JW5068AQFNF#TRPBF
JW5068AQFNF#TRPBF
    JOULWATT(杰华特)
    QFN20
    QFN20
JW5068AQFNF#TRPBF 数据手册
JW5068A 23V/8A Sync. Step-Down Converter Preliminary Specifications Subject to Change without Notice DESCRIPTION FEATURES The JW ®5068A is a monolithic buck switching regulator based on I2 architecture for fast transient response. Operating with an input range of 4V~23V, JW5068A delivers 8A of continuous output current with two integrated N-Channel MOSFETs. The internal synchronous power switches provide high efficiency without the use of an external Schottky diode. At light loads, the regulator operates in low frequency to maintain high efficiency and low output ripples.  JW5068A guarantees robustness with output short protection, thermal protection, current run-away protection, and input under voltage lockout.  JW5068A is available in QFN3X3-20 package, which provide a compact solution with minimal external components. APPLICATIONS Company’s Logo is Protected, “JW” and “JOULWATT” are Registered Trademarks of JoulWatt technology Inc. 4V to 23V operating input range 8A continuous / 16A peak output current Up to 95% efficiency High efficiency at light load 500kHz switching frequency External bypass input Programmable valley current limit Power good indicator Input under voltage lockout Output discharge function Output over voltage latch off protection Output short protection Thermal protection RoHS compliant and halogen free Available in QFN3X3-20 package              Industrial and commercial low power system Notebook LDO monitors and TVs Green electronics/ appliances    TYPICAL APPLICATION 8A Step-down Regulator CBST L VIN VIN BST VOUT SW C1 EN FB ON/OFF CIN ILMIT JW5068A JW5068A Rev.0.55 2023/03/07 R3 BYP VBYP R2 VCC CVCC R1 PG RPG COUT CBYP GND JoulWatt® Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 1 JW5068A JoulWatt ORDER INFORMATION DEVICE1) PACKAGE TOP MARKING2) JW5068AQFNF#TRPBF QFN3X3-20 JW5068A YW□□□□□ Notes: JW # TRPBF 1) JW 2) Line1: PB Free Tape and Reel(If”TR”is not shown, it means tube) Package Code Part No. YW Lot number Product code Line2: Week code Joulwatt LOGO Year code PIN CONFIGURATION SW GND VCC NC 20 19 18 17 16 1 4 VIN 5 6 7 8 9 10 NC VIN GND PG 3 GND 2 VIN GND VIN SW BST SW TOP VIEW 15 BYP 14 FB 13 ILMT 12 NC 11 EN ABSOLUTE MAXIMUM RATING1) VIN, EN, PG, ILMT Pin............................................................................................................ -0.3V to 28V SW Pin.......................................................................................... -0.3V(-5V for 5ns)(-1V for 20ns) to 28V BST Pin .......................................................................................... SW-0.3V to SW+5V(+5.8V for 150ns) All other Pins ............................................................................................................................ -0.3V to 6V Junction Temp. 2) .............................................................................................................................150ºC Lead Temperature .............................................................................................................................260ºC ESD Susceptibility (Human Body Model) ............................................................................................. 2kV RECOMMENDED OPERATING CONDITIONS3) Input Voltage VIN ....................................................................................................................... 4V to 23V Output Voltage VOUT............................................................................................................0.6V to VIN-3V Ambient Temperature Range ............................................................................................... -40°C to 85°C Operating Junction Temperature..........................................................................................-40ºC to 125ºC THERMAL PERFORMANCE4) θJA θJc QFN3X3-20............................................................................................................................30....4.5ºC/W JW5068A Rev.0.55 2023/03/07 JoulWatt® Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 2 JW5068A JoulWatt Note: 1) 2) 3) 4) Exceeding these ratings may damage the device. These stress ratings do not imply function operation of the device at any other conditions beyond those indicated under RECOMMENDED OPERATING CONDITIONS. The JW5068A includes thermal protection that is intended to protect the device in overload conditions. Continuous operation over the specified absolute maximum operating junction temperature may damage the device. The device is not guaranteed to function outside of its operating conditions. Measured on JESD51-7, 4-layer PCB. JW5068A Rev.0.55 2023/03/07 JoulWatt® Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 3 JW5068A JoulWatt ELECTRICAL CHARACTERISTICS VIN=12V, TA=25℃,Unless otherwise stated. Item Symbol VIN Under Voltage Lock-out Threshold Conditions Min. Typ. Max. Unit VIN rising 2.7 2.91 3.12 V VIN falling 2.45 2.7 2.95 V VIN_MIN VIN Under Voltage Lockout Hysteresis VIN_MIN_HYST Shutdown Current ISD VEN=0V 2 5 μA Supply Current IQ VEN=5V, VBYP=5V 45 70 μA EN Rising Threshold VEN_H EN Falling Threshold VEN_L Feedback Voltage VFB Top Switch Resistance5) Bottom Switch Resistance5) 180 mV 0.8 4V
JW5068AQFNF#TRPBF 价格&库存
很抱歉,暂时无法提供与“JW5068AQFNF#TRPBF”相匹配的价格&库存,您可以联系我们找货
