SS12-SS110
Surface Mount Schottky Barrier Rectifiers
REVERSE VOLTAGE: 20 - 100 V
FORWARD CURRENT: 1.0 A
SMAJ
Features
Schottky barrier rectifier
4.3± 0.1
Guardring protection
Reverse energy tested
2.6± 0.15
1.70± 0.25
Low forward voltage
High current capability
Extremely low thermal resistance
5.6± 0.2
2.35± 0.1
Mechanical Data
1111
1.3± 0.2
Polarity: Color band denotes cathode end
Mounting position: ANY
0.2± 0.05
0.203MAX
Case: SMAJ molded plastic body
Weight: 0.003 ounces, 0.084 grams
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
SS12
SS13 SS14 SS15
SS16 SS18
SS19 SS110
UNITS
Maximum repetitive peak reverse voltage
VRRM
40
50
60
80
90
100
V
Maximum RMS voltage
VRWS
14
21
28
35
42
56
63
70
V
Maximum DC blocking voltage
VDC
40
50
60
80
90
100
V
Maximum average forward rectified current at
TL=90
IF(AV)
1.0
A
Peak forward surge current 8.3ms single
half-sine-wave
IFSM
40
A
Maximum instantaneous forward voltage
at I FM=1.0A (NOTE1)
VF
Maximum DC reverse current
TJ=25
at rated DC blocking voltage TJ=125
Maximum thermal resistance
Operating temperature range
Storage temperature range
0.50
0.85
0.2
IR
R
0.75
0.5
6.0
JL
5.0
28
V
mA
o
C/W
TJ
-55 ---- +125
o
C
TSTG
-55 ---- +150
o
C
NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 %
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SS12-SS110
Ratings AND Charactieristic Curves
1.0
FIG.2-- PEAK FORWARD SURGE CURRENT
PEAK FORWARD SURGE
CURRENT,AMPERES
CURRENT,AMPERES
FIG.1 -- FORWARD DERATING CURVE
Resistive or
inductive Load
0.5
P.C.B.MOUNTED ON
0.2X0.2(5.0X5.0mm)
COPPERPAD AREAS
70 80
60
90 100 110 120 130 140 150 160 170
40
LEAD TEMPERATURE
SS12J-SS14J
10
SS18J-SS110J
0 .0 1
Pulse Width=300
1%DUTY CYCLE
S
SS15J-SS16J
0 .2
0 .4
0 .6
0 .8
1 .0
1 .2
1 .4
1 .6
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
10 0
100
SS15J-SS110J
10
TJ=125℃
1
SS12-SS14
SS18J-SS110J
0.1
T J=25℃
SS12J-SS16J
0.01
0.001
60
80
1 00
PERCENT OF RATED PEAK REVERSE VOLTAGE,
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMAJ
5000/REEL
80000
36X30.6X31
12.00
11.00
ht t p : //
10
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE
CURRENT,MICRO AMPERES
CURRENT,AMPERES
50
0 .1
1
NUMBER OF CYCLES AT 60Hz
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
1
O
TL=100 C
8 .3 m s S in g le H a lf S in e -W a v e
(J E D E C M e th o d )
www.lgesemi .c o m
很抱歉,暂时无法提供与“SS14”相匹配的价格&库存,您可以联系我们找货
