F4
F4
    DY(迪一电子)
    SOD-123FL-2
    二极管配置:-;直流反向耐压(Vr):400V;平均整流电流(Io):1A;正向压降(Vf):1.3V@1A;反向电流(Ir):5uA@400V;反向恢复时间(trr):150ns;工作温度:-55℃...
F4 数据手册
F1 THRU F7 Single Phase 1.0AMP Surface Mount Fast Recovery Rectifier Features Case: SOD-123FL Glass passivated die construction Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction High temperature soldering guaranteed: 260℃ /10 seconds,0.375"(9.5mm) lead length, 5 lbs. (2.3kg) tension · Plastic material-UL flammability 94V-0 · · · · · Mechanical Data · Case: SOD-123FL, molded plastic · Terminals: plated leads solderable per MIL-STD-750, Method 2026 · Polarity: Color band denotes cathode end · Mounting position: Any Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified. Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. SYMBOL TYPE NUMBER F1 F2 F3 F4 F5 F6 F7 UNITS 50 100 200 400 600 800 1000 V 35 70 140 280 420 560 700 V VRRM Peak Repetitive Reverse Voltage Working Peak Reverse Voltage VRWM DC Blocking Voltage VDC RMS Reverse Voltage VRMS Average Rectified Output Current @TL =110 ℃ IF(AV) Non-Repetitive Peak Forward Surge @Tj=25 ℃ Current 8.3ms Single half sine-wave @Tj=125 ℃ 1.0 A 30 IFSM 24 A Superimposed On Rated Load (JEDEC Method) Non-Repetitive Peak Forward Surge @Tj=25 ℃ Current 1.0ms Single half sine-wave @T j=125℃ Superimposed On Rated Load (JEDEC Method) IFSM 60 48 A 10000 times of the wave surge current ( time width 1ms, time interval 3s ) IFSM 22.5 A I 2t 3.735 A2s VFM 1.3 1.2 V IR 5.0 100 uA 2 I t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=1.0A @TA =25 ℃ @TA =125 ℃ Peak Reverse Current @TA =25℃ At Rated DC Blocking Voltage @TA =125 ℃ Maximum reverse recovery time (NOTE 1) Typical Junction Capacitance (Note 2) Typical thermal resistance (NOTE 3) Operating and Storage Temperature Range Trr 150 250 500 CJ 7 pF RθJA RθJC RθJL 120 25 17 ℃/W TJ,TSTG -55to+150 ℃ Note: 1. Measured with IF=0.5A, IR=1A, Irr=0.25A. 2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C. 3. Device mounted on FR-4 substrate, 1"*1", 2oz, single-sided, PC boards with 0.1"*0.15" copper pad. version:06 ns 1 of 3 F1 THRU F7 Single Phase 1.0AMP Surface Mount Fast Recovery Rectifier IFINSTANTANEOUS FORWARD CURRENT,(A) I(AV)AVERAGE FORWARD CURRENT (A) FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 0.6 0.4 0.2 0 0 25 50 75 100 125 150 175 1 0.1 0.01 0 0.4 0.8 1.2 1.6 1.8 FIG. 4-TYPICAL REVERSE CHARACTERISTICS 30 25 20 15 10 5.0 0 10 10 VF, INSTANTANEOUS FORWARD VOLTAGE (V) FIG. 3-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 1 20 IRINSTANTANEOUS REVERSE CURRENT (uA) I FSMPEAK FORWARD SURGE CURRENT (A) LEAD TEMPERATURE(OC) FIG. 2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 100 NUMBER OF CYCLES AT 60 Hz 1000 100 10 TA=100℃ 1 0.1 TA =25℃ 0.01 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLYAGE(%) FIG. 5 TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE (pF) Forward Power Dissipation (W) FIG. 6 Forward Power Dissipation Average Rectified Forward Current (A) REVERSE VOLTAGE (V) (1.3) Fig.6 TYPICAL CAPACITANCE version:06 2 of 3 F1 THRU F7 Single Phase 1.0AMP Surface Mount Fast Recovery Rectifier Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from XINNUO. •XINNUO reserves the right to make changes to this document and its products and specifications • XINNUO disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •XINNUO does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. XINNUO makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify XINNUO for any damages resulting from such improper use or sale. •Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:06 3 of 3
很抱歉,暂时无法提供与“F4”相匹配的价格&库存,您可以联系我们找货
