TAI-TECH
KBM01-230800465 P2.
High Current Ferrite Chip Bead(Lead Free)
1.Features
HCB1608KF-SERIES
Halogen
1. Monolithic inorganic material construction.
Halogen-free
2. Closed magnetic circuit avoids crosstalk.
3. Suitable for reflow soldering.
4. Shapes and dimensions follow E.I.A. spec.
5. Available in various sizes.
6. Excellent solder ability and heat resistance.
7. High reliability.
8.100% Lead(Pb) & Halogen-Free and RoHS compliant.
9. Low DC resistance structure of electrode to prevent wasteful electric power consumption.
10. Operating Temperature: -55~+125℃(Including self-temperature rise)
2.Dimensions
Chip Size
A
1.60±0.15
B
0.80±0.15
C
0.80±0.15
D
0.30±0.20
Units: mm
3.Part Numbering
HCB
1608
KF
A
B
C
A: Series
B: Dimension
C: Material
D: Impedance
E: Packaging
F: Rated Current
121
T
D
E
F
LxW
Lead Free Material
121=120Ω
T=Taping and Reel, B=Bulk(Bags)
20=2000mA
4.Specification
Tai-Tech
Part Number
Impedance (Ω)
Test Frequency
(MHz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB1608KF-100T40
10±25%
100
0.03
4000
HCB1608KF-100T50
10±25%
100
0.02
5000
HCB1608KF-100T60
10±25%
100
0.01
6000
HCB1608KF-300T10
30±25%
100
0.20
1000
HCB1608KF-300T60
30±25%
100
0.01
6000
HCB1608KF-330T30
33±25%
100
0.04
3000
HCB1608KF-500T30
50±25%
100
0.04
3000
HCB1608KF-600T15
60±25%
100
0.15
1500
HCB1608KF-600T20
60±25%
100
0.10
2000
HCB1608KF-600T30
60±25%
100
0.04
3000
HCB1608KF-600T40
60±25%
100
0.03
4000
HCB1608KF-800T30
80±25%
100
0.04
3000
Rated current: based on temperature rise test
In compliance with EIA 595
www.tai-tech.com.tw
TAI-TECH
Tai-Tech
Part Number
KBM01-230800465 P3.
Impedance (Ω)
Test Frequency
(MHz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB1608KF-101T20
100±25%
100
0.04
3000
HCB1608KF-151T20
150±25%
100
0.10
2000
HCB1608KF-221T25
220±25%
100
0.05
2500
HCB1608KF-471T20
470±25%
100
0.10
2000
HCB1608KF-601T10
600±25%
100
0.20
1000
HCB1608KF-601T15
600±25%
100
0.15
1500
www.tai-tech.com.tw
TAI-TECH
KBM01-230800465 P4.
5. Reliability and Test Condition
Item
Series No.
Performance
FCB
FCM
HCB
Test Condition
GHB
FCA
-55~+125℃
-55~+125℃
(on board)
Transportation
Storage Temperature
--For long storage conditions, please see the
Application Notice
Agilent4291
Agilent E4991
Impedance (Z)
Agilent4287
Refer to standard electrical characteristics list
Agilent16192
DC Resistance
Agilent 4338
Rated Current
DC Power Supply
Over Rated Current requirements, there will be
some risk
Temperature Rise Test
Rated Current < 1A ΔT 20℃Max
Rated Current ≧ 1A ΔT 40℃Max
Life test
Appearance: no damage.
Impedance: within±15%of initial value.
RDC:within ±15% of initial value and shall not exceed the specification value
Load Humidity
Thermal shock
Vibration
Bending
1. Applied the allowed DC current.
2. Temperature measured by digital surface
thermometer.
Preconditioning: Run through reflow for 3
times.( IPC/JEDEC J-STD-020E Classification
Reflow Profiles)
Temperature: 125±2℃
Applied current: rated current.
Duration: 1000±12hrs.
Measured at room temperature after placing
for 24±2 hrs.
Reflow Profiles)
Humidity: 85±2%R.H.
Temperature: 85±2℃.
Duration:1000hrsMin.Bead:with100%ratedcurr
ent , Inductance: with 10% rated current
for 24±2 hrs..
Reflow Profiles)
Condition for 1 cycle
Step1: -55±2℃
30±5 min.
Step2: 125±2℃
≦0.5min
Step3: 125±2℃
30±5min.
Number of cycles: 500
for 24±2 hrs.
Appearance:No damage.
Impedance:within±15% of initial value
Reflow Profiles)
Oscillation Frequency: 10Hz ~ 2KHz ~ 10Hz
for 20 minutes
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles
each of 3 orientations)。
Impedance:within±10% of initial value
Shall be mounted on a FR4 substrate of the
following dimensions:
>=0805inch(2012mm):40x100x1.2mm
=0805inch(2012mm):1.2mm
0805inch(2012mm):1kg
很抱歉,暂时无法提供与“HCB1608KF-221T25”相匹配的价格&库存,您可以联系我们找货
