PTVSHC2EN12VUT
Transient Voltage Suppressor
Description
The PTVSHC2EN12VUT ESD protector is designed to replace multilayer varistors (MLVs)
in portable applications such as cell phones, notebook computers, and PDA’s. They
feature large cross-sectional area junctions for conducting high transient currents, offer
Pin 2
Pin 1
desirable electrical characteristics for board level protection, such as fast response time,
Circuit Diagram
lower operating voltage, lower clamping voltage and no device degradation when
compared
to
MLVs.
The
PTVSHC2EN12VUT
protects
sensitive
semiconductor
components from damage or upset due to electrostatic discharge (ESD) and other voltage
induced transient events. The PTVSHC2EN12VUT is available in a DFN1610-2L package
with working voltages of 12 volt. It is used to meet the ESD immunity requirements of IEC
Pin 1
61000-4-2, (±30kV air, ±30kV contact discharge)
H12T
Pin 2
Marking (Top View)
Feature
Applications
3000W Peak pulse power per line (tP = 8/20μs)
Cell phone handsets and accessories
DFN1610-2L package
Personal digital assistants (PDA’s)
Response time is typically < 1 ns
Notebooks, desktops, and servers
Protect one I/O or power line
Portable instrumentation
Low clamping Voltage
Cordless phones
RoHS compliant
Digital cameras
Transient protection for data lines to
Peripherals
IEC 61000-4-2(ESD) ±30KV(air), ±30KV(contact);
MP3 players
IEC 61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Device meets MSL1 requirements
Rev.06.3
1
www.prisemi.com
PTVSHC2EN12VUT
Electronics Parameter
Symbol
Parameter
VRWM
Peak Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Breakdown Voltage @ IT
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
PPP
Peak Pulse Power
CJ
Junction Capacitance
IF
Forward Current
VF
Forward Voltage @ IF
I
IF
V
VC VBR VRWM
IR VF
IT
IPP
Electrical characteristics per line@25℃( unless otherwise specified)
Parameter
Symbol
VRWM
Breakdown Voltage
VBR
It =1mA
IR
VRWM =12V
Clamping Voltage
VC
Cj
Conditions
Min.
Typ.
13
Max.
Units
12
V
16
V
1
μA
IPP=50A tP = 8/20μs
V
IPP=100A tP = 8/20μs
25
27
V
350
500
pF
VR=0V f = 1MHz
300
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Peak Pulse Power ( tP = 8/20μS )
Ppp
3000
W
Lead Soldering Temperature
TL
260 (10 sec)
Operating Temperature
TJ
-55 to +125
TSTG
-55 to +150
Storage Temperature
Rev.06.3
2
www.prisemi.com
PTVSHC2EN12VUT
Typical Characteristics
tr=8μs
IPP – Peak Pulse Current - % of IPP
100
100
% Of Rated Power
80
60
tP =20μs(IPP /2)
40
60
40
10
15
50
t - Time - μs
Fig 1.Pulse Waveform(8/20μs)
100
125
150
Fig 2.Power Derating Curve
500
50
Pulse waveform: tp=8/20us
f = 1MHz
C - Junction Capacitance - pF
450
40
VC - Clamping Voltage - V
75
TL – Lead Temperature - ℃
30
350
300
250
200
150
100
10
50
60
80
100
4
IPP - Peak pulse current - A
8
10
12
Fig 4. Capacitance vs. Reveres voltage
Fig 3. Clamping voltage vs. Peak pulse current
V_pulse
16
Pulse from a
Transmission line
100ns
TLP_V
12
TLP_I
DUT
10000
8
TLP Current - A
Peak Pulse Power - W
6
VR - Reverse voltage - V
1000
Pin 1 to Pin 2
T = 25 ℃
4
-8
100
-12
-16
10
1
10
100
1000
Pulse Duration - μs
-5
10
15
TLP Voltage - V
Fig 5. Non Repetitive Peak Pulse Power vs. Pulse time
Rev.06.3
-20
-10
3
Fig 6. TLP Measurement
www.prisemi.com
PTVSHC2EN12VUT
Solder Reflow Recommendation
Preliminary Heating
300
Soldering
Cooling(in air)
Temperature of Soldering
260℃ (+0,-5℃)
250
245℃ (+0,-5℃)
200
150
120℃
100
100℃
50
2 to 5 min
more than 1 min
Less than 10s
Remark: Pb free for 260℃;Pb for 245℃.
PCB Design
For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD
protection. Novices in the area of ESD protection should take following suggestions to heart:
Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.
Do not make false economies and save copper for the ground connection.
Place via holes to ground as close as possible to the anode of the TVS diode.
Use as many via holes as possible for the ground connection.
Keep the length of via holes in mind! The longer the more inductance they will have.
Rev.06.3
4
www.prisemi.com
PTVSHC2EN12VUT
Product dimension (DFN1610-2L)
D
L
b
E
1
2
h
e
h
Bottom View
A
C
A1
Dim
Millimeters
MIN
MAX
0.60
A
0.45
A1
0.05
b
0.75
0.85
c
0.10
0.20
D
1.55
e
1.65
1.10BSC
E
0.95
1.05
L
0.35
0.45
h
0.15
0.25
0.6
0.625
1.0
1.225
1.85
Recommended Soldering Pad
Unit:mm
Ordering information
Device
Package
Shipping
PTVSHC2EN12VUT
DFN1610-2L (Pb-Free)
3000 / Tape & Reel
Rev.06.3
5
www.prisemi.com
PTVSHC2EN12VUT
Load with information
USER DIRECTION OF FEED
4.0±0.1
Ø1.50±0.1
Pin1
4.0±0.1
3.5±0.1
8.0±0.3
1.75±0.1
2.0±0.1
Unit:mm
Rev.06.3
6
www.prisemi.com
PTVSHC2EN12VUT
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.3
7
www.prisemi.com
很抱歉,暂时无法提供与“PTVSHC2EN12VUT”相匹配的价格&库存,您可以联系我们找货
