ES8D-ES8J
Surface Mount Superfast Rectifiers
Features
Glass passivated chip junctions
Ideal for automated placement
Ultrafast reverse recovery time
for high efficiency
Low profile package
High forward surge capability
High temperature soldering:
260℃/10 seconds at terminals
Component in accordance to
RoHS 2002/95/1 and WEEE 2002/96/EC
Mechanical Date
Case: JEDEC DO-214AB molded plastic
body over passivated chip
Terminals: Solder plated, solderable per
J-STD-002B and JESD22-B102D
Polarity: Laser band denotes cathode end
Maximum Ratings and Electrical Characteristics
o
Rating at 25 C
ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or
inductive load. For capacitive load, derate current by 20%
Type Number
Maximum Recurrent Peak Reverse
Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified
Current See Fig. 1
Peak Forward Surge Current, 8.3 ms
Single Half Sine-wave Superimposed on
Rated Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@ 8.0A
Maximum DC Reverse Current
o
@T A =25 C at Rated DC Blocking Voltage
o
@ T A =100 C
Maximum Reverse Recovery Time
( Note 1 )
Typical Junction Capacitance ( Note 2 )
Maximum Thermal Resistance (Note 3)
Operating Temperature Range
Storage Temperature Range
Notes:
version: 02
Symbol
ES8D
ES8G
ES8J
V RRM
200
400
600
V
V RMS
140
280
420
V
V DC
200
400
600
V
I(AV)
8.0
A
I FSM
125
A
VF
0.98
1.3
1.7
V
IR
10
350
uA
uA
Trr
35
nS
Cj
R θJA
R θJL
TJ
T STG
45
pF
30
75
-55 to +150
-55 to +150
1. Reverse Recovery Test Conditions: IF =0.5A, IR =1.0A, IRR =0.25A
2. Measured at 1 MHz and Applied V R =4.0 Volts
3. Units Mounted on P.C.B. 0.4” x 0.4” (10mm x 10mm) Pad Areas
http://www.trr-jx.com
Units
o
C/W
C
C
o
o
ES8D-ES8J
Characteristic Curves (TA=25 ℃ unless otherwise noted)
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
FIG.2- TYPICAL REVERSE CHARACTERISTICS
1000
10.0
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD CURRENT. (A)
RESISTIVE OR
INDUCTIVE LOAD
0.4X0.4"(10X10mm)
COPPER PAD AREAS
8.0
4.0
90
100
110
120
130
140
150
o
LEAD TEMPERATURE. ( C)
FIG.3- MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
Tj=1250C
10
Tj=850C
1
Tj=25 0C
0.1
PEAK FORWARD SURGE CURRENT. (A)
125
8.3ms Single Half Sine Wave
o
(JEDEC Method) at TL=120 C
100
0.01
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
80
60
40
80
FIG.5- TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
Tj=25 C
PULSE WIDTH-300 S
1% DUTY CYCLE
INSTANTANEOUS FORWARD CURRENT. (A)
100
10
1
NUMBER OF CYCLES AT 60Hz
FIG.4- TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE.(pF)
60
Tj=25 0C
f=1.0MHz
Vsig=50mVp-p
50
40
30
0.1
10
100
10
0.01
0.4
0.6
0.8
REVERSE VOLTAGE. (V)
1.0
1.2
FORWARD VOLTAGE. (V)
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50W
NONINDUCTIVE
10W
NONINDUCTIVE
trr
+0.5A
DUT
50Vdc
(approx)
PULSE
GENERATOR
(NOTE 2)
1W
NON
INDUCTIVE
OSCILLOSCOPE
(NOTE 1)
NOTES: 1. Rise Time=7ns max. Input Impedance=
1 megohm 22pf
2. Rise Time=10ns max. Sourse Impedance=
50 ohms
version: 02
-0.25A
-1.0A
1cm
SET TIME BASE FOR
5/ 10ns/ cm
1.4
1.6
1.8
很抱歉,暂时无法提供与“ES8J”相匹配的价格&库存,您可以联系我们找货
