LESD8LL5.0C
LESD8LL5.0C
    TENGLING(腾领)
    SOD882
    ESD抑制器 SOD882 90W 5V
LESD8LL5.0C 数据手册
LESD8LL5.0C 1-Line bidirectional ESD Protection Diode Transient Voltage Suppressors ESD Protection Diodes with Ultra−Low Capacitance General Description The ESD8LL5.0C is designed to protect voltage sensitive components from ESD. Excellent clamping capability, low capacitance, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its low capacitance, it is suited for use in high frequency designs such as USB 3.0 high speed and antenna line applications Applications        USB2.0 adn USB3.0 Cellular phones audio MP3 players SOD882 Digital cameras Portable applicationss Mobile telephone SATA and eSATA Features       Ordering information Ultra Low Capacitance 0.3 pF(Typ) Small Body Outline Dimensions 1.00mm x 0.60mm Low Body Height Device LESD8LL5.0C Marking 21 Shipping 10000/Tape&Reel Peak Power up to 90 Watts @ 8 x 20 μs Pulse Low Leakage current Response Time is Typically < 1 ns Absolute Ratings (Tamb=25°C ) Symbol Parameter Value Units PPP Peak Pulse Power (tp = 8/20μs) 90 W TL Maximum lead temperature for soldering during 10s 260 °C Tstg Storage Temperature Range -55 to +150 °C Top Operating Temperature Range -40 to +125 °C Tj Maximum junction temperature 150 °C ±20 ±15 KV 4 A IEC61000-4-2 (ESD) IPPM air discharge contact discharge IEC61000-4-5 (8/20uS) 1/3 www.twtlgf.com 1 LESD8LL5.0C 1-Line bidirectional ESD Protection Diode Electrical Parameter Symbol Parameter Reverse Peak IPP Maximum Current VC Clamping Voltage @ IPP Pulse IR Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM IT Test Current VRWM VBR Breakdown Voltage @ IT Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. VRWM IR1(uA) (V) @ VRWM Device LESD8LL5.0C VBR (V)@ IT (Note 1) IT VC (V) VC (V) @ IPP=1 A* @ Max IPP* IPP PPK C (A)* (W)* (pF) Max Max Min mA Typ Max Max Max Max 5.0 0.1 6.0 1.0 13.0 22.0 4.0 90 0.35 *Surge current waveform per Figure 1. 1. VBR is measured with a pulse test current IT at an ambient temperature of 25℃. Fig1. IEC61000-4-5 Waveform Fig2.IEC61000-4-2 Waveform 2/3 www.twtlgf.com 2 LESD8LL5.0C 1-Line bidirectional ESD Protection Diode OUTLINE AND DIMENSIONS SOD882 SOD882 Dim Min Typ. Max A 0.46 0.48 0.50 A1 0 0.02 0.05 b 0.45 0.5 0.55 c 0.1 0.12 0.14 D 0.95 1.00 1.05 E 0.55 0.60 0.65 L 0.20 0.25 0.30 L1 h 0.035 0.05 0.12 0.065 0.17 崩胶 0 0.07 0.06 All Dimensions in mm 0.06 3/3 www.twtlgf.com 3
LESD8LL5.0C 价格&库存
很抱歉,暂时无法提供与“LESD8LL5.0C”相匹配的价格&库存,您可以联系我们找货
