA
80
ns
Fall Time
tf
IB1=IB2 =-15mA
30
ns
MIN
TYP
MAX
2021-10-21
UNIT
版次: c
E L M
K
MMBT2907A
K
E L M
Typical Characteristics
2021-10-21
版次: c
MMBT2907A
K
E L M
Typical characteristics
OUTLINE DRAWING
.007(.20) MIN.
SOT-23
.006(.15)
.002(.05)
.083 (2.10 )
.066(1.70)
.044(1.10)
.035(.90)
.006(.15) MAX.
.103(2.60)
.086(2.20)
.056(1.40)
.047(1.20)
.122(3.10)
.106(2.70)
.020(.50)
.013(.35)
2021-10-21
版次: c
很抱歉,暂时无法提供与“MMBT2907A”相匹配的价格&库存,您可以联系我们找货
