HHXB800ARA390MJA0G
HHXB800ARA390MJA0G
    NCC(贵弥功)
    SMD,D10xL10.3mm
    铝聚合物电容器 SMD,D10xL10.3mm 39µF ±20% 80V Ф10.00mm 35mΩ
HHXB800ARA390MJA0G 数据手册
CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXB Series ・High reliability and high voltage are realized by hybrid electrolyte ・Endurance with ripple current : 5,000 hours at 105℃ ・For high reliability applications. (Automotive equipment, Base station equipment, etc.) ・RoHS2 Compliant ・Halogen Free ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. HXA Higher temperature HXB Longer life HXD ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ 80Vdc ±20% (M) I=0.01CV or 3μA, whichever is greater Where, I : Max. leakage current (μA) , C: Nominal capacitance(μF), V : Rated voltage(V) Rated voltage(Vdc) 80V tanδ 0.08 (Max.) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.5 Z(-55℃)/Z(+20℃)≦2.0 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105 ℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105 ℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size Code : A code : HA0 and JA0 ● Size Code : G(Vibration resistant structure) code : HA0 and JA0 Vent for JA0 Vent for JA0 0.3max. W 0.3max. L±0.5 L±0.5 A±0.2 Size Code HA0 φD 8 L 10.0 A 8.3 B 8.3 C 9.0 W 0.7 to 1.1 P 3.1 JA0 10 10.0 10.3 10.3 11.0 0.7 to 1.1 4.5 P C±0.2 B±0.2 φD±0.5 P C±0.2 B±0.2 φD±0.5 W A±0.2 : Dummy terminals ◆MARKING ◆PART NUMBERING SYSTEM 1 2 3 4 H HXB 5 6 7 8 9 10 RA 11 12 13 14 M 15 16 17 18 EX) 80V22µF G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 22µF:220) Taping code Terminal code Voltage code (ex. 80V:800) Series code Category 26A 22 K HB ●Rated voltage symbol Rated voltage (Vdc) 80 Symbol K Please refer to "Product code guide (conductive polymer hybrid type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V 2021 CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXBSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Size code ESR (mΩmax./20℃, 100kHz) Rated ripple current (mArms/105℃, 100kHz) Part No. 80 22 39 HA0 JA0 45 35 1,600 1,700 HHXB800□RA220MHA0G HHXB800□RA390MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 22 39 120 0.07 0.10 1k 0.30 0.40 5k 0.50 0.60 10k 0.60 0.70 20k 0.70 0.80 30k 0.75 0.80 100k to 500k 1.00 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V 2021
HHXB800ARA390MJA0G 价格&库存
很抱歉,暂时无法提供与“HHXB800ARA390MJA0G”相匹配的价格&库存,您可以联系我们找货
