EMVY6R3ARA102MHA0G
EMVY6R3ARA102MHA0G
    NCC(贵弥功)
    径向,Can-SMD
    1000 µF 6.3 V 铝电解电容器 径向,Can - SMD 105°C 时为 2000 小时
EMVY6R3ARA102MHA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MVY - Series Low impedance, 105℃ MZA Lower Z ・Endurance : 1,000 to 5,000 hours at 105℃ ・Low impedance ・For digital equipment, especially DC-DC converters ・Solvent resistant type except 80 & 100Vdc (see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. MVY Longer life MLA Lower Z MVE ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ (6.3 to 63Vdc) -40 to +105℃ (80 & 100Vdc) 6.3 to 100Vdc (at 20℃, 120Hz) ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V When nominal capacitance exceeds - 1,000µF, add 0.02 to the value above D55 to F80 0.24 0.20 0.16 0.14 0.12 0.12 tanδ (Max.) HA0 & JA0 0.28 0.24 0.20 0.16 0.14 0.12 - for each 1,000µF increase. (at 20℃, 120Hz) KE0 to MN0 0.26 0.22 0.18 0.16 0.14 0.12 0.14 0.10 0.10 Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V D55 to JA0 3 2 2 2 2 2 Z(-40℃)/Z(+20℃) KE0 to MN0 10 8 6 4 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified ime at 105℃. D55 to F80 : 1,000 hours Time HA0 & JA0 : 2,000 hours KE0 to MN0 : 5,000 hours Rated voltage 6.3Vdc (D55 to JA0) 6.3 to 100Vdc Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3Vdc (D55 to JA0) 6.3 to 100Vdc Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size Vent (Except F61 to HA0) 0.3max. L±0.3 (Note) φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.3 (Note) Note : L±0.5 for HA0 to MN0 A±0.2 Note : L±0.5 for HA0 to MN0 2 3 4 5 6 7 8 9 10 11 12 A±0.2 : Dummy terminals ◆PART NUMBERING SYSTEM 1 W P C±0.2 Vent (Except D55 to HA0) Code : G(Vibration resistant structure) code : F61 to MN0 Size code B±0.2 Code : A code : D55 to MN0 13 14 15 16 17 18 E MV Y AAA A DA AAA M AAA G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 4.7µF:4R7,10µF:100) Taping·Tray code Terminal code (A, G) Voltage code (ex. 6.3V:6R3,10V:100,50V:500) Series code Category D55 E55 F55 F61 F80 HA0 JA0 KE0 KG5 LH0 LN0 MH0 MN0 D 4 5 6.3 6.3 6.3 8 10 12.5 12.5 16 16 18 18 L 5.2 5.2 5.2 5.8 7.7 10.0 10.0 13.5 16.0 16.5 21.5 16.5 21.5 A 4.3 5.3 6.6 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 B 4.3 5.3 6.6 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 C 5.1 5.9 7.2 7.2 7.2 9.0 11.0 13.7 13.7 18.0 18.0 20.0 20.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.0 1.4 1.9 1.9 1.9 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ◆MARKING D55 to JA0 EX) 6.3V100µF 7hY 100 6.3V KE0 to MN0 EX) 16V1,000µF 0V MVY 1000 16V Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip Low impedance, 105℃ MVYSeries - ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 Cap (µF) Size code 22 33 47 100 220 330 470 680 1,000 1,500 2,200 2,200 3,300 3,300 4,700 4,700 6,800 6,800 8,200 22 33 47 100 220 330 470 680 1,000 2,200 2,200 3,300 3,300 4,700 4,700 6,800 10 22 33 47 100 220 330 470 680 1,000 1,000 2,200 2,200 3,300 3,300 4,700 10 22 33 47 100 220 D55 E55 E55 F55 F55 F80 HA0 HA0 HA0 JA0 KE0 LH0 KG5 MH0 LN0 MH0 LN0 MN0 MN0 E55 E55 F55 F55 F80 HA0 HA0 JA0 JA0 KG5 LH0 LH0 MH0 LN0 MN0 MN0 D55 E55 F55 F55 F55 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 LN0 MH0 MN0 E55 F55 F55 F55 F80 HA0 Rated ripple Impedance current (Ω max./20℃, (mArms/105℃, 100kHz) 100kHz) 3.0 1.8 1.8 1.0 1.0 0.34 0.30 0.30 0.30 0.15 0.070 0.054 0.060 0.054 0.038 0.054 0.038 0.038 0.038 1.8 1.8 1.0 1.0 0.34 0.30 0.30 0.15 0.15 0.060 0.054 0.054 0.054 0.038 0.038 0.038 3.0 1.8 1.0 1.0 1.0 0.34 0.30 0.30 0.15 0.070 0.054 0.054 0.054 0.038 0.054 0.038 1.8 1.0 1.0 1.0 0.34 0.30 60 95 95 140 140 280 450 450 450 670 820 1,260 950 1,350 1,630 1,350 1,630 1,750 1,750 95 95 140 140 280 450 450 670 670 950 1,260 1,260 1,350 1,630 1,750 1,750 60 95 140 140 140 280 450 450 670 820 1,260 1,260 1,350 1,630 1,350 1,750 95 140 140 140 280 450 Part No. EMVY6R3ARA220MD55G EMVY6R3ARA330ME55G EMVY6R3ARA470ME55G EMVY6R3ARA101MF55G EMVY6R3ARA221MF55G EMVY6R3□RA331MF80G EMVY6R3□RA471MHA0G EMVY6R3□RA681MHA0G EMVY6R3□RA102MHA0G EMVY6R3□RA152MJA0G EMVY6R3□RA222MKE0S EMVY6R3□RA222MLH0S EMVY6R3□RA332MKG5S EMVY6R3□RA332MMH0S EMVY6R3□RA472MLN0S EMVY6R3□RA472MMH0S EMVY6R3□RA682MLN0S EMVY6R3□RA682MMN0S EMVY6R3□RA822MMN0S EMVY100ARA220ME55G EMVY100ARA330ME55G EMVY100ARA470MF55G EMVY100ARA101MF55G EMVY100□RA221MF80G EMVY100□RA331MHA0G EMVY100□RA471MHA0G EMVY100□RA681MJA0G EMVY100□RA102MJA0G EMVY100□RA222MKG5S EMVY100□RA222MLH0S EMVY100□RA332MLH0S EMVY100□RA332MMH0S EMVY100□RA472MLN0S EMVY100□RA472MMN0S EMVY100□RA682MMN0S EMVY160ARA100MD55G EMVY160ARA220ME55G EMVY160ARA330MF55G EMVY160ARA470MF55G EMVY160ARA101MF55G EMVY160□RA221MF80G EMVY160□RA331MHA0G EMVY160□RA471MHA0G EMVY160□RA681MJA0G EMVY160□RA102MKE0S EMVY160□RA102MLH0S EMVY160□RA222MLH0S EMVY160□RA222MMH0S EMVY160□RA332MLN0S EMVY160□RA332MMH0S EMVY160□RA472MMN0S EMVY250ARA100ME55G EMVY250ARA220MF55G EMVY250ARA330MF55G EMVY250ARA470MF55G EMVY250□RA101MF80G EMVY250□RA221MHA0G WV (Vdc) 25 35 50 63 *1 80 *1 100 □ : Enter the appropriate terminal code. Production of the products shown in is scheduled to be discontinued. *1: Assembly boards with the designated products attached cannot be cleaned. Cap (µF) Size code 330 470 1,000 1,000 2,200 2,200 3,300 4.7 10 22 33 47 47 68 100 220 330 470 470 1,000 1,000 2,200 1.0 2.2 3.3 4.7 10 22 33 47 68 100 220 330 330 470 470 1,000 68 100 220 220 330 330 470 470 100 220 330 330 470 47 68 100 100 220 220 330 HA0 JA0 LH0 MH0 LN0 MN0 MN0 D55 E55 F55 F55 F55 F61 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 MN0 D55 D55 D55 E55 F55 F55 F80 F80 HA0 HA0 JA0 KE0 LH0 LH0 MH0 MN0 KE0 KE0 KE0 LH0 LH0 MH0 LN0 MH0 KE0 KG5 LN0 MH0 MN0 KE0 KE0 KE0 LH0 LN0 MH0 MN0 Rated ripple Impedance current (Ω max./20℃, (mArms/105℃, 100kHz) 100kHz) 0.30 0.15 0.054 0.054 0.038 0.038 0.038 3.0 1.8 1.0 1.0 1.0 1.0 0.34 0.30 0.30 0.15 0.070 0.054 0.054 0.054 0.038 5.0 5.0 5.0 3.0 2.0 2.0 0.60 0.60 0.60 0.60 0.30 0.11 0.087 0.087 0.087 0.050 0.19 0.19 0.19 0.12 0.12 0.12 0.085 0.12 0.33 0.26 0.16 0.24 0.16 0.33 0.33 0.33 0.24 0.16 0.24 0.16 450 670 1,260 1,350 1,630 1,750 1,750 60 95 140 140 140 140 280 450 450 670 820 1,260 1,260 1,350 1,750 30 30 30 50 70 70 170 170 300 300 500 650 900 900 1,060 1,520 500 500 500 845 845 905 1,100 905 450 550 900 700 950 450 450 450 650 900 700 950 Part No. EMVY250□RA331MHA0G EMVY250□RA471MJA0G EMVY250□RA102MLH0S EMVY250□RA102MMH0S EMVY250□RA222MLN0S EMVY250□RA222MMN0S EMVY250□RA332MMN0S EMVY350ARA4R7MD55G EMVY350ARA100ME55G EMVY350ARA220MF55G EMVY350ARA330MF55G EMVY350ARA470MF55G EMVY350□RA470MF61G EMVY350□RA680MF80G EMVY350□RA101MHA0G EMVY350□RA221MHA0G EMVY350□RA331MJA0G EMVY350□RA471MKE0S EMVY350□RA471MLH0S EMVY350□RA102MLH0S EMVY350□RA102MMH0S EMVY350□RA222MMN0S EMVY500ARA1R0MD55G EMVY500ARA2R2MD55G EMVY500ARA3R3MD55G EMVY500ARA4R7ME55G EMVY500ARA100MF55G EMVY500ARA220MF55G EMVY500□RA330MF80G EMVY500□RA470MF80G EMVY500□RA680MHA0G EMVY500□RA101MHA0G EMVY500□RA221MJA0G EMVY500□RA331MKE0S EMVY500□RA331MLH0S EMVY500□RA471MLH0S EMVY500□RA471MMH0S EMVY500□RA102MMN0S EMVY630□RA680MKE0S EMVY630□RA101MKE0S EMVY630□RA221MKE0S EMVY630□RA221MLH0S EMVY630□RA331MLH0S EMVY630□RA331MMH0S EMVY630□RA471MLN0S EMVY630□RA471MMH0S EMVY800□RA101MKE0S EMVY800□RA221MKG5S EMVY800□RA331MLN0S EMVY800□RA331MMH0S EMVY800□RA471MMN0S EMVY101□RA470MKE0S EMVY101□RA680MKE0S EMVY101□RA101MKE0S EMVY101□RA101MLH0S EMVY101□RA221MLN0S EMVY101□RA221MMH0S EMVY101□RA331MMN0S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Size code D55 to JA0 KE0 to MN0 Capacitance(µF) Frequency(Hz) 1.0 to 4.7 10 to 100 220 to 470 680 to 1,500 47 to 100 220 to 470 1,000 2,200 to 3,300 4,700 to 8,200 120 0.35 0.40 0.50 0.60 0.40 0.50 0.60 0.75 0.85 1k 0.70 0.75 0.85 0.87 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.90 0.94 0.95 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
EMVY6R3ARA102MHA0G 价格&库存
很抱歉,暂时无法提供与“EMVY6R3ARA102MHA0G”相匹配的价格&库存,您可以联系我们找货
