SOLID POLYMER ELECTROLYTIC CAPACITOR 导电性高分子固体铝电解电容
HV
series Low Leakage Current
Features(特点)
«Designed for surface mounting on high density PC board ,Applicable to automatic mounting
machine uing emboss carrier tape
用于高密度表面贴装,吸塑载带封装成盘后用于自动机贴装
«Low ESR at high frequency range & Large permissible ripple current
(在高频范围内的低ESR ,允许大纹波电流)
Specifications (产品规格)
item
项目
Operating Temperature Range
工作温度范围
Rated Voltage Range
额定电压范围
Performance Characteristics
性能 特点
-55~+105°C
2.5~80vdc
Capacitance Tolerance(容量公差)
Leakage Current(+20°C max)
漏电流
Dissipation Factor(损耗系数)
tanδ at 20°C,120Hz
±20%(120Hz,+20°C)
≤0.2cv(uA.After 2 minutes)
充电2分钟后漏电≤0.2vc
Not to exceed the value specified
不超过指定值
不超过指定值
ESR(100KHz)
Capacitance Change
Leakage Current
Endurance(耐久性)
105°C,2000H at rated voltage
105°C 2000h 不超过额定电压
ESR
Dissipation Factor
Capacitance Change
Leakage Current
Moisture Resistance(耐湿性)
Stored at 60°C,RH90~95% 2000H
存放在60°C,RH90~95% 2000h
ESR
Dissipation Factor
Within ±20% of the value before test
测试前的值的±20%以内
不超过指定值
Not to exceed 150% of the value
specified
不超过指定值的150%
specified
不超过指定值的150%
测试前的值的±20%以内
不超过指定值
specified
不超过指定值的150%
specified
不超过指定值的150%
Srequency Coefficient For Ripple Current (纹波电流的频率系数)
Frequency
Coefficient
120Hz≤freq.
很抱歉,暂时无法提供与“HV1E227M0810PZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.47426
- 50+1.18555
- 150+1.06182
